Anyway to get the leviton dimmer added. I got these to replace a GE switch that would not pair and now these do not have an edge driver. They paired as groovy.
The Groovy handler has an exact match for 0x001D/0x3201/0x0001 and 0x001D/0x3301/0x0001 both:
Theres no exact match for 0x001D/0x3201/0x0001 (DZ6HD) in the generic switch Edge driver, only 0x001D/0x3301/0x0001 (DZ1KD)
https://github.com/SmartThingsCommunity/SmartThingsEdgeDrivers/blob/main/drivers/SmartThings/zwave-switch/fingerprints.yml.
@nayelyz, whats the process for getting what looks like an oversight in copying support for a device’s fingerprint from Groovy to Edge? I can add the fingerprint and submit a pull request if that is easiest.
As I understand, a non-exact fingerprint like this one means that if a device matches in manufacturerId and productId, the productType can be any value, which means that both devices should be accepted.
But, I will report it, Pull Requests are not currently being reviewed.
@Shanapadila, could you DM me with the following information, please?
- When did you try to pair the device? If it has been more than 12 hours since, please help us try again and send the Hub logs from the IDE:
- In the IDE, enter “my hubs”
- Enter the corresponding Hub and go to “view utilities”
- Click on “send” below "send hub logs
- Is your email account here the one that you use for SmartThings?
- If you have more than one Hub, the name of the one where the device is paired.
- The name of the device after it gets paired with the DTH
Agreed, but as the Groovy fingerprint is a more exact match (all 3 parameters match), I’m guessing it wins over the more generic Edge fingerprint. The Leviton 6HD is a pretty popular switch, makes sense that it would get an exact match in Edge to be sure its covered.
Thank you! Please let me (us) know if there is a better/easier route to submit issues/concerns like this to you and your team.
Mmm it depends, it is preferred in a new post so our discussion doesn’t get lost.
I’ll move these posts in this case.
If you need to share files with us, please send an email to build@smartthings.com.
But, tagging us is ok as well, as we receive a notification, we know there’s something we need to look at. It would be nice if you could add the link where the conversation started ![]()
I can’t get any of my leviton or GE switches working with the z-wave driver. Starting to wonder if my Z-Wave radio got borked.
Post their model numbers and maybe we can assist.
Troubleshooting steps:
- Are you excluding the zwave devices first before including them?
- What does “can’t get them to work” mean? They don’t include? They include but with the wrong driver?
- Leviton devices can sometimes be finiky to include correctly, especially with S2 security. I’ve often has those include incompletely (they get paired as a Zwave Thing with a fingerprint of 0000-0000-0000) and have to try several times. GE/Jasco are usually very solid.
