So I have purchased a few items from Fibaro. I have the following
FGS221 - Relay Switch 2x1.5kW
Thanks to Mellbrat, (Z-Wave Fibaro Motion Sensor and Z-Wave Fibaro Relay Insert 2 * 1.5 KW) I managed to get this working as I want.
FGWPE/F-101 - Wall Plug
Initially detected as a standard Z-Wave Meter Plug, but I copied the code from the default device and added the correct fingerprint to detect this device as the Fibaro switch. So was happy there.
However, I also have the FGRM-222 - Roller Shutter, but I cannot get this to work. It is not detected as anything at all. I have used the base frame from other device and to try to create the correct Fingerprint (have used a friends Rasperry Pi http://razberry.z-wave.me/ to detect the command class codes. Even compared the details collected by Razberry for the Wall Plug to ensure I am reading things correctly) However, nothing I do will have this detected. I have forced complete reset on the FGRM-222, to ensure it’s not already paired to a device.
Firstly, has anyone else gotten this to work?
Secondly, is there a true debugging view on the Hub, I mean to see even things it receives but discards. I know the logging mode exists, but this only shows me information pertaining to devices it has detected.
Thirdly, if there are command classes that are not understood by the Smartthings, will the device be ignored entirely?
If any information is needed, please let me know. In a recent attempt to resolve detection, I removed all device types, and started again. I have the code at home, but cannot post the fingerprint I am using at this time. I’ll try to update tonight.
Many thanks for any help that can be provided.
