Everspring ST814 as an alternative temperature sensor?
Has anyone had any experience using an Everspring ST814 for temperature and humidity control?
Minollo,
Yes, I use these. See this post.
Jim
i cant for the life of me get my ST814 to send data to ST, it connects and shows up in ST as a smartsense moisture sensor, but no readings ever show up, any advise?
Jim,
How did you connect it to the ST hub? I just got one and when I try to connect the SmartTHings app just says ā€œIdentifying 1 deviceā€ and hangs forever. I asked support and they said:
We don't have a dedicated device type created for the Everspring temperature sensor so I don't think it will work I'm afraid. Sorry about that. I will flag for our hardware team so they can get something put together.
Unless you can tell me your trick, I’ll need to send it back. I thought I had seen it on the list of supported devices but it’s not there …
thanks
This one has eluded me as well. I changed the device type per what Jim had mentioned but mine doesn’t give any meaningful data to ST. I’d be willing to create a device type for this but I haven’t been able to find guidance on where to see the data that is coming from the device. The ā€˜raw data’ displayed in the IDE doesn’t appear to be the least bit similar to the codes in the thermometer documentation.
Anyone solve/figure this one out?
Also, are there literally NO other options out there that doesn’t cost us $50/ea.? This one, the Multi, and Aeotech’s are all around this pricepoint. Ideally, I’d like a sensor in every room, but not looking to shell out $500+.
Wasn’t Aeotech coming out with something without the motion/illumination (which should drive the cost way down AND the physical size of it)?
