Hello, this is driving me mad so any help is appreciated.
I have the Fibaro FIBEFGK-101-ZW5 Door/Window Sensor. For some reason I can’t find a device handler that works correctly with it, despite it being officially supported by SmartThings.
I have had it set up working fine, but decided to mess around with it by hooking it up to a pressure pad. Now I can’t get it to detect open/closed properly.
The “Fibaro Door/Window Sensor ZW5” device handler detects open and closed stated but seems to be getting these mixed up with tamper active. The “Fibaro Door/Window Sensor ZW5 With Temperture” has the same problem while “Fibaro Door/Window Sensor” displays correctly within the app but does not detect the open/closed state. It just gets stuck on open/closed.
I have tried removing the device from SmartThings and resetting the device as per the manual and have added it to SmartThings again but with the same problems.
I have also tried JJ’s device handler with no luck.
Is anyone able to give me any help?
It’s driving mad as I did have it working perfectly previously both with and without the pressure pad attached, I think I may have been using a custom device handler, but can’t remember where I found it or what it was called.
Any help is appreciated.
regards
