Awesome, thank you for the clarification, have you got a link to the strips you used by any chance?
Anyone have any suggestions on where I can buy RGBW 24V strips in 100FT rolls? I need about 109FT in total for both of my tray ceilings.
Is this still happening? I have migrated all of my devices over to V2, but I am holding off on setting up the SHM part until i know this is fixed so i dont lose control of it again.
@twack any idea on when a fix is coming for this?
Yes it still happens, only when you have shm change colors. Shm can still turn the light off/on without problems
Looking at it now.
Twack
Any luck on finding the issue @twack?
I am getting ready to cut & solder the LEDs for my kitchen cabinets. I have two strips, RGB & RGBW. I am at a loss as to why I would use the RGBW. My whites are about the same at full power and the RGBW colors are less than half the brightness of the WW strip using every other LED. Thoughts?
GTC100,
I have found that the strips are all a bit different, even the same brand and model have subtle differences. You find the best fit for you particular application. Most of them are pretty cheap these days.
Please post a pic/vid when your project is done. We’d all love to see it.
Twack
Hi guys,
I have been following this thread with interest for a while.
I am about to complete a large home extension project in the UK which includes having a new kitchen fitted into a 50sqm room and all of my lighting/electrics redone. I am planning to include RGBW light strips around my kitchen island (7.4m), along my opposing worktop (2.7m) and under the wall cabinets (2.7m) using RGBW LED strips and power driver(s?) from here:
I plan to buy a Fibaro RGBW controller and to integrate with ST and use @twack’s code. I am impressed with the feedback I am seeing in this and other threads for it.
The wiring needs to be installed in the next couple of weeks and I am keen to make sure I get everything right.
I have a few (probably dumb) questions that I would appreciate some advice on:
I understand that the Fibaro controller controls the dimming levels of each colour (plus white) to get the full range of colours through the software but what is the best set up in terms of physical hardware - by which I mean physical light switches?
Is it worth having the LED power driver hard wired to a z-wave light switch on the wall to provide a sort of ‘override’ switch or is there a better way of doing this? I appreciate that I don’t actually need a physical light switch at all, but I suppose I’m looking for some suggestions on the most practical setup for a kitchen.
Appreicate your advice.
hey, so if you notice on the RGBW controller you have analog inputs, I believe you can wire a switch to the analog input that allows you to turn it on and off.
Thanks, Ronin. Good to know.
One more question that I forgot to ask above:
Can I/should I connect a z-wave dimmer switch to the Fibaro RGBW controller? I understand that the Fibaro dims individual colours from the RGBW selection to create any colour in the palette, but can you also use a z-wave dimmer switch connected to the controller to then dim your selected colour or does this have to be done through software?
The controller itself changes colors, dims and turns on/off
if this is a stupid question, apologies…
the reason for using the fibaro rather than something like the Hue Lightstrip or Osram Lightify strip is what? does it provide some functionality that the others do not?
and follow-up on the “wiring switch to analog inputs” comment - would that be in the same electrical box or does the placement not matter? having problems visualizing physical connections/wiring needed from a light switch somewhere on a wall in a kitchen and having an LED strip turn on under kitchen cabinets
You can use any LED strip with this controller, including multiple strips connected together (as long as you have the power to run them). With the Hue and Osram, the strip is all part of the controller. Not sure if you can add on to the strips or not. But you can get much brighter/higher quality LED strips and integrate them in to ST with this. Another benefit are the Inputs, and the ability to control 4 channels independently (all white, you lose RGB control doing this).
Also the Fibaro supports a higher wattage without the need for more amplifiers as far as I know, although this is a bit more complicated to answer. But I have osram lightify and the fibaro and I prefer the fibaro as it is also a zwave repeater and easy to use/install with a more customizable interface. Plus fibaro products are quite premium.
Twack,
Can you modify this police app to activate by a Virtual Switch instead of a contact sensor?
-Brian
Sounds like you want a Button in the App on your phone that when Pressed, turns on the Police Lights?
Here you go:
Turn-on-Police-Light-When-Switch-Is-On.groovy
Here’s another app that I had that is kind of fun. It allows you to choose what action, or color/program, that the Fibaro RGBW controller will run. If you don’t pick an action, it will cycle through the list of possibilities, changing each time the contact sensors opens.
Trigger-Fibaro-RGBW-Action-From-Contact-Sensor.groovy
Hope you enjoy,
Twack
