[Edge Drivers] Issue with Zigbee Switch driver (status in the app)
I switched 1of my ZBMinis over to your test driver and it seems to be working just fine.
I will try to get you logs later today.
Zigbee Switch Mc-Test is working perfect! Thanks you verry much! Will it stay or will you delete this afther time? becuse it says ‘test’ . or will it keep working if i do not touch it? Thanks a lot.
Hear are the ZBmini logs.
1 on & off using the app them 1 on & off using the physical switch. No problems noted.
2022-08-09T18:58:30.047261984+00:00 TRACE Zigbee Switch Mc-Test Received event with handler capability
2022-08-09T18:58:30.063692692+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> received command: {“args”:{},“capability”:“switch”,“command”:“on”,“component”:“main”,“positional_args”:{}}
2022-08-09T18:58:30.066978775+00:00 TRACE Zigbee Switch Mc-Test Found CapabilityCommandDispatcher handler in Zigbee_Switch
2022-08-09T18:58:30.080851234+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
2022-08-09T18:58:30.284267567+00:00 TRACE Zigbee Switch Mc-Test Received event with handler zigbee
2022-08-09T18:58:30.289222442+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5F6F, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -58, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x53, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2022-08-09T18:58:30.300048650+00:00 TRACE Zigbee Switch Mc-Test Received event with handler zigbee
2022-08-09T18:58:30.304568317+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5F6F, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -58, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x24, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2022-08-09T18:58:30.313284025+00:00 TRACE Zigbee Switch Mc-Test Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-08-09T18:58:30.316189317+00:00 INFO Zigbee Switch Mc-Test Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2022-08-09T18:58:30.319920567+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-08-09T18:58:30.331161109+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
2022-08-09T18:58:30.339552900+00:00 TRACE Zigbee Switch Mc-Test Received event with handler zigbee
2022-08-09T18:58:30.344125984+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5F6F, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -59, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x23, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int8, OnOff: true > > > >
2022-08-09T18:58:30.353722359+00:00 TRACE Zigbee Switch Mc-Test Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-08-09T18:58:30.356728984+00:00 INFO Zigbee Switch Mc-Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-08-09T18:58:30.359924692+00:00 PRINT Zigbee Switch Mc-Test value.value >>>>>>>>>>> true
2022-08-09T18:58:30.362767067+00:00 PRINT Zigbee Switch Mc-Test New value.value >>>>>>>>>>> true
2022-08-09T18:58:30.366027525+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“LQI: 255 … RSSI: -58 dBm”},“visibility”:{“displayed”:false}}
2022-08-09T18:58:30.382107567+00:00 PRINT Zigbee Switch Mc-Test <<<<<<< Power meter Timer >>>>> OFF
2022-08-09T18:58:30.389241234+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-08-09T18:58:30.399954067+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“power”,“capability_id”:“powerMeter”,“component_id”:“main”,“state”:{“unit”:“W”,“value”:80}}
2022-08-09T18:58:30.435294525+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
2022-08-09T18:58:30.442244192+00:00 TRACE Zigbee Switch Mc-Test Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-08-09T18:58:30.452535817+00:00 INFO Zigbee Switch Mc-Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-08-09T18:58:30.456308984+00:00 PRINT Zigbee Switch Mc-Test value.value >>>>>>>>>>> 1
2022-08-09T18:58:30.464162400+00:00 PRINT Zigbee Switch Mc-Test New value.value >>>>>>>>>>> true
2022-08-09T18:58:30.471773900+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“LQI: 255 … RSSI: -59 dBm”},“visibility”:{“displayed”:false}}
2022-08-09T18:58:30.489425567+00:00 PRINT Zigbee Switch Mc-Test <<<<<<< Power meter Timer >>>>> ON
2022-08-09T18:58:30.492730109+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-08-09T18:58:30.507655150+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“power”,“capability_id”:“powerMeter”,“component_id”:“main”,“state”:{“unit”:“W”,“value”:80}}
2022-08-09T18:58:30.532298984+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
2022-08-09T18:58:30.536952900+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
2022-08-09T18:58:32.742834817+00:00 TRACE Zigbee Switch Mc-Test Received event with handler capability
2022-08-09T18:58:32.763368067+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> received command: {“args”:{},“capability”:“switch”,“command”:“off”,“component”:“main”,“positional_args”:{}}
2022-08-09T18:58:32.772382026+00:00 TRACE Zigbee Switch Mc-Test Found CapabilityCommandDispatcher handler in Zigbee_Switch
2022-08-09T18:58:32.786591234+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
2022-08-09T18:58:32.903044567+00:00 TRACE Zigbee Switch Mc-Test Received event with handler zigbee
2022-08-09T18:58:32.908992817+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5F6F, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -59, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x25, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int8, OnOff: true > > > >
2022-08-09T18:58:32.968564734+00:00 TRACE Zigbee Switch Mc-Test Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-08-09T18:58:32.971578109+00:00 INFO Zigbee Switch Mc-Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-08-09T18:58:32.982493359+00:00 PRINT Zigbee Switch Mc-Test value.value >>>>>>>>>>> 0
2022-08-09T18:58:33.019354942+00:00 PRINT Zigbee Switch Mc-Test New value.value >>>>>>>>>>> false
2022-08-09T18:58:33.035228651+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“LQI: 255 … RSSI: -59 dBm”},“visibility”:{“displayed”:false}}
2022-08-09T18:58:33.083562734+00:00 PRINT Zigbee Switch Mc-Test <<<<<<< Power meter Timer >>>>> ON
2022-08-09T18:58:33.108877651+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-08-09T18:58:33.155191484+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“power”,“capability_id”:“powerMeter”,“component_id”:“main”,“state”:{“unit”:“W”,“value”:0}}
2022-08-09T18:58:33.200239401+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“energy”,“capability_id”:“energyMeter”,“component_id”:“main”,“state”:{“unit”:“kWh”,“value”:0.0}}
2022-08-09T18:58:33.232307859+00:00 PRINT Zigbee Switch Mc-Test <<<<< Cancelando timer >>>>>
2022-08-09T18:58:33.246235984+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
2022-08-09T18:58:33.252346484+00:00 TRACE Zigbee Switch Mc-Test Received event with handler zigbee
2022-08-09T18:58:33.256929817+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5F6F, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -59, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x55, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: SUCCESS > > >
2022-08-09T18:58:33.273411234+00:00 TRACE Zigbee Switch Mc-Test Received event with handler zigbee
2022-08-09T18:58:33.278867067+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5F6F, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -59, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x26, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2022-08-09T18:58:33.295457692+00:00 TRACE Zigbee Switch Mc-Test Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-08-09T18:58:33.310204984+00:00 INFO Zigbee Switch Mc-Test Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2022-08-09T18:58:33.315610734+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-08-09T18:58:33.327890109+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
2022-08-09T18:58:33.347489567+00:00 TRACE Zigbee Switch Mc-Test Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-08-09T18:58:33.352252067+00:00 INFO Zigbee Switch Mc-Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-08-09T18:58:33.359519276+00:00 PRINT Zigbee Switch Mc-Test value.value >>>>>>>>>>> false
2022-08-09T18:58:33.362316609+00:00 PRINT Zigbee Switch Mc-Test New value.value >>>>>>>>>>> false
2022-08-09T18:58:33.365574067+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“LQI: 255 … RSSI: -59 dBm”},“visibility”:{“displayed”:false}}
2022-08-09T18:58:33.399376192+00:00 PRINT Zigbee Switch Mc-Test <<<<<<< Power meter Timer >>>>> OFF
2022-08-09T18:58:33.407321692+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-08-09T18:58:33.420620609+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
2022-08-09T18:58:36.119352568+00:00 TRACE Zigbee Switch Mc-Test Received event with handler zigbee
2022-08-09T18:58:36.132515401+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5F6F, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x27, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int8, OnOff: true > > > >
2022-08-09T18:58:36.154971068+00:00 TRACE Zigbee Switch Mc-Test Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-08-09T18:58:36.158085026+00:00 INFO Zigbee Switch Mc-Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-08-09T18:58:36.163214276+00:00 PRINT Zigbee Switch Mc-Test value.value >>>>>>>>>>> 1
2022-08-09T18:58:36.166240984+00:00 PRINT Zigbee Switch Mc-Test New value.value >>>>>>>>>>> true
2022-08-09T18:58:36.169671026+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“LQI: 255 … RSSI: -64 dBm”},“visibility”:{“displayed”:false}}
2022-08-09T18:58:36.181975693+00:00 PRINT Zigbee Switch Mc-Test <<<<<<< Power meter Timer >>>>> OFF
2022-08-09T18:58:36.185532026+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-08-09T18:58:36.197120026+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“power”,“capability_id”:“powerMeter”,“component_id”:“main”,“state”:{“unit”:“W”,“value”:80}}
2022-08-09T18:58:36.212127568+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
2022-08-09T18:58:36.215947068+00:00 TRACE Zigbee Switch Mc-Test Received event with handler zigbee
2022-08-09T18:58:36.220681484+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5F6F, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x28, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2022-08-09T18:58:36.229778651+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
2022-08-09T18:58:36.233431568+00:00 TRACE Zigbee Switch Mc-Test Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-08-09T18:58:36.236310776+00:00 INFO Zigbee Switch Mc-Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-08-09T18:58:36.239528984+00:00 PRINT Zigbee Switch Mc-Test value.value >>>>>>>>>>> true
2022-08-09T18:58:36.242442693+00:00 PRINT Zigbee Switch Mc-Test New value.value >>>>>>>>>>> true
2022-08-09T18:58:36.245769318+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“LQI: 255 … RSSI: -64 dBm”},“visibility”:{“displayed”:false}}
2022-08-09T18:58:36.255289026+00:00 PRINT Zigbee Switch Mc-Test <<<<<<< Power meter Timer >>>>> ON
2022-08-09T18:58:36.258570734+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-08-09T18:58:36.268016109+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“power”,“capability_id”:“powerMeter”,“component_id”:“main”,“state”:{“unit”:“W”,“value”:80}}
2022-08-09T18:58:36.277726818+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
2022-08-09T18:58:40.846572485+00:00 TRACE Zigbee Switch Mc-Test Received event with handler zigbee
2022-08-09T18:58:40.855149652+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5F6F, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -60, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x29, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int8, OnOff: true > > > >
2022-08-09T18:58:40.874230693+00:00 TRACE Zigbee Switch Mc-Test Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-08-09T18:58:40.878221527+00:00 INFO Zigbee Switch Mc-Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-08-09T18:58:40.881493443+00:00 PRINT Zigbee Switch Mc-Test value.value >>>>>>>>>>> 0
2022-08-09T18:58:40.884568735+00:00 PRINT Zigbee Switch Mc-Test New value.value >>>>>>>>>>> false
2022-08-09T18:58:40.888669610+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“LQI: 255 … RSSI: -60 dBm”},“visibility”:{“displayed”:false}}
2022-08-09T18:58:40.909284443+00:00 PRINT Zigbee Switch Mc-Test <<<<<<< Power meter Timer >>>>> ON
2022-08-09T18:58:40.913309193+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-08-09T18:58:40.925015568+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“power”,“capability_id”:“powerMeter”,“component_id”:“main”,“state”:{“unit”:“W”,“value”:0}}
2022-08-09T18:58:40.937311318+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“energy”,“capability_id”:“energyMeter”,“component_id”:“main”,“state”:{“unit”:“kWh”,“value”:0.0}}
2022-08-09T18:58:40.950886235+00:00 PRINT Zigbee Switch Mc-Test <<<<< Cancelando timer >>>>>
2022-08-09T18:58:40.956621443+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
2022-08-09T18:58:40.960541402+00:00 TRACE Zigbee Switch Mc-Test Received event with handler zigbee
2022-08-09T18:58:40.965257610+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5F6F, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -59, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x2A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2022-08-09T18:58:40.976138193+00:00 TRACE Zigbee Switch Mc-Test Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-08-09T18:58:40.979098485+00:00 INFO Zigbee Switch Mc-Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-08-09T18:58:40.982293943+00:00 PRINT Zigbee Switch Mc-Test value.value >>>>>>>>>>> false
2022-08-09T18:58:40.985244527+00:00 PRINT Zigbee Switch Mc-Test New value.value >>>>>>>>>>> false
2022-08-09T18:58:40.988576902+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“LQI: 255 … RSSI: -59 dBm”},“visibility”:{“displayed”:false}}
2022-08-09T18:58:40.999184402+00:00 PRINT Zigbee Switch Mc-Test <<<<<<< Power meter Timer >>>>> OFF
2022-08-09T18:58:41.003543235+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-08-09T18:58:41.012462068+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
2022-08-09T18:58:49.183276319+00:00 DEBUG Zigbee Switch Mc-Test driver device thread event handled
2022-08-09T18:59:08.009321238+00:00 TRACE Zigbee Switch Mc-Test Received event with handler zigbee
2022-08-09T18:59:08.073662155+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5F6F, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -60, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x2B, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int8, OnOff: true > > > >
2022-08-09T18:59:08.104605280+00:00 TRACE Zigbee Switch Mc-Test Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-08-09T18:59:08.114199071+00:00 INFO Zigbee Switch Mc-Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-08-09T18:59:08.136961988+00:00 PRINT Zigbee Switch Mc-Test value.value >>>>>>>>>>> 0
2022-08-09T18:59:08.150604905+00:00 PRINT Zigbee Switch Mc-Test New value.value >>>>>>>>>>> false
2022-08-09T18:59:08.164491988+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“LQI: 255 … RSSI: -60 dBm”},“visibility”:{“displayed”:false}}
2022-08-09T18:59:08.177049530+00:00 PRINT Zigbee Switch Mc-Test <<<<<<< Power meter Timer >>>>> OFF
2022-08-09T18:59:08.181083321+00:00 INFO Zigbee Switch Mc-Test <ZigbeeDevice: 8f2a9f23-5370-4144-b511-a698cd635321 [0x5F6F] (Sonoff ZBMini)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”}}
2022-08-09T18:59:08.199420363+00:00 DEBUG Zigbee Switch Mc-Test Sonoff ZBMini device thread event handled
Hi @Paul_Oliver,
It seems to be working fine, when on_off handler receives the value 0 or 1 it converts it to false and true respectively and emits the correct event.
in bold value.value >>>>>>>>>>> and New value.value >>>>>>>>>>>
Try it a little more and if it still works fine I’ll merge it with the zigbee Switch Mc driver.
Thanks for your help
@Denz_Modz,
I’m glad it works well for you.
Don’t worry, I will notify you when I merge it with the definitive Zigbee Switch Mc driver and then you will only have to make a driver change in the app device driver menu and you will not lose anything, name, automations and settings.
In any case, as long as you do not uninstall a driver from your hub, it does not matter if it is deleted from the channel, it will continue to work indefinitely.
Ok, I will continue testing for a few days, and get back to you.
Hi
Has something changed in the last few days with the stock driver for this device?
I have had the Sonoff ZBMini installed for a few weeks using the “Zigbee Switch” driver, which it automatically selected when pairing (2022-01-26), and it’s been working perfectly well, up until 2 days ago.
Now the device connectivity seems a bit random. Goes offline… When online it doesn’t always respond to on/off commands; when it does respond it doesn’t change in the app; control in the app indicates on/off but the device doesn’t respond…
(I haven’t found a consistent pattern yet)
Nothing else on my system has changed, just this device now seems sporadic.
I would suggest using @Mariano_Colmenarejo “Zigbee Switch Mc” driver. It has been work great for months,
@Paul_Oliver is right, @Hendo25. The issue is that the device is sending unexpected values by the default libraries which are according to the Zigbee cluster specification.
So, for now, you should use the custom driver. The team is checking more details about the device and the issue to see what they can do.
Once we get more info, we’ll let you know.
ive had a smarthings plug running fine for a while on the dth today i changed it over to edge , bad idea
it shows up as a lds plug
the power meter bit is useless the fan its connected has two speeds on first speed power meter eventually gets to 14w
on second speed power meter still at 14w turn the fan off physically still 14w.
It has been around 5 days and my ZBMini continues to work fine with your “zigbee Switch Mc-Test” driver. So it should be safe to merge it.
Thanks @Paul_Oliver
Driver modified for switch zigbee Sonoff Mini in this driver version
│ Name        │ Zigbee Switch Mc                     │
│ Version     │ 2022-08-14T14:06:16.674806212        │
In a few days I will delete the driver Test version of the channel
So I have been having this issue that my zbmini always reports as turned on when using the physical switch. I added your firmware, but when I want to change the firmware in the smartthings app, I only get a white screen when I click your firmware.
Do you have any idea what is going wrong?
Hi @Youri1983
I think it is a new problem with last app version and android 13
Should I be able to change it from a windows pc? Can’t even remember if there is a smartthings app for windows.
Only with other tablet or phone with android 11 or 12 or previous smartthings app version or from IOs app.
I hope it fixed soon!
I hope so too. In the meantime I grabbed my previous phone, logged in and was able to change the firmware. Now it displays the correct status (dispite having a 1.5 second delay) so I can use the mini as a build in smart switch.
Has anyone already given you credits for your amazing help and work today? If not let me be the first. Thank you!
Yes, I have also noticed a delay in updating status in the new version of the app compared to the previous version
just FYI I’m running android 12 and having the same driver change issues since the lastest update so I don’t think it’s specific to android 13.
And I have the issue with android 11 too :astonished:
Yesterday worked fine
