I had to replace my ST Hub and being the old one died after I included these two switches I can’t figure out how to re-add them to my network. The manual just gives instructions for excluding them with the use of a mote or controller.
There is a forced exclude (also called “general exclusion”) that can be used for any Z wave device. It is under Z wave utilities. Support@smartthings.com can help you if you get stuck.
Once you have done the exclude, then do a factory reset on the device. After that you should be able to include it to the new hub.
Thank you very much!!!
