Fibaro RGBW Controller (DTH link in post 32, police light smartapp link in post 79)
Hey, so that didnt work for me but, now that I know Smartthings smartapps code are open and available I used one of them which turns on switches.on and that seems to turn the white channel on also. so does lights*.on but switch1.on only does the RGB, if I could get a hold of the new smart lighting app I would love that so I can modify that.
In any case thank you very much for all the help Twack.
I had a mistake in the sample. Try again with the edit (above).
Got a question about a problem here – any pointers greatly appreciated.
I had a Fibaro RGBW controller sitting and waiting here for a bunch of months. After getting my hub yesterday and adding all the devices I already had, I unhooked an RGB LED strip I use every day in the kitchen stock w/its remote and hooked it up the Fibaro controller. It connected to Smartthings right away, nice device. But, the strip does not come on.
  • The device handler seems to work. moved all controls to all extremes slowly.
  • Activities show the changes there
  • No light…
I unhooked the strip & put it back original and it worked.
Any ideas or pointers?
Looks like the black strip wire is in connected to ground. It should be connected to 12/24 VDC
The other way around. The black wire on the strip is the powered line, not the ground:
My black wire is connected as described in the above manual AND it works.
But, but… Black is always Ground!
Thanks all! Easy fix. Works well.
So good to be back in the Community.
You’re 100% correct, I just went back and looked at my Dresden ZigBee setup and you’re spot on. I shall delete my previous post to avoid confusion.
Sorry to say I have a fundamental question on which Fibaro RGBW Controller file to use:
I installed a Fibaro RGB Controller device type I found - it did not give me the bottom tiles.
I tested in the IDE and I could control the strip from there including storm, police, etc.
I found one that did give me the tiles, but could not control the strip from the IDE nor App!
What am I missing?
Hi @gtc100
I use the device type written by @twack . Everything works fine for me. I will warn you that if you use smart home monitor or the new smart lights app to change the color. It will “hijack” the controller so to speak. Only way I could get control of it again was to change colors with an older app. Support said it’s not a supported device and sent me to this thread. I have a feeling the new apps changing color are written to work with hue and not fibaro. I’ve worked around this using virtual switches and older apps.
Thanks for the heads up. @twack, is there an official word on this?
Holy crap, so that is what happened to my Fibaro…I had it set to turn the fibaro Red when the SHM was triggered, and then the device tile would crash every time i tried to open it. I ended up just deleting the controller from ST and mess with it when my V2 hub finally gets here.
@DinnerYeti
Thats exactly what happened to me, Had SHM turn the Fibaro to red. Turned red then turned them off. when i went in to try and turn them back on the app crashed every time.
Hey all,
The fibaro rgbw controller never got official integration due to some Zwave Color hacks I had originally put in the DTH. It needs to be re-aligned with the proper color control methods. In backlog for me right now.
As for turning on the bottom tiles, how did you install it? From my github?
hopefully @twack can fix this soon, until then below is the app i used to restore the controller. You only have to install this app once to restore the controller . What I was doing with this app is I installed about 5 copies I changed line 42 in each install to the color i wanted the lights to be, i then installed 5 virtual switches called one called “red lights”, another “green lights”, another “blue lights”…you get the idea…when it was all said and done I could then Have Alexa turn on the different color lights…it was just a fun little project for me. :smile:
preferences {
section(“When this switch turns on …”){
input “contact1”, “capability.switch”, title: “Where?”
section(“Turn on the Fibaro color…”){
input “switches”, “capability.switch”, multiple: false
def installed()
subscribe(contact1, “switch.on”, contactOpenHandler)
def updated()
unsubscribe()
def contactOpenHandler(evt) {
log.debug "$evt.value: $evt, $settings"
log.trace "Turning on switches: $switches"
switches.blue()
def contactclosedHandler(evt) {
switches.off()
I am trying to exclude my fibaro rgbw controller to migrate over to V2, however the controller is out in the pool utility box in the yard and doesn’t have a great wifi signal. Is there a way to get it excluded without disconnecting and moving it indoors?
I personally would use a long network cable and extension cord to move the hub closer to the controller. only reason is the little tiny wires and screws on the controller are a pain (for my old eyes anyway)
Well, I thought so, but it may have been from the Smartthings account, too. I have been all over github, but I am still not sure how to get the latest of something mentioned here. I just went back to github & pulled a version from your repository specifically and it is working.
I am seeing the problem being described. SmartLighting & your device type are not compatible.
-I turn it on directly to Police color
– ST sends Blue to it based on SmartLighting on motion, the LED turns off
— I am able to just turn it on again with any of your colors.
– ST sends Blue again based on same, nothing happens to LEDs.
on my ipad, I can do all this over and over…
On my android phone, I can turn them on & off, but it crashes when I go into the device every time
If you have an Aeon Minimote, you can exclude with that. Solves a lot of exclusion issues. :sunglasses:
OK, I was able to get it excluded but now I am not getting a response after including it on the V2 hub. I am using @twack code for the device type which was unchanged from the V1 hub. I did change the name of of my device from Fibaro RGBW Controller to Waterfall Lights, do I need to change that in the code somewhere?
I checked and pulled yours from github. It works on both Android & my ipad w/o crashing. I removed my LEDs from SmartLighting, but do use goodbye, goodnight, and gentle wake up. None of which change the color. So far so good.
