Hi, I tried researching this error and I found that it is not something I can fix and that I might of caused it by modding a DTH. I did try using an incognito tab but no dice. This error came about as I was trying to add a smartapp (Echo Speaks) from the repo on the IDE page. I entered a support ticket (#979457) but maybe someone has a suggestion since it might take a while for me to get a response. Thanks!
Were you logging in at https://account.smartthings.com?
Is your hub assigned to a room in the new app?
Thank you for replying. Yes, I am logging into https://account.smartthings.com and my hub is assigned to a room in the new app. Should I remove it from the room? Thanks again for your help.
definitely not
Ok. From what I read I might have to wait for the device causing the problem to be removed by support. Thanks!
