My EVA Logic Z-Wave plug always turns on at 1% dimmer setting no matter what I set it to previously. It won’t remember the last setting. Its been working fine for months until today. Any ideas on how to fix this? I’m assuming its an edge driver issue.
Tagging @philh30 who has worked with this issue for some other brands.
Do you know the name of the edge driver that it selected?
It says Z-Wave Switch
2022-12-20
What I’ve seen before is Jasco dimmers coming on at 100% every time they were turned on by z-wave. In that case, the old DTHs we’re sending a Basic:Set command for on/off, which the device interpreted as “turn on using default device settings”. The default libraries for Edge drivers now try to use the most complex on/off command supported by the device, and only fall back to a Basic:Set if nothing more complex is supported. The more complex z-wave commands override the device’s default behavior, which causes the undesirable results. The fix was a custom driver for those devices that sends Basic:Set for on/off.
If yours are coming on at 1% instead, it’s possible that it’s the same root cause but different behavior since it’s a different brand.
