Is it configurable though? Apparently it needs a driver restart for the native handler to update the value and there are no settings to change it. So, for the user, it’s like if there was no configuration.
It’s better than not being able to change it though.
Edit: I’ve asked in the PR, hopefully a custom driver can trigger an update to change the time without restarts. That would be the ideal scenario. I was going to test it but looks like current hub firmwares don’t have the native handlers, will have to wait till next beta! (…) Confirmed, no restart needed so I’ll update the native handler with the current preference of Matter Playground when they release the feature
From the description of the PR:
there may be opportunity / need to alter this value in the future.
By the way I had to factory reset the BILRESA scroll again today, at least the Control devices by rotating option made it less traumatic, no rules to modify. (Edit: just forgot about the new Update routines feature, I should have used that instead of setting the actions again!)
They need a firmware update “pronto”, I know there’s a test version available but didn’t install it, so at least IKEA is working on fixing the issues.
I bought 2 BILRESA scroll wheel… spent last 6 hours trying all possibles things with them. Stock and your driver..
In the end I don’t now what to say…
It’s a fuc… lottery!!! work fine, work very well, don’t work, sleep for too long, sleep forever… it broke my nuts!!! It’s a lovely small button with a lot of possibilities… It will be a most wanted when will be truly reliable for use…
Just one question… how can I update firmware without IKEA hub or without home assistant?
(PS: I bought too Bilresa dual button and I conclude that they have not the reliability of RODRET…)
My next step will be expand/update my thread network. I hope that will be the solution to stabilize the buttons response…
Do you know if using ikea hub they work truly fine???
There are no updates for the buttons yet, when they release you’ll be able to update them with SmartThings.
The IKEA hub is not needed, mine is in a drawer actually.
My experience is not so bad though, the dual button has been great. The scroll is sometimes annoying, especially if you play too much with it.
In my environment Rodrets have fastest and more reliable response… What tips can you give me to workaround???
RODRET has no double-tap (unless you emulate it with my driver) and that makes the single press faster. With BILRESA if you don’t care about the double press or can figure out a compatible automation you can use the optional events (initial press and short release) that trigger before the “Pressed”. I use the “Enable Short Press Release” which will show up as “Swipe up” action before Pressed. You’ll see that event is faster, but will trigger twice in a double press.
As for reliability, nothing really, strenghen the Thread network, don’t add them to multiple platforms or just wait for IKEA to update the firmware. But I don’t remember realiability issues with the dual button. The scroll is more picky and sometimes bricks itself.
Any chance to change select ‘sector’ with routines??
What do you mean? The scrolled sectors is a way to know how much you scrolled at once to trigger different actions with a single gesture. For instance, if you rotate it a little do something, if instead you rotated more it does a different thing.
If you mean changing the active group with routines, that’s not possible since there’s no interface for that.
It’s not that… I mean the selector group…
Yeah, just edited my response, it’s not possible.
New version 2026-04-27
Settings for BILRESA scroll have received a makeover with a couple new features and editorial changes to stay in touch with the new “Control devices by rotating” actions of the app.
- Reverse scrolling direction is a new option so the scroll is inverted (left is right), quite useful if you use the wheel upside down like under a desk or desk chair! Fun fact, the magnet is strong enough to be under some areas of a IKEA MARKUS chair without falling.
- Scrolling modes is now called Swipe Left / Right triggers and there is a new option to disable those events entirely if you prefer or if you only use the new “Control devices by rotating” action.
- Disable heldRotate is now called Disable press+rotate.
Always progressing…
Little details make uge steps to satisfy necessities of all kind of users…
Even if I don’t use now or if I don’t need it, make me comfortable to know is there if I will need it…
Good work![]()
Just an update:
I put another aeotec hub(not mine) in the room where I use the buttons. Join them… And… They’re(buttons) working very well…
I confirm now the problem was a poor thread network…
Maybe just a router thread device like a switch or plug in the room do the same as the Hub… Will try…
You may want to use the new Thread Diagnostic app.
It eliminates much of the guess work, and money wasted, when setting up your thread topology.
The first firmware update for BILRESA dual button has arrived, version 1.9.15, just released!
- It bumps Matter version to 1.4 and probably improves stability in multi-admin scenarios.
- The triple-tap hack takes advantage of Matter 1.4 and works better now, more especifically it will feel like a native triple-tap with no extra delay.
- The battery reporting is still weird and reports 45% for fresh NiMH batteries whereas a MYGGSPRAY would report 90%.
Regarding the battery, for the initial version the driver would double the figure but for the new version I’m not sure what to do. It’s probably better to report what the device reports even if it’s wrong, maybe they adjusted the percentages for alkalines instead of NiMH or it doesn’t pretend to be an exact figure anyway.
When you update the button you’ll see your battery reading drop, just ignore it, it’s just that now displays what the button reports instead of the driver trying to correct the figure.
NiMH batteries have a nominal voltage of 1.2V per cell. When fully charged, they often read around 1.4V to 1.5V immediately after coming off the charger, though this settles to roughly 1.2V–1.3V during use. They are considered discharged at approximately 0.9V to 1.0V per cell
An alkaline battery (such as AA, AAA, C, D) has a nominal voltage of 1.5V. Fresh, unused alkaline batteries typically measure higher, often between 1.58V and 1.6V. As they are used, this voltage drops consistently, with most batteries considered dead when they drop below 1.2V to 1.3V
Probably mapping is different for each device
Yeah, but it doesn’t add up, also BILRESA battery reports are erratic with weird spikes over time, maybe it’s just a faulty hardware affecting BILRESA.
I’ll have it in observation with the uncorrected values, as long as it does not trigger a wrong low-battery warning I’ll let it stay. And if someone from IKEA can confirm what kind of mapping they are using I can add a correction for NiMH that is more realistic.
New driver version 2026-05-09
- Improves reliability of triple-tap hack when used with the new firmware version of BILRESA dual button 1.9.15. I’ve never got a false positive, i.e. a triple-press that should have not triggered, but now I would say it is virtually impossible. Maybe eventually IKEA will add actual triple-press support to the dual button (like the scroll wheel has) but meanwhile the hack seems to be working fine.
- Removes the battery reading correction of BILRESA for any firmware version and model. Now you’ll see what the device reports which sometimes is way lower than real, especially with NiMH batteries. I guess IKEA did not consider that a bug despite all their other devices reporting more realistic values for the same batteries.
