[Edge] Edge Driver for Tuya Smart Knob Dimmer (TS004F)
I want to thanks @zambobmaz for developing and adding support for this device in his zigbee-tuya-button Edge Driver. Sharing here with the community on his request.
Channel invitation link
The device is this one:
Manufacturer code _TZ3000_402vrq2i
Model TS004F
Through several tests today, I have almost completed the implementation.
When the knob is directly connected to the device, brightness changes (like with a bulb) are smooth. However, when passing through the hub, there are some limitations.
I have created a new profile. As always, you need to delete and reconnect the device.
If the screen does not appear as shown in the attached image, please try again the next day. It seems to take some time for deployment.
If anyone on the SmartThings Community needs it, I would appreciate it if you could share it.
I am unable to post or comment because I have issues logging into the SmartThings Community.
Remote Mode:
• Push: Working
• Double Push: Working
• Long Push (Release): Working
• Knob: Working
• Knob Level: Device does not support
• Knob with hold: Device does not support
Scene Mode:
• Push: Working
• Double Push: Device does not support
• Long Push: Device does not support
• Knob: Working
• Knob Level: Working
• Knob with hold: Working
• Knob Level with hold: Working
I have added wheel and hold_wheel level. These values represent the angle the knob is turned.
• Turning clockwise increases the value.
• Turning counterclockwise decreases the value.
• The reference point is 50.
• This value is generated each time the knob is turned and is not accumulated from previous values.
More info:
