Fibaro roller shutter 2 not work with SmartThinghs (Samsung connect) but work with SmartThings Classic?
Hi,
i have successfully connect my fibaro roller shutter 2 FGS-222 with my v2 hub (with device handler script).
All work in SmartThings Classic but in SmartThinghs (Samsung connect) i see Fibaro in my device but
with no action. If i tap on fibaro i get “Can’t connect to Device. Check device and try again”.
If i remove device handler script and set fibaro to default “fibaro dimmer”, it work in Samsung connect but
i lost ability to calibrate etc…
There is a workarround to make fibaro roller compatible with samsung connect?
No custom code work with smartthings (Samsung connect) at this point.
Ok thanks, not work for custom code compatibility or for samsung connect problem?
I need to setup my home, but if i make all setup in SmartThings classic i can port in samsung connect later?
