Fibaro smoke sensor not reporting temp
Go to IDE
Click on My Device Handlers
Click Create New Device Handler
Click From Template
Select Fibaro Smoke Sensor and create
From the simulator on RH side, select your location and the device you want to configure
Triple click the button on the smoke sensor and click the configure button on the simulator, if you also have a tab with live logging you will be able to see if the configuration is sendt and received
