I did what you said and the tile did not change to a multi-tile. Iβm on Android.
Sorry, I have thoroughly checked the profile code of your device and found an error in the name of the multi-tile profile.
I will correct it this afternoon and let you know.
thanks for reporting it
Fixed in this driver version
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Multi Switch and Child Mc
Version 2024-11-18T17:12:39.051800484
Hi @Pjvs
Please, Are your device TS0002/_TZ3000_lmlsduws" double switch workin for power and energy measurement?
Manufacturer _TZE200_vzqtvljm
model TS0601
endpoint 0x01
device ID 0x0051
profile ID 0xA3A7
Network ID 0x0104
Server clusters
Groups 0x0004 0x01
Scenes 0x0005 0x01
TuyaEF00 0xEF00 0X01
Basic 0x0000 0x01
Client Clusters
Time 0x000A 0x01
OTAUpgrade 0x0019 0x01
You device has EF00 clusters, so try using the Personal Tuya Devices - EF00 driver. See link below
Datapoint is not displayed.
EF00 DRIVER
info
Look in history and see if there are any information.
Roberto, did you do it in this order? Iβve found itβs better to have installed the driver to your hub before pairing the device.
Thanks for the great work.
Iβm thinking of buying these https://www.aliexpress.com/item/1005007972719183.html?spm=a2g0o.productlist.0.0.2063743bW95F6V&mp=1
I checked & your driver supports the 3 gang version
deviceLabel: Aqara ZNQBKG31LM
manufacturer: LUMI
model: lumi.switch.acn040
deviceProfileName: three-switch
I have a few questions
- I canβt seem to find fingerprint for the 2 gang version, is it supported? I assume it would be easy since the 3 gang is
- In Aqaraβs website, they explain that any of the buttons can be configured as βwirelessβ button, i.e. if not load is connected, you can program this button with press, double press & hold actions - does your driver support this?
- If the above is not possible, it it possible to mimic this behaviour? this driver mimics click, double, triple & hold for IKEA strybar despite not officially supported [Edge] IKEA STYRBAR Button Edge Driver (FW 2.4.5 compatible, full arrow support)
Hi,
I donβt know what 2-gang fingerprint you are looking for and canβt find, there are several 2-gang LUMis.
Sorry, My driver does not support different types of button presses
this one βlumi.switch.b2nc01β
Hi,
Added to this driver version
you need reinstall with this driver version installed in your hub
Version 2024-11-21T16:55:07.569520644
- id: "LUMI/switch.b2nc01"
deviceLabel: LUMI Double Switch QBKG41LM
manufacturer: LUMI
model: lumi.switch.b2nc01
deviceProfileName: two-switch
@Mariano_Colmenarejo , how are you?
I find that the settings to input the connected load power manually doesnβt accept decimal numbers.
This can be changed in a future version?
Hi,
can you add the Fingerprint
_TZ3000_kdi2o9m6
actually Driver
Devices: https://github.com/Mariano-
Github/Edge-Drivers-Beta/blob/main/zigbee-
switch-v6.5/fingerprints.yml
to this driver to get Watt Symbol in the Icon.
Devices Supported: https://github.com/Mariano-
Github/Edge-Drivers-Beta/blob/main/zigbee-switch-power-v5/fingerprints.yml
Optical same Plugs in my House. But diffrent Manufacturers?!
Thx for you hard work. ![]()
Hi,
Changing the data type of preferences can be problematic and cause the preferences not to be displayed in the app, at least that was the case until now. What you had to do was create a new preference with another type of data.
I donβt think it will do this anymore, since a precision of 1 W for a simulated consumption meter seems sufficient to me.
Tolerances of +/-1 W in a real device can be normal or more, depending for example on the operating temperature of the device and the hardware it has to compensate for it, which causes the temperature to vary the resistance or impedance of the load even more than the equivalent of 1 W.
Hi,
This device does not has power and energy capabilities, I have one of them.
In the driver fingerprints are comments due to I use it for test.
I may add simulated power measurement to the zigbee switch Mc driver tile in the future
Name Zigbee Switch Mc
Version 2024-12-03T17:39:50.798152854
- id: "ZBMicro/Switch"
deviceLabel: ZBMicro Switch
manufacturer: SONOFF
model: ZBMicro
deviceProfileName: single-switch
