Great news! ![]()
Thanks @mocelet
Great news! ![]()
Thanks @mocelet
I didn’t go into details of the triple-tap hack but it works in a different way for the release firmware (Matter 1.3) and the new 1.9.15 update (Matter 1.4).
For the curious, the button does not report the third press in any way so the hack relies on other events (or lack of) as a hint that you pressed it three times. Hints are not 100% error-proof but there are extra checks in place and there are better hints now:
Assuming there are no bugs in the new firmware, the triple-tap is now both faster to trigger and way more reliable with virtually no false triple-taps.
Hi,
Is it possible to dim lights with the regular Bilresa remote - the one without the steering wheel?
Yes, a generic way would be enabling the Auto-Repeat Held in settings, that will make the button repeat the Held action while pressed. With that, you can pick as Held action the “Adjust brightness 10%” for instance of your light, resulting in the light dimming proportionally to how much you’ve pressed it.
Not all SmartThings lights offer the adjust brightness option, if it doesn’t you’ll have to use a virtual dimmer with steps.
Thanks for the response. For some reason j dont have the adjust brightness setting so I’ll see if I can do something with a virtual dimmer switch
So far SmartThings only added the Adjust Brightness action to ZigBee and Matter lights so I assume yours are not. It’s not available for groups, cloud connected lights, etc. I would request that to support so they prioritize it, it’s a half baked feature right now.
If you don’t want to install more drivers you can create routines but it’s going to be cumbersome “if button 1 Held precondition brightness less than or equal to 10% then brightness 20%” and so on.
Then it should have the Adjust brightness action next to the Dimmer of your screenshot.
Is it using the stock Zigbee Switch driver? In that case it’s something SmartThings has to fix since, also, your light supports both colour and colour temperature and those don’t appear either in your screenshot.
Could you consider adding an optional “return to Group 1 after idle” feature for BILRESA?
For example, after 30 seconds or 1 minute with no interaction, automatically reset the active group to Group 1.
I use Group 1 for lights, Group 2 for blinds, and Group 3 for PC power, so returning to Group 1 would make accidental actions much less likely.
Unfortunately that cannot be done, the group selector is not exposed to Matter or the smart home platform and there is no way to change the current group other than the physical button.
In the “official” IKEA subreddit some users suggested IKEA to expose the group as a Mode precisely for your use case but so far no news on it being considered.
