[EDGE] Official Zooz Edge Drivers Channel
This is the Official Zooz Edge Drivers Channel for Zooz Products.
The channel has not changed, just a new person doing updates to the existing channel.
Since I am now updating these drivers for Zooz and I cannot edit the original post, I am starting a new post for the channel. Mark this thread as Watching to be notified of updates.
Original Thread: [OBSOLETE] Zooz Edge Driver Channel
:white_check_mark: Supported Devices:
Supported Devices List
  • Zooz Switch
    • Zooz ZEN21 On/Off Switch
    • Zooz ZEN22 Dimmer
    • Zooz ZEN23 Toggle Switch
    • Zooz ZEN24 Toggle Dimmer
    • Zooz ZEN26 S2 On/Off Switch
    • Zooz ZEN27 S2 Dimmer
    • Zooz ZEN53 DC Motor Controller
    • Zooz ZEN54 0-10V Dimmer
    • Zooz ZEN55 DC Signal Sensor
    • Zooz ZEN71 On/Off Switch
    • Zooz ZEN72 Dimmer
    • Zooz ZEN73 Toggle Switch
    • Zooz ZEN74 Toggle Dimmer
    • Zooz ZEN76 S2 On/Off Switch
    • Zooz ZEN75 Heavy Duty Switch
    • Zooz ZEN77 S2 Dimmer
  • Zooz Multichannel Switch
    • Zooz ZEN14 Outdoor Double Plug
    • Zooz ZEN20 Power Strip
    • Zooz ZEN25 Double Plug
    • Zooz ZEN30 Double Switch
  • Zooz Plugs
    • Zooz ZEN04 Smart Plug
    • Zooz ZEN05 Outdoor Plug
    • Zooz ZEN06 Smart Plug
    • Zooz ZEN15 Power Switch
  • Zooz Relay
    • Zooz ZEN51 Dry Contact Relay
    • Zooz ZEN52 Double Relay
    • Zooz ZEN57 240v XS Relay
    • Zooz ZEN58 LV XS Relay
    • Zooz ZEN78 High Power Relay
  • Zooz Siren
    • Zooz ZSE50 Siren & Chime
  • Zooz Multisensor
    • Zooz ZSE11 Q Sensor
    • Zooz ZSE18 Motion Sensor
    • Zooz ZSE29 Outdoor Motion Sensor
    • Zooz ZSE40 4-in-1 Sensor
    • Zooz ZSE43 Tilt | Shock Sensor
    • Zooz ZSE44 Temperature | Humidity Sensor
  • Zooz Scene Controller
    • Zooz ZEN32 Scene Controller
    • Zooz ZEN35 Dimmer & Scene Controller
  • Zooz Range Extender
    • Zooz ZAC38 Range Extender
  • Zooz RGBW
    • Zooz ZEN56 RGBW Dimmer
  • Zooz Button Remote
    • Zooz ZEN34 Remote Switch [1]
    • Zooz ZEN37 Wall Remote
  • Zooz ZEN16 MultiRelay
  • Zooz ZEN17 Universal Relay
  • Zooz ZAC36 Valve Actuator
  • Zooz ZSE41 XS Open Close Sensor
  • Zooz ZSE42 XS Water Leak Sensor
:inbox_tray: Installation:
  1. Go to the Zooz Edge Driver Channel
  2. Log in with your Samsung/ST account
  3. Enroll your hub in the channel
  4. Click Available Drivers [2]
  5. Click the Install button next to each Driver you want to install
  6. Wait a few minutes for it load on your hub
  7. Join the device -OR- Switch existing device
  1. After inclusion has finished and you test the buttons, tap the upper paddle 7x to force it to run a wake up ↩︎
  2. If you still see the “Enroll” button then try clicking it again and if that doesn’t work load the page using the original invitation link again ↩︎
Here are the changes in all my updates so far
UPDATE: Zooz Switch v2025-03-05
Full Details
Goal was to get all the ZEN7x switches and dimmers current on features and settings, along with standardizing all the settings names and descriptions per Zooz specs. You will see more detailed info for each of the settings than prior versions.
The toggle switches will show LED commands now. The LED is mostly hidden but they are visible in a dark room depending on your wall plate.
v2025-03-05 Zooz Switch - Version: 2025-03-06T03:14:21.729465523
  • ZEN71 / 73 / 76 switches - added profile 3 for firmware parameter changes
    • added parameters 7, 18, 19 to applicable profiles
  • ZEN72 / 74 / 77 dimmers - added profiles 4,5,6,7 for firmware parameter changes
    • added parameters 7, 20, 31 ,32, 33, 34 to applicable profiles
  • ZEN73 / 74 - Added led mode, color, brightness commands that others already had
  • ZEN71, ZEN72, ZEN73, ZEN74, ZEN76, ZEN77
    • Verified and updated all profile min/max versions based on changelogs
    • Updated all settings name, descriptions, and options per specs from Zooz
    • Added support for native firmware version capability
    • Removed firmware from details, tap … Information to see firmware version
UPDATE: Zooz Switch v2025-03-14
NEW PRODUCT: Zooz ZEN75 Heavy Duty Switch 800LR
Full Details
v2025-03-14 Zooz Switch - Version: 2025-03-15T00:13:05.105635945
  • Added support for new ZEN75 Heavy Duty Switch
UPDATE: Zooz ZAC36 Valve Controller v2025-03-14
Full Details
This is an exciting update for you all, bringing this driver up to speed with all the devices features. This unlocks some new potential with this driver when you have the battery backup added to the device. Not only can you see the battery status but you could also use the power status as a power outage indication!
v2025-03-14 Zooz ZAC36 - Version: 2025-03-15T00:23:33.565735135
  • Set up profiles 3 and 4 for new firmwares
  • Added parameters 45, 52, 81-86, 100, 113-115 to applicable profiles
  • Verified and updated all profile min/max versions based on changelogs and notes
  • Added battery capability to firmware 1.13 and up
  • Added powerSource, and chargingStatus capabilities to firmware 1.19 and up
  • Added feature to switch profiles when no battery so extra capabilities are hidden
UPDATE: Zooz ZSE42 Water Sensor v2025-03-25
Full Details
v2025-03-25 Zooz ZSE42 - Version: 2025-03-26T02:28:25.700363876
  • Changed Wake Interval to be set at 6 hrs for quicker recovery from offline
  • More robust process to set and confirm wake interval
UPDATE: Zooz ZEN32 Scene Controller v2025-04-02
Full Details
This update fixes the issue where firmware 2.0 would get the default profile, missing newer settings. All applicable settings should now be available for all firmware.
v2025-04-02 Zooz ZEN32 - Version: 2025-04-03T00:25:12.103091754
  • Added parameter 27 for firmware >= 2.40
UPDATE: Zooz Switch (Power Meter Plugs) v2025-04-18
Brings the ZEN04 and ZEN05 current with features and settings.
Full Details
v2025-04-18 Zooz Switch - Version:2025-04-18T21:03:03.459961321
  • ZEN04 - added profile 3 for firmware 2.30
    • added parameters 14, 15; updated 5, 7, 8 for new firmware
    • fixed profile / presentation so Energy Reset can be used in routines
  • ZEN05 - added profiles 2, 3 for new hardware, firmware 2.0 - 2.10
    • added support for power monitoring
    • added parameters 9 - 18 to applicable profile
    • updated parameters 9, 11, 12 for firmware 2.10 (profile 3)
  • ZEN15 - minor profile updates to stay in sync with ZEN04/05
  • ZEN04, ZEN05, ZEN15:
UPDATE: Zooz Scene Controller v2025-04-24
NEW PRODUCT: Zooz ZEN35 Dimmer & Scene Controller
v2025-04-24 - Version: 2025-04-24T21:40:27.509238514
  • Added support for ZEN35 Dimmer Scene Controller
Is the driver channel the same as the original one from 2022, or do we need to change to a new channel?
You can check in the edits of the old post that the link is exactly the same.
Same channel, I will clarify in my post above.
For the zooz zen14, we changed the settings to include child devices, but we can’t actually go into them. It just says loading.
I have actually not touched or used the Multichannel Switch driver yet, so I am not really sure what the issue would be. You might have better luck reaching out to Zooz, unless someone else in this community has more knowledge on it than me.
I just wanted to report that it seems none of my ZEN04 or ZEN15s are working today to turn on or off while using the ZOOZ driver for them. They still report statistics fine but they won’t turn on or off by any means through SmartThings/alexa connection. If I change them to the original SmartThings Z-wave driver it turns on and off fine but then don’t have most of the statistics.
I can’t say for sure how long this has been the case because my Zen04 and Zen15s are all just used for power monitoring mostly so they rarely ever get turned on/off. I only have one that is used primarily for on/off but it doesn’t get frequent use.
Not sure if it might be related to a driver update or if it’s some kind of SmartThings fubar with 3rd party drivers.
Edit: seems none of my devices that use the official Zooz drivers work for on/off. Had to hunt down which of my in wall switches were Zooz to test them too and they work with the regular SmartThings driver but not the Zooz one. Haven’t noticed any problem with any of my Zooz sensors. Just on/off for switches and plugs so far.
I have an OG v2 hub and have been using the official Zooz drivers since SmartThings swapped over to edge drivers, pretty much.
Just tested it with a ZEN05 fw 2.10 and it works fine for me. The entire switch driver uses the built in ST capabilities for on/off as well, so it should send the same commands as the built in driver.
Still no go for me with the Zooz drivers.
My ZEN15(all the older original ones if their hardware has been updated since then) are all FW 1.02(edit: one shows as 1.03)and my Zen04(the 800LR version since I think they had other hardware versions of the model at one point) are 2.2 according to what shows in the SmartThings app with the Zooz driver enabled to show the extra stats. The in wall switch shows as 20.15.
It’s weird that none of them work with the Zooz driver but work fine with the default ST Z-wave switch driver for on/off. But at least it rules out any sort of network issue on my end, I’d think.
I’ve got the newest iOS app update and with the Zooz driver from April for the respective devices, when I click on/off it does the little spinning then eventually pops up with the standard little, a network or server error occurred, error. Only showing up for my Z-wave stuff using a Zooz official driver. I do have some other 3rd party Z-Wave drivers for things like fan switches and they work fine too to make sure it isn’t just a 3rd party driver type of thing on my hub.
You could try uninstalling the driver then adding it back again. Otherwise not sure what would be causing it. All works fine here.
Reinstalling the driver worked. I thought about doing that originally but since the driver was dated from April, I knew some had worked since then so didn’t think it would be the cause but I guess maybe it pushes the driver updates to the hub slowly and only updated in the last month or two to probably corrupt the driver on my hub.
Just had to play whackamole to find my Zooz devices to change their drivers so I could do the uninstall.
I was thinking I remembered being able to see all of the devices that used a specific driver but couldn’t find it, if I was remembering correctly or if maybe that was from the old IDE days.
UPDATE: Zooz Relay v2025-07-28
NEW PRODUCT:
v2025-07-28 - Version: 2025-07-29T19:30:30.600233538
  • Initial release
  • NOTE: Input type 0 (automatic) does not work well with SmartThings so the default is being set to option 3 and 0 is not available. Supporting Water, Motion, and Contact for the extra sensor inputs only at this time.
I have had a heck of a time trying to integrate a ZEN17 into Smartthings. Over the last year I’ve uninstalled and reinstalled it several times, each time with an odd result. Currently I have separated the relays into separate devices to control and monitor a garage door. The device to control the door works but the contact sensor device does not. In fact, when that sensor is shorted manually, the device for the door control will show its relay as becoming closed. Now, the relay really isn’t closing because the garage door does not move.
Any help at fixing this would be greatly appreciated. I have the exact same setup on a Hubitat elsewhere and have had 0 issues with it.
After you change the settings for the input type, did you then exclude and include the device again? Do not factory reset. After including it again select your input type again. I would suggest the contact sensor input type (not dry contact). You can change the setting to separate the input from the relay before or after you exclude it.
UPDATE: Zooz Multisensor v2025-08-25
v2025-08-25 - Version: 2025-08-26T01:54:43.803281104
  • Updates for ZSE18, ZSE11, and ZSE44 Only
  • Added ability to handle power source changes (ZSE18, ZSE11)
  • Changed ZSE18 tamper alerts from Acceleration to Tamper
  • Fix to correct negative luminance values (ZSE11)
  • Added battery quantity/size information (tap > next to battery %)
  • Updated all settings names, descriptions, and options per specs from Zooz
  • Removed firmware from details (tap menu, Information to see firmware version)
UPDATE: Zooz Siren v2025-09-13
NEW PRODUCT:
v2025-09-13 - Version: 2025-09-13T16:04:44.559066511
  • Initial release
  • NOTE: Routines cannot be made to select a specific tone yet, still working on that feature.
Since this is a new driver package, follow the install instructions in the top post to get to the Available Drivers list, and then install this new driver to your hub.
Hey Jeff,
For the ZSE42, what do you think about enhancing the driver to show the battery level over time? Basically the same chart for the water sensor status.
Unfortunately that’s no longer possible in SmartThings.
SmartThings no longer keeps the battery history and the app won’t display the chart it used to display. Drivers can’t do anything about that.
I recently got the Zooz Zse50 Siren intending to use it with Home Monitor, however HM still shows “Sound Sirens: None Available”.
I can use it with routines but not as an alarm.
Is there any solution to this?
