Anyone know how to fix so the fibaro EU wallplug works?
I have 4 of them installed. They work fine with the standard ZWave Metering Switch.
What doesnt work for you?
It does not work to install in in Samsung smartthings for me
Ah i have read about it that the new Version HW rev 3.2 are currently not working with smartthings. Do you have one of the 3.2 HW revision?
Hos to check version? I have fibaro wallplug fgwpx-102-en-s-v1.00
Actually i believe this problem only belongs to the Motion Sensors, sorry.
Have you tried pairing them to the hub:
- Go to Smartthings App
- Click on Marketplace
- Click on Connect new Device
- Plugin Wallplug
- Press Button on Wallplug
- Click on the detected WallPlug in Smartthings.
Let me know if it works or not.
Yes this worked!! THX!!
I just installed my ST hub v2 ( got it from usa) and i just pluged my fibaro wall plug FGWPE/F-102 i followed the above steps but the SmartThings searching forever without finding it, any help here ?
Hi you sure your fibaro plug is for US version frequens? Maby this is the problem because I heard that its not same frequens in US and EU version of smartthings
viktor
Hi,
I have ST hub V2 and a FIBARO Wall Plug both EU versions.
Hub is searching but doesn’t find the device.
If anyone was able to enroll please help.
Thank you.
Any update on this? I have the 3.2 version and it is not being detected.
Same problem here. I have a UK SmartThings and trying to connect Fibaro Wall Plug FGWPE-102 ZW5 v3.2. ST searching forever!
UPDATE: It is now working. Press and hold the B button to reset, then triple click and ST should find it.
Hi @jjs,
I cant add it to my smartthings can you help me?
Did you found a fix?
Did you found a ris
Did you foud a fix
