Anyone know if it’s possible to use the Everspring ST815 Illumination sensor?
If I had to guess I’d say it would… but personally, I’d look at the Aeon Motionsensor first if I were you. It’s only a little bit more expensive and it includes motion, temp, humidity, as well as illumination.
Thanks Chris. When I detect the Everspring, it seems to only detect temperature and moisure elements and not illumination. Maybe I’ll just ditch it and try the Aeon as you suggested.
I’ve got two of them and they definitely report on illumination.
@chrisb - what device type are you using to pair your Everspring ST815 with Smartthings?
