I recently purchased a 4-pack of Galaxy SmartTag2s and ran into some significant usability limitations regarding Power Saving Mode and Offline Searching while simulating a lost item on a remote hiking trail; i.e. retrace my steps to locate the item.
I would like to submit the following feedback and feature requests to the development team:
1. Power Saving Mode Disables “Ring”
The Issue: Enabling Power Saving Mode completely disables the “Ring” feature.
The Problem: You only need to ring a tag when it is actually lost. In that critical moment, finding the item is a higher priority than saving battery. Users who want to save power simply won’t press the ring button; it shouldn’t be forced off globally.
Recommendation: Allow the “Ring” feature to remain available in Power Saving Mode, or automatically override power savings when the user actively triggers a search.
2. “Search Nearby” Requires Data or Wi-Fi
The Issue: I simulated a remote hike by turning off cellular data and Wi-Fi. The SmartThings app refused to even open or initiate the “Search Nearby” feature without an active internet connection.
The Problem: Items are frequently lost in remote areas (hiking trails, campsites, beaches) where there is zero cellular service.
Recommendation: Support Offline Search. The phone should be able to use its local Bluetooth/UWB radio to detect and track a local tag without needing to ping a Samsung server first.
3. Cannot Change Tag Settings Offline (The Workaround Failure)
The Issue: As a workaround simulation, I opened “Search Nearby” while connected to Wi-Fi, forced the app to Keep Open, and then disconnected from the network. While the local Bluetooth search worked, I ran into a wall: because I was offline, the app would not let me turn off Power Saving Mode to ring the tag.
The Problem: Even if you successfully track a tag down to a 5-foot radius using UWB offline, you cannot toggle the ring feature to find it in deep brush because the setting change requires an internet connection.
Summary Request for Samsung Developers:
Please implement “Offline Search with Ring Override.”
Users must be able to initiate a local Bluetooth/UWB search entirely offline.
The local “Ring” command should instantly override Power Saving Mode during an active search.
Is anyone else concerned with these limitations?
