[edge] Zemismart Tuya Zigbee blind motor
OK. It seems that your device packets are similar to those of other Zemismart blind motors with battery.
I’ve modified the Edge driver to work with your device.
It will be applied to your ST hub in several days.
If you want to apply the changes right now, then you may want to delete and reinstall the Edge driver.
Thanks, I will test it when my hub gets updated and will report the results.
Update: Fantastic the driver works very well
Do we get those drives by default or do i have to enroll?
You need to enroll.
Hi everyone,
@iquix : I have 5 of these motors using your original DTH for Tuya Window Shade (v.0.1.0). My motors fingerprint is this:
fingerprint endpointId: “0x01”, profileId: “0104”, inClusters: “0000 0004 0005 EF00”, outClusters: “0019, 000A”, manufacturer: “_TZE200_gubdgai2”, model: “TS0601”, deviceJoinName: “Zemismart Vertical Blind” // M515EGBZTNv2 or TM616EGBZTN
Would your EDGE driver work with this motor? I have model M515EGBZTNv2.
If so, I would I go about adding this fingerprint to your driver?
Thank you.
Pair the device with “Zigbee Thing” driver from the SmartThings Official Edge Beta channel,
and then change the driver to “Tuya Window Shade” from the DetailView of SmartThings app.
Where do I find the “Detail View”? I have the Driver set as “Zigbee Thing” in the Driver Screen. But I have no idea were to fine this “DetailView”. The only other available installed driver is “Zigbee Thing [YG] v1.0.2”. Do I need to install your channel to gent the “Tuya Window Shade” channel?
Could you add this device ?
Refer to How to use the custom Edge Driver: section from the document below.
Thanks iquix, but these are the only two other available dtivers and neither of them work. I need to find a compatible driver but I do not think one has been developed. I’ve searched the forums and asked for help on this site to no avail :face_exhaling:
You have to install ‘tuya window shade’ edge driver from my channel to your hub.
https://bestow-regional.api.smartthings.com/invite/qWjB0pNyY62y
Then, you can find the driver from the driver switching menu in the detailView.
Many thanks Jaewon. This worked wonderfully! I really appreciate your help on this!
You have any update?
Great work Jaewon, the Tuya app shows % of battery left on the rechargeable battery any chance of incorporating that feature in your driver.
Thanks again.
I have a tuya wireless motor in my house, but it never displays battery info in the tuya app. Also, I have never seen the battery packet sent from the device in the live log of the ST hub.
Hello Jaewon, here are 2 screenshots from the product description of my ZigBee roller blind from Zemismart maybe that particular model might have the power show option.
so, i purchased the zemismart curtain track zigbee system, is there a specific way to integrate these into smartthings with a new edge driver? im not having any luck, its appearing as a thing device and im not able to change the driver because of this.
Hi there, the first thing was to install from Yakov’s channel the beta edge drivers,[ST Edge/Beta] Xiaomi/Aqara/Tuya zigbee sensors driver , select and install the Thing driver from his list , finally install from Iquix’s chanel which we will find in the current thread his curtain edge driver and then you can change driver in order to use the driver you have just installed.
I will be removing the smart blinds from my SmartThings hub for 2 specific reasons and use a Tuya hub, first my blinds are zebra blinds and when I set my limits with the remote the limits are not fully transported in Iquix’s driver, there is preset position in the setting menu which doesn’t work for my blinds and secondly my motos are able to report battery capacity left by using the Tuya app which I find is very important for my needs.
Thanks! I finally got the right driver to start with and switched to yours right after. I see the shade motor in my devices now! When I click the device icon, I see basicHtml with device data, but no way to activate the shade motor. I see “Standby” under momentary. Should I see anything like “Up,” or “Down?”
Thank you @iquix. With your new driver, I can finally ask Alexa to open my blind (M515EGBZT) to, or by any %
Happy days :smiley:
Edit: I can now remove the device handler from the SmartThings IDE website, right?
Thanks.
