Hi David,
If you have wifi bulbs (I have Lifx), may I suggest Logitech’s Pop Switches be considered.
I’ve been using them for a few years now. Have placed covers over the wall mount switches and placed Pop Switches directly above and in some rooms, where I actually need a switch too. Example, next to beds (where their control Wemo sockets for bedside lights and the main overhead light being Lifx bulbs).
On occasions, I’ve read comments about others finding them unstable or unreliable and a few years back, in my experience that was true but, not had any problems for over 3 years to date.
If I have gone off on a tangent, please forgive me but I hope my post was at least interesting.
All the Best,
Darren
Hi Darren. Thanks for replying! I went for a Fibaro dimmer 2 for a switch with multiple lights. I’ve also bought myself an IKEA build which I’m having troubles with. I just can’t pair it at all! To add to the frustration pairing my account with Google Assistant is also failing. I’m not having much luck at all so far and I’m beginning to think the Smartthing hub wasn’t the best choice at all…
Hi David,
Sorry to hear about your challenges.
I have often been tempted with Ikea’s offering and after hearing from you, glad I have stuck with what I know works reliably and well.
Other than my Pop Switches and Lifx bulbs, I use Amazon instead of Google along with Fire Sticks and Tablets.
My venture into Smartthings is very recent and working out very well. Other than integrating with my lights, my Hub V2 has been faultless with my Fibaro smoke, leak, motion detector and door contacts. As well as my Sonos speakers (and Sonos connect to my old home theatre system), Ring Doorbell and a few Smartthings detectors.
I hasten to add, been slowly purchasing IoT devices over the years.
I have a few other devices that I intend to connect to my V2 Hub. Just need to find a few hours to make it happen. Next will be my Wink egg Minder. Then thinking about my Smarter Kettle and bathroom scales.
If you choose to head down the LIFX route, I’m sure you’ll face less difficulties, I’ll be in a position to help and I’m sure you’ll find your Smart Hub a good choice.
Good luck.
All the Best,
Darren
For those based in UK / Europe I found 2 x types ZIGBEE switches which do not require NEUTRAL wire and they are not dimmers , only on/off and work perfect with smarthings and or directly with phillips hue links below.
use Samsung IDE website.
register there and then use the tutorials available via google on how to add device handlers in Samsung IDE. you will need to add the device handler as a zigbee switch and then it will work fine
Maybe a stupid/dangerous question, I’ve got no neutral at the switch, but I do have earth. Does Earth work as Neutral in this scenario or do I need proper Neutral (guessing so and wouldn’t risk it, but wondering)
Good question, and your instincts are correct: do not use the earth in place of the neutral. The radio in the switch might operate but you create a hazardous situation.
Does these two switches still working? I asked the supplier about whether it is compatible with Smartthings and they said no. Under the Q&A of the Amazon link you provided they even said it won’t work with smartthings
Yes they do still work excellent , with no problems whatsoever !
over the moon with connectivity , reliability,responsiveness,look and quality.
Do not hesitate to spend £19 even if in some cases you might loose it. At least you follow you passion which makes you happy. Imagine how much more you spent for alcohol , junk food or other poisons that actually contribute to your premature death. In my opinion these switches are very cheap
Well speech! Definitely motivated me to buy one.
Although now i’m thinking about it, do correct me if I’m wrong, smartthings hub can’t work locally without the Internet, so what is the difference between buying a Zigbee switch vs a Wifi switch?
As far as I am aware you are correct ,it cannot work locally in the smartthings but if you have hue bridge you can connect to it and in case of emergency when internet is down you can still use it. I personally don’t have a experience with wifi switches so I leave it to those who has
The wifi one would work only with the tuya cloud service and it will occupy an extra IP on your wifi network. More switches will occupy more IPs. It will make your router “overloaded/crowded”. Some routers cannot handle more than 32 devices.
It’s more complicated than that. Zigbee switches and Z wave devices connected directly to the hub are using local communications, but the logic for many automations runs in the cloud. At the present time some automations using the official smart lighting feature and some automations using the official smartthings home monitor feature are eligible to run locally if all of the devices involved are using stock device type handlers which are also eligible to run locally. The only Wi-Fi integration at the present time which is eligible to run locally is with the Phillips hue bridge.
Even so, there’s a lot of stuff which doesn’t run locally. You can’t arm/disarm STHM locally. You can’t change the mode unless the cloud is available. You can’t use the smart things mobile app to control devices unless the cloud is available even if the phone is on the same Wi-Fi as the hub. (They didn’t have to design it that way, but they did.)
No custom code can run locally, so if you are using a custom device type handler, a webcore piston, or a custom smart app, that won’t run locally regardless of what the devices are.
So…You could have a zigbee device using a stock device type handler eligible to run locally on a time based schedule created in the smart lighting feature and that might be able to run without the Internet. But you wouldn’t be able to turn it on and off with the mobile app.
So, yes, Zigbee device might allow you to do more than a Wi-Fi device if the Internet was not available – – but only some actions and not if you are using a custom DTH.
Thanks for that, kind of what my very rough thoughts were, but some great knowledge written in a clear and concise way that makes a lot of sense.
I won’t be touching it!
