Exclude Ecolink z-Wave Tilt Sensor
I had a SmartThings hub and installed this Model: TILT-ZWAVE2.5-ECO garage door tilt sensor. It worked well. I had to replace the Aeotec SmartThings hub. However, I forgot to exclude the tilt sensor before the hub exchange. How can I exclude/factory reset the tilt sensor before I try to add it/include it on the hub? Or must I buy a new one and discard this one? Currently when I add the battery the light goes on but does not blink. If I put the cover on the light goes out.
No need to buy a new sensor. You can exclude it from the new hub. Find the hub in the ST app and open it, tap on the 3 dots, tap on Settings and select z-wave utilities. Put the hub into exclusion mode, bring the sensor within 10 feet of the hub and do the procedure on the device to complete the exclusion process. Or you can use the Advances Web App to run exclusion, go to the hub section, tap on your hub name and exclude.
Took the 1st option and it worked the 1st time around. I also checked out the advanced option as well without messing with it of course.
Thank you so much for that answer! Kudos!
