Hi, @senspix.
What do you mean by “provisioning process”? Is it that the events are delayed to be sent from SmartThings to the device?
Have you tested the behavior in Android?
The team mentioned this issue is due to the SmartThings app camera permissions. There’s an issue with some non-Samsung mobile devices where the permissions to access the camera cannot be enabled.
This is a complex issue to solve so there’s no ETA on the fix. Something that could be of help is to check the current permissions of the SmartThings app in your mobile settings. Here’s a guide to do so and change them if necessary: https://support.google.com/android/answer/9431959?hl=en
Sorry about that, I put the instructions for Android.
The team mentioned that the QR option being unavailable now is intended while the issue is resolved. It’s also affecting the OCF devices’ onboarding.
I don’t know why your Android device is not being affected.
Are you planning to certify that direct-connected device? I saw that you can connect correctly to the device accessing it from “my testing devices”
No, connecting with iOS device when initiating the provisioning from “my testing devices” does not work either. There’s another network/connection issue. Se log output below.
I am working on/with 2 different devices. I believe that one device will be certified and one will only use the label “Smartthings Compatible”.
See connections log below
D (08:59:41.955) event: no handlers have been registered for event WIFI_EVENT:14 posted to loop 0x3ffc0044
D (08:59:41.956) event: running post SYSTEM_EVENT:17 with handler 0x400f9520 and context 0x3ffc00dc on loop 0x3ffc0044
I (08:59:41.965) [IoT]: event_handler(147) > station:a6:23:1c:3a:60:cd join, AID=1
I (08:59:41.973) [IoT]: _iot_easysetup_wifi_event_cb(91) > Station joined to SoftAP
I (08:59:47.226) esp_netif_lwip: DHCP server assigned IP to a station, IP is: 192.168.4.2
D (08:59:47.226) event: no handlers have been registered for event IP_EVENT:2 posted to loop 0x3ffc0044
D (08:59:47.233) event: running post SYSTEM_EVENT:19 with handler 0x400f9520 and context 0x3ffc00dc on loop 0x3ffc0044
I (08:59:47.244) [IoT]: event_handler(167) > event_handler = 19
I (08:59:48.207) esp_netif_lwip: DHCP server assigned IP to a station, IP is: 192.168.4.2
D (08:59:48.207) event: no handlers have been registered for event IP_EVENT:2 posted to loop 0x3ffc0044
D (08:59:48.214) event: running post SYSTEM_EVENT:19 with handler 0x400f9520 and context 0x3ffc00dc on loop 0x3ffc0044
I (08:59:48.225) [IoT]: event_handler(167) > event_handler = 19
I (08:59:50.226) esp_netif_lwip: DHCP server assigned IP to a station, IP is: 192.168.4.2
D (08:59:50.227) event: no handlers have been registered for event IP_EVENT:2 posted to loop 0x3ffc0044
D (08:59:50.234) event: running post SYSTEM_EVENT:19 with handler 0x400f9520 and context 0x3ffc00dc on loop 0x3ffc0044
I (08:59:50.244) [IoT]: event_handler(167) > event_handler = 19
I (08:59:54.216) esp_netif_lwip: DHCP server assigned IP to a station, IP is: 192.168.4.2
D (08:59:54.217) event: no handlers have been registered for event IP_EVENT:2 posted to loop 0x3ffc0044
D (08:59:54.224) event: running post SYSTEM_EVENT:19 with handler 0x400f9520 and context 0x3ffc00dc on loop 0x3ffc0044
I (08:59:54.235) [IoT]: event_handler(167) > event_handler = 19
D (08:59:56.417) MAIN: Current minute: 539, test time: 193
I (09:00:04.546) esp_netif_lwip: DHCP server assigned IP to a station, IP is: 192.168.4.2
D (09:00:04.547) event: no handlers have been registered for event IP_EVENT:2 posted to loop 0x3ffc0044
D (09:00:04.554) event: running post SYSTEM_EVENT:19 with handler 0x400f9520 and context 0x3ffc00dc on loop 0x3ffc0044
I (09:00:04.565) [IoT]: event_handler(167) > event_handler = 19
I (09:00:05.553) esp_netif_lwip: DHCP server assigned IP to a station, IP is: 192.168.4.2
D (09:00:05.553) event: no handlers have been registered for event IP_EVENT:2 posted to loop 0x3ffc0044
D (09:00:05.561) event: running post SYSTEM_EVENT:19 with handler 0x400f9520 and context 0x3ffc00dc on loop 0x3ffc0044
I (09:00:05.571) [IoT]: event_handler(167) > event_handler = 19
W (117551) wifi:<ba-add>idx:4 (ifx:1, a6:23:1c:3a:60:cd), tid:0, ssn:2, winSize:64
I (09:00:10.322) [IoT]: _iot_easysetup_gen_get_payload(177) > waiting.. response for [0]
I (09:00:10.322) [IoT]: _do_iot_main_command(499) > curr_main_cmd:10, curr_main_state:1/1
I (09:00:10.329) [IoT]: _do_state_updating(1646) > Notification only with IOT_STATE_PROV_CONN_MOBILE
I (09:00:10.339) [IoT]: _do_status_report(304) > Call usr status_cb with 2/4
D (09:00:10.346) DEV_CTRL: status: 2, lv: 4. State: PROVISIONING_CONN
I (09:00:10.354) [IoT]: http_msg_handler(421) > get cmd[0] ok
I (133701) wifi:station: a6:23:1c:3a:60:cd leave, AID = 1, bss_flags is 658547, bss:0x3ffd5934
I (133701) wifi:new:<1,0>, old:<1,0>, ap:<1,1>, sta:<0,0>, prof:1
W (133701) wifi:<ba-del>idx
D (09:00:23.549) event: no handlers have been registered for event WIFI_EVENT:15 posted to loop 0x3ffc0044
D (09:00:23.558) event: running post SYSTEM_EVENT:18 with handler 0x400f9520 and context 0x3ffc00dc on loop 0x3ffc0044
I (09:00:23.569) [IoT]: event_handler(157) > station:a6:23:1c:3a:60:cd leave, AID=1
I (09:00:23.578) [IoT]: _iot_easysetup_wifi_event_cb(95) > Station left from SoftAP
I (09:00:23.586) [IoT]: _do_iot_main_command(499) > curr_main_cmd:10, curr_main_state:1/1
W (09:00:23.595) [IoT]: _do_state_updating(1711) > Iot-core task will be stopped, needed ext-triggering
I (09:00:23.605) [IoT]: http_cleanup_all_connection(39) > close listen socket
I (09:00:23.613) [IoT]: http_cleanup_all_connection(46) > close accept socket
I (09:00:23.621) [IoT]: es_http_deinit(184) > http tcp deinit complete!
I (09:00:23.628) [IoT]: iot_easysetup_deinit(566) > IOT_STATE_PROV_ES_DONE
I (09:00:23.635) [IoT]: iot_bsp_wifi_set_mode(234) > iot_bsp_wifi_set_mode = 0
I (133801) wifi:mode : null
D (09:00:23.646) event: running post WIFI_EVENT:3 with handler 0x400fa9ec and context 0x3ffc22f4 on loop 0x3ffc0044
I (09:00:23.647) [IoT]: _do_status_report(304) > Call usr status_cb with 1/0
D (09:00:23.656) esp_netif_handlers: esp_netif action stopped with netif0x3ffd22a0 from event_id=3
D (09:00:23.664) DEV_CTRL: status: 1, lv: 0. State: IDLE_STATE
D (09:00:23.677) event: running post SYSTEM_EVENT:3 with handler 0x400f9520 and context 0x3ffc00dc on loop 0x3ffc0044
I (09:00:23.682) [IoT]: _do_update_timeout(200) > Current timeout : 4294967295 for -1/-1
I (09:00:23.691) [IoT]: event_handler(112) > SYSTEM_EVENT_STA_STOP
I (09:00:23.701) [IoT]: _do_status_report(295) > Unsupported state -1 for 0/0
D (09:00:23.707) event: running post WIFI_EVENT:13 with handler 0x400fa9d4 and context 0x3ffc23a4 on loop 0x3ffc0044
D (09:00:23.724) esp_netif_handlers: esp_netif action stopped with netif0x3ffd3680 from event_id=13
E (09:00:23.733) [IoT]: st_conn_start(1908) > Can't go to PROV_CONFIRM (0x2)
D (09:00:23.734) event: running post SYSTEM_EVENT:16 with handler 0x400f9520 and context 0x3ffc00dc on loop 0x3ffc0044
I (09:00:23.741) [IoT]: st_conn_start(1910) > st_conn_start done (-7)
I (09:00:23.757) [IoT]: event_handler(140) > SYSTEM_EVENT_AP_STOP
W (09:00:23.765) MAIN: fail to start connection. err:-7
Hi!
I talked to the team again and they mentioned that the version of the app for iOS 15.4 has this issue. It will be solved in the next release of the ST app (as a reference: 1.6.85). There’s no ETA yet on its release.
