I’m looking at this in the advanced section, but it’s not apparent to me how to display existing codes for the locks. Could you please elaborate on how to do this?
Whether you can see the actual codes already in the lock is dependent on whether your lock supports S2 security and your lock is paired properly with it. When the driver requests the codes from the lock, locks supporting S2 send the codes and can then be decoded by the driver and displayed in the mobile app. If the lock is not properly paired or doesn’t support S2, then the codes are obfuscated since they would be unencrypted and possibly sniffed.
There is nowhere in the Advanced Web App where the actual lock codes would be displayed. Only the codeSlot numbers and any codeNames associated with a slot as @mlchelp mentioned.
Universal Enhanced Z-Wave Plus Lock Driver - v20240122
- (New) Added support for additional lock models/brands (see first post)
- (Fix) Update for new HubCore firmware
Please make sure that your lock is within 20ft of a buffering device/repeater for best performance and reliability.
NOTES
- This version of the enhanced driver is only available via the new platform Drivers license (refer to website for details). If you have an active subscription, the new driver will be automatically pushed to your hub within 24 hours
- Refer to the previous release notes for more driver details. New features are not available in the Legacy Migration drivers.
- See the first post for a full list of available features by lock/model
Copyright (c) RBOY APPS
Since your lock supports these features it means that your lock isn’t responding to requests from the hub to discover / activate these features. Thta usually means there’s interference or packet loss in the mesh. See this topic for more details on how to resolve it:
Universal Enhanced Z-Wave Plus Lock Driver - v20240127
- (Fix) Some KeyWe locks reporting unlocked after being locked
NOTES
Universal Enhanced Z-Wave Plus Lock Driver - v20240221
- (Fix) Update for new hub firmware
- (New) Support for additional lock models
NOTES
Steal deal - $46 for a Yale Zwave Deadbolt - get it while it lasts.
If only it wasn’t brass!
I have this one in brushed nickel. It’s been very dependable. I’ve had it for 3 years with no issues.
It’s $39 today when I checked…
Still $40 US today.
Universal Enhanced Z-Wave Plus Lock Driver - v20240315
- (Fix) Latest SmartThings mobile app has changed how the UI lists programmed user codes. See the FAQ page for details on how to view the programmed codes
- (Fix) Not being able to rename users when overwriting existing slots
NOTES
- The latest SmartThings iOS mobile app now cuts off the text after the second line so not all user codes are visible. See the FAQ page for details on how to view the programmed codes
Thanks for making this visible again! However, this is the WORST. I hope SmartThings updates their app to make this more user friendly.
Where i used to see the list of users and lock codes, I only see HTML code now
Wow, just noticed a similar issue with @TAustin’s PurpleAir driver on the “sensor sites used.” What a mess.
Any idea if or when they are going to fix the UI on the mobile app to display all users and codes again?
If enough users ask them I don’t see why they won’t. They need re-enable HTML on tiles and re-enable expanding tiles. They’ve cut off both these features in the latest updates. Put in a ticket to support.
It’s VERY frustrating because it was working perfectly, supported html and the tile would expand to fill up all the text. I don’t know why they went backwards and disabled both features.
Can you point me in the right direction to do that?
Yup; this messes up a few of my drivers that use html tables to display info. ![]()
