On some of my FIbaro Smoke Sensors I can not update the configuration/settings.
I think I have narrowed it down to it not setting the MSR.
For the sensor I´m able to change the configuration, the MSR is listed under “Data” in the IDE. These devices was added a long time ago. For the devices recently added, MSR is not listed and when I try to hit the B-button on the device to update settings/configuration, this message is in the logs:
3199603c-9973-4a98-98c0-6ba9c9b4b019 12.13.49 CEST: info checking this MSR : null before sending configuration to device
When I do the same for the ones that are working, then this is the message:
f8f731fb-1a7c-45d3-89dd-729e85ddf0c3 12.15.45 CEST: info checking this MSR : 010F-0C02-1002 before sending configuration to device
The RAW description is also listed in a different way
For the ones that is not possible to change config:
zw:Ss type:0701 mfr:010F prod:0C02 model:1002 ver:3.03 zwv:4.05 lib:03 cc:5E,86,72,59,73,80,22,31,56,98,7A sec:20,5A,85,84,71,70,8E,9C role:06 ff:8C01 ui:8C01
The ones that are working:
0 0 0x0701 0 0 0 13 0x5E 0x20 0x86 0x72 0x5A 0x59 0x85 0x73 0x84 0x80 0x71 0x56 0x70 0x31 0x8E 0x22 0x9C 0x98 0x7A
I have tried contacting support many times, the latest reply was this:
“There are set APIs provided by Fibaro for the integration, and I’m afraid the settings of the Fibaro Smoke Sensor can not be changed through SmartThings. The only thing I could suggest is to change the Device Type Handler for the Smoke Sensor via IDE to see if it works better for you”
@tyler, @jody.albritton, @slagle anyone?
