FAQ: Zwave Secondary Hub Basics
As always, The first rule of home automation applies: “the model number matters.” This FAQ is just going to lay down some general concepts about Z wave secondary hubs. It does not apply to Zigbee. It does not apply to Wi-Fi mesh sub hubs. And it doesn’t even apply to all zwave hubs except at the most basic level. But it should help explain the basic concepts. And I’m going to try to keep this as simple as possible at the conceptual level, so there may be a few places where it’s not 100% technically accurate, but it will give you the idea of the impact on your usage of the system.
THE PRIMARY ZWAVE HUB
Every Z wave network is “established“ by a primary controller. Usually the hub. The primary hub is responsible for giving out network addresses, keeping track of the security keys, and adding or removing devices from the network.
A smartthings hub expects to be the primary zwave hub on its network unless it is one of the Wi-Fi mesh subhubs, in which case it will take a subordinate role.
It is technically possible to add a smartthings hub to another network owned by a different brand of primary zwave hub, but it may not work very well if you do.
When the SmartThings Hub is added into another Z-Wave network, it may not receive notifications from some battery-operated devices. SmartThings Technical Support does not provide assistance to consumers using the Hub with other Z-Wave controllers.
It also lacks some of the Z wave utilities that other Z wave controllers may have.
So one of the most frequent questions about secondaries that gets posted to the forum is “can I add my smartthings hub as a secondary to my existing zwave network“? and the short answer is that yes, you can do it, but you probably won’t get the results that you expect.
THE ROLE OF A ZWAVE SECONDARY CONTROLLER
Back when zwave was first developed, everything ran locally, and the theoretical role of a secondary controller was to speed up local communications for a specific set of devices which were physically close together. Like on another floor of the house. Or a handheld remote in a room with several Z wave devices.
When a secondary controller is added to an existing zwave network it should not have any devices already connected to it. You basically have to start from scratch. At the moment that it joins, the primary controller will pass over to it a list of the Z wave devices currently attached to the network. That’s pretty much all that it gets. In some networks you will have the option to allow the secondary to add new devices to the network, but in others not.
Once the secondary is on the network, it can then communicate with the devices in the list it was given when it joined, except that it may not be able to communicate with locks because it doesn’t have the security keys for those.
As mentioned in the note from smartthings support above, most secondaries Will also not receive lifeline messages from some individual battery-operated devices.
If the secondary is allowed to add devices and it does, usually the primary will also know about those devices.
However, it is really common that if the primary adds additional devices after the secondary was added to the network, the secondary will not know that those exist.
There are a few secondaries, such as the Aeotec Z stick, which will continue to query for new device adds and so generally stay in sync with the primary. And vera has its own system for keeping multiple Vera brand hubs all in sync with each other.
but other than that you should pretty much assume that your secondary hub will only be aware of zwave devices that were on the network at the time that it was added to the network. that means if you want to secondary to be aware of devices added after the time that it was it self added to the network, you have to exclude it and re-include it. That can be a lot of work if you have to also rebuild automations. :disappointed_relieved:
Nonzwave devices on a multi platform hub
If you have a multi platform hub, like smartthings, and it is on a Z wave network, whether it is the primary or the secondary, you also need to understand the information about any of the other protocols, like your Zigbee or Wi-Fi devices, is not shared. joining a Z wave network just means joining the Z wave network. It doesn’t mean you can then fold in other devices controlled by either hub.
Summary
Some platforms, including smartthings and most security systems, assume that their hub will always be the primary zwave controller and results may be unsatisfying if you try to set them up as a secondary, even though technically it may be possible.
If you do want to set smartthings up as a secondary, it should not have any Z wave devices connected to it at the time it joins the other network. It will only know about devices that were on the other network at the time that the smartthings hub joined that network. It will not be able to message locks. It may also have difficulty with some battery operated devices that are trying to use the lifeline group. SmartThings support will not help you if you run into problems when you have a smartthings hub set up as a secondary to a different brand’s primary hub.
If you want to use smartthings as the primary and another brand as the secondary, that may work fine with the same caveats: it may only know about Z wave devices that were on the network at the time that it joined the network; it probably will not be able to message locks; it will not receive lifeline messages. and it will not have any information about the non-Z wave devices on your SmartThings account.
In the past, some people have successfully used one of the swimming pool management Z wave controllers as a secondary, but these are pretty much self contained systems. Quite a few people have added a Z wave USB stick in order to get its mapping capabilities. Also quite a few people have been able to add handheld zwave remotes of various types to act as secondaries for a few specific devices. And a few people have added a vera, for whatever reason, and managed to get what they wanted out of it.
Most attempts to connect to a security system in either direction have not been successful.
So while it can sometimes be done for some specific situations my first question would be why are you trying to do it?
if it’s for a specialty sub system like the swimming pool management systems, that makes sense.
If it’s to tie in your smartthings home automation to a security system, that probably won’t work the way you were hoping.
if it’s for a handheld remote designed for that purpose, go for it.
for any other use case you will probably want to consider alternative approaches. :sunglasses:
Very helpful and informative. Thank you.
Figured I’d follow up on this post. I had to add an Aeotec Zstick to install firmware updates, because Smartthings does not support Zwave firmware updates. Everything you said above @JDRoberts is spot on, and boy Zwave networks DO NOT like having two controllers attached. It was temporary to just install firmware updates, but it caused all sorts of problems. It took me days to get my two switches that are near the edge of the range (in detached garage) stable and working again after attaching and removing this Zstick. I could not remove it from the network easily, as both Smartthings and the Zstick tried fighting for control. Putting the Zstick into exclusion mode is designed to exclude devices FROM the Zstick, not to exclude the Zstick from a different network. I had to reset the Zstick multiple times and really play around with the software with the classic app and IDE to get things working again. If there was no classic app, I have no idea how I would have fixed this. As I pointed out in this post - Get ready to make the switch! I am also realizing the limitations of Smartthings when it comes to Zwave control. It seems to me that the main purpose of Smartthings is to unify multiple different devices across different platforms. Up until the recent migration issues, it did that amazingly well, and hopefully when they work out the bugs, will continue to serve that purpose. However, for me, 90% of my devices are Zwave devices, which I installed 3-4 years ago probably when Zwave was “new and exciting”. I don’t have a lot of “cross platform” setups linked together through Smartthings like a lot of other people who I see posting on here. I still like Zwave and it has huge benefits over WIFI devices, but I am questioning its long term future, especially when Amazon’s newest Alexa went with Zigbee and no Zwave support. Most devices I have are “Zwave Plus”, but 3 are legacy Zwave - 2 Aeotec Micro Switches, and one GE/Jasco on/off. It annoys me that I have one toggle that is not Zwave Plus, because at the time I bought them from Amazon they were similar in price and I didn’t understand or realize the difference between the original and plus version. I really don’t want to rip these out every few years either - it is not good for the house’s wiring to constantly be flexing in and out of the wall. The wiring is not designed to do that, with “dumb” switches lasting more than 30+years, and I’ve already had wire break and as it gets shorter and shorter every time I replace a switch, I don’t want to have to rewire my whole house.
Anyway, as I pointed out in the other post, Zwave control seems to be absent in the new Smartthings app as well. I deleted a device and it just deleted it from the new app, but did not do an exclusion from the Zwave network, and also there was no option to force remove. If others do that, it will leave “ghost” devices on their Zwave network that will haunt it forever, and they will be left with no choice but to exclude every device, factory reset the hub, and start over, a daunting task for anyway, especially with a lot of devices and programmed automatons. Looking back on my purchase of Smartthings, I’m second guessing on whether it was the best choice for my setup.
It’s hard to guess about the future. Although you’re absolutely right that the Alexa devices with built-in smart hubs only use Zigbee, not Z wave, the ring security system (also owned by Amazon) uses only Z wave, not Zigbee. That’s probably because with the new S2 security protocols Z wave can be UL listed as a security system and zigbee so far cannot.
https://products.z-wavealliance.org/Search/DoAdvancedSearch?regionId=2&category=-1&brand=648
Also, Z wave doesn’t have to worry about interference from Wi-Fi, which is particularly important for systems which include Wi-Fi cameras and doorbells, like ring, where they may want to boost the Wi-Fi to get good video while not affecting nearby security sensors. :sunglasses:
So it’s just not clear yet where things will end up in five years. each protocol has pros and cons.
That’s true, Zwave seems to have a bright future with home security. Thanks for the optimism :slight_smile:
Thank you! This has been an extraordinarily helpful post for me, explaining most probably why I threw my smart things hub through a glass window (literally). Yeah, I have a bad temper…
I have a 96 zone Ademco (Honeywell) security system with a z-wave automation device called a VAM. My Z wave network has about 60 devices in it. The real and only reason I looked at the SmartThings hub at all was because of its Amazon Echo integration.
I divide my automation into two spaces, (1) convenience, and (2) security. Many devices overlap, many do not.
“Convenience“ is “… Alexa turn on cove lighting“. “Security“ is lights on for alarms, lights on when coming in at dark, lights off when arming for night mode, etc.
In order to make all of this work, SmartThings MUST run in secondary controller mode. This is enforced because the VAM MUST run in primary controller mode if it is to connect to the Honeywell Total Connect 2.0 [TC 20] security management system which is required for many reasons.
I was trying to get the best of two worlds, but as you noted in the post, new devices do not automatically pop over to the secondary, nor do meta-data, such as the name and type of the device. Once the SmartThings pulls the initial data transfer, and you have set up complex scenes and automation scenarios, you’re extraordinarily hard-pressed to dare touch the freaking thing again… thus the aforementioned window incident. Samsung is polite, but useless, stating that “… Yes, you can run it in secondary mode, but we do not provide any type of support for it at all.”
It was actually all running quite well, for nearly 2 years, then it just stopped… And I couldn’t get it fixed no matter what I did. Because I got in a lot of trouble for breaking a window pane, I’ve done without the extraordinary convenience of “Alexa“. Because of your post on the subject, at least I know all of my problems weren’t created by “me“.
I have had a SmartThings hub working as a Secondary Controller for 5 1/2 years with Zero problems.
The issues that are mentioned in previous?
All of them are solved problems.
Lifeline? Most devices allow up to 5, but it is non-issue, because the primary controller does not need to be associated to a device ( I have multiple Stelpro KI, they only allow one device to be associated so my SmartThings controller is it ).
Battery operated devices? There is no requirement that the primary controller handle Wakeup. Most battery operated devices can have multiple devices associated to them, which is fundamental to how z-wave works, so having multiple hubs receive events battery operated devices is not a problem.
And my SmartThings has never been Node 1,… and this has never been issue, which speaks for itself (aka, in a positive way about SmartThings). The number of Z-wave gateway vendors who have made assumptions about which node their Gateway? Sadly, this is a common mistake.
Most of the posts about Z-wave secondary controllers are FUD.
