Features missing without the IDE
I wonder if they are gonna add a reboot hub button in the app?
Interestingly, if you have the Wi-Fi (Plume) hub, there is an option to reboot the entire hub (not just the ST Hub portion). Click on the hub device->Network status->Click on specific Hub/sub-hub->Click on 3-dot menu->Reboot device. There is also an option to factory reset as well.
There is nothing in settings for ver 2 hub, which is what i have & probably nothing for ver 3 & aeotec hub. Hopefully thats something that can be easily added.
reboot hub and topic of the thread is weird information in the IDE - only slightly off topic :slight_smile:
just-saying-colin-jost
sorry - just wanted an excuse to use the gif
Moved to new thread. :wink:
Ok, so what’s everyone take on this? I hope they do add a reboot button in the app.
My take is there should ALWAYS be a soft reboot option available. But im old school…
Ya, having a soft reboot option should be required. On a previous hub, I once discovered that it was over a year behind on updates, a reboot and it caught itself up and stayed current after that.
Otherwise, it’s a pain to do a hard reset, given that all my hubs have been v2s. Though I was contemplating taking the batteries out, and switching the cable so I can control it via a smart USB socket controlled by either eWeLink or Smart Life…
Just as the local edge drivers giving me a way to reboot my router… though neither soft nor hard reboot of my router would’ve helped when edgebridge took it down (I had created a feedback loop that caused edgebridge to create a logfile (without debug) of over 10G…
Or maybe it’s time to upgrade the thumb drive that my router runs on, again. Was using a 16G drive, but upgraded to a (faster) 32G drive … perhaps something like the 256G drive I got so I can do cross-compiles to build new router images.
Both servers are running on my router…
It didn’t really register in my brain that there wasn’t a soft reboot option in the app. Like @nathancu I’m old school, there really should always be one. My ST Hub isn’t in the most convenient location.
I used the IDE yesterday when I needed to soft reboot. That still works for now.
6 months later and still no soft reboot in the app. I hate that I have to perform acupuncture pressing the little button on the back of my hub! I’m both lazy and not a contortionist!
Lets be honest , you do not need to do anything to the hub to reboot it that is simply a choice you are making.
All you need to do is leverage a smart socket and you can reboot it just fine remotely. I think I have rebooted mine roughly 20 times over the past year by taking this approach.
When you use a smart plug, that’s a hard reboot. You’re just cutting the power and then restoring it. A soft reboot, which is done by the hub itself, is a different function. For one thing, if your hub has just started a firmware update (something you have no control over because smartthings pushes it out from the cloud), a hard reboot significantly increases the likelihood that there will be a problem when the hub restarts. A soft reboot will shut down “gracefully“ in engineering terms, making it less likely that there will be problems on restart.
Sure, most of the time a hard reboot goes OK, but for best practices, a soft reboot is always preferred if it’s available. FWIW.
hub reboot is now available
