is there any way to increase or decrease the brightness of a lamp by clicking on the button several times?
For now I can only assign a fixed brightness level to each button. I want to increase / decrease the brightness each time I a tap a button.
i have the same issue with the same (?) dimmer that comes with the ikea smart blinds (I assume it’s exactly the same dimmer): “hold” works on the 5-button tradfri remote, but not with this square one…
There must be a reason for it. Probably the device is not capable of held, only push.
Otherwise, you asked in the other topic, the FYRTUR, or what ever it is called smart blinds are stock supported by SmartThings. Check the new app, add device IKEA section.
Hi I purchased 4 gu10 tradfri bulbs and the tradfri 5 button remote. How on earth do I get the bulbs to dim up and down like a standard dimmer? Also is there no held option for the centre button?
Download and install the ABC Advanced Button Controller SmartApp, and set up the buttons the do brightening and dimming steps on press or hold. What ever you want. The SmartApp might crashes in the new SmartThings app, so it is advised to install it in the Classic app.
Pair the remote with TouchLink to the GU10 bulbs. (It works for me with the E27 bulbs). Pair all bulbs and the remote to the Hub, and make sure events are recorded when buttons pressed and help. Then move the 5 button remote close to one of the bulbs and hold the pairing button on the back, until the bulb dims and flashes once (as far as I can remember). Then try the dimming and on/off on the bulb, it should work now.
Carry on adding the other bulbs to the 5 button remote with the TouchLink method.
It is advised to remove the power from the other bulbs meanwhile pairing to one at the time.
I’ve paired them with the smart bulbs already and there back in the ceiling. Where would I get this app from please. Isn’t the centre button supposed to have a held operation as mine only has press.
