Hi all,
Just purchased an Ecolink garage door sensor and tried pairing it to ST, I am facing the following problems:
To add the device, I clicked the ‘+’ icon, chose the “Ecolink Garage Door Tilt Sensor” and started the pairing/discovery process. During pairing, ST starts checking for a “3-way axis device”, detects the tilt sensor, but the message I see is “A new device was added but it was not the correct type”. The tilt sensor gets added anyway as a Z wave switch, but I can see the tilt sensor works correctly. Anyone else having any such issues?
Once in a while, I also see the red LED keeps on glowing for an arbitrary time (usually > 10 seconds). During this time, open/close status of the doors is not indicated correctly. Not sure if this indicates a range issue, or I have a damaged sensor. Any thoughts?
I’m having the same problem. I noticed when I choose Ecolink Tilt Sensor when adding the Thing, it looks right in the Add Thing menu, but when I get into the screen to add it, the image showing in the screen where you hit Connect Now is for a SmartThings MultiSensor. Perhaps there’s something wrong in that dialog?
@artworx@bmoffett I added it as a SmartThings MultiSenseor, and then changed it in the IDE (ide.smartthings.com) to a “Z-Wave Door/Window Sensor”. Works perfectly now. Alternatively, you could also just ask support to change the type to “Z-Wave Door/Window Sensor”.
Have not tried a ST Multisensor as a garage door sensor (I do own a whole bunch of them, so i can test and report back).
@bmoffett Have you tried putting the ST hub in exclusion mode, excluding the sensor, and then re-adding the sensor?
I had a similar issue with Monoprice sensors earlier which got resolved this way.
I actually purchased EcoLink wireless door window sensor and it hooked up perfectly and easily. Mounting it on the garage door is still a challenge but hope to mount it soon. I found someone mounting it with wood blocks but I plan to use garage mounting brackets. Hopefully it will work. After that I want to figure out how to automatically open when I arrive in the neighborhood. Anyone have ideas on that.
I got a replacement and it works just fine. A few instances where a false signal came through, but I haven’t had time to investigate. I’m planning to put a camera in the garage so I have a way to detect false signals.
Anyone else get false signals from their Ecolink Garage Door sensor?
If so I might just use a normal Ecolink door/window sensor on my garage door, I found a good / easy place to mount one.
@bmoffett Maybe adjust the angle on the tilt switch itself.
Thanks, because of the false alarms I will probably just use the normal Ecolink door/window sensor on the garage door. If you get a false alarm you might try adjusting the angle of your ball switch.
I made a small angle bracket that attaches to the top of the door to hold the switch approx 3" higher than the top edge of the door (just high enough so the door does not hit the 2nd half of the switch which is mounted on the wall above the door).
I use the same sensor. You will have to go into the IDE and add the capabilities that are on the multisensor to the device type metadata of your tilt sensor. Then it will let you add it as a garage door metadata {
// Automatically generated. Make future change here.
definition (name: “Z-Wave Door/Window Sensor Garage”, namespace: “smartthings”, author: “SmartThings”) {
capability “Three Axis”
capability “Contact Sensor”
capability “Acceleration Sensor”
capability “Signal Strength”
capability “Temperature Measurement”
capability “Sensor”
capability “Battery”
