Any option to have a driver for Fibaro Roller Shutter 4 FGR-224 to be used with smartthings?
Thanks and regards
Hi @Chemy
I posted this test driver for the FGR-224 back in August, but I havenβt received any feedback from the user who requested it.
If you want to try it out, itβs available on my shared channel
Z-Wave Window Treatment Mc-TEST
2024-12-10T17:32:13.897215207
Thanks a lot. It seem to work fine.,!!
Thanks for feedback.
In some days if works fine I will merge with the Mc driver
Hi @Chemy
This driver is the same one you are using as the TEST version.
You can install this driver on your hub and perform a driver change to this driver whenever you want.
You can also continue using the TEST driver as long as you do not delete it from your hub.
I will delete the TEST driver from my channel, this will not affect your device
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Z-Wave Window Treatment Mc
Version 2024-12-16T17:16:33.184772953
