Added timeout of 30 sec for this device in this driver version
{mfr = “_TZ3000_lzdjjfss”, model = “TS0210”, timeout = 30 },
New driver version will be automatically updated in 12 hours maximum
Name Zigbee Motion Sensor Mc
Version 2024-08-01T15:31:14.239595598
If you can turn on and off the 5 plugs from advanced users web, then you should also be able to control them from the app, they are the same commands sent to the same endpoints
please add this device to the Thermo and humidity driver fingerprint:
Model: TS0201
Fingerprint: _TZ3210_ncw88jfq
Type: thermo and humidity sensor with lcd
Added to this driver version.
This device uses EF00 tuya cluster too, I do not known if it will works fine
You need uninstall device
Install this driver version in your Hub
Pair device with with this driver version, you do not perform a driver change from zigbee thing
Name Zigbee Temp Sensor and Child Thermostat Mc
Version 2024-08-07T16:38:01.476703703
- id: "_TZ3210_ncw88jfq/TY0201"
deviceLabel: Tuya TS0201
manufacturer: _TZ3210_ncw88jfq
model: TY0201
deviceProfileName: temp-humid-battery
Just found this amazing item on AliExpress. Check it out!
US $7.82 | Tuya Smart WiFi/Zigbee Micro USB Adaptor Switch 5V Mini 1 2 3 USB Power Adaptor Smart Life Control Via Alexa Google Yandex Alice https://a.aliexpress.com/_oD7uSdt
You are a veteran in this community and you already know that with this information I can’t tell you anything for sure. Fingerprints and clusters are needed
Unsure if it is the the right topic.
How to find out if the following device are supported byt SmartThings / Edge Driver?
Sunricher remote DIM CCT RGB 3 in 1 Zigbee Remote SR-ZG2868
Sunricher remote controller DIM Single Color 2 Groups Zigbee Wall Mounted Remote Controller SR-ZG9001NK4_DIM
Since both are “remotes”, I tried to find info in other topics, however unsuccessful.
What info is needed?
Manufacturer: Sunricher
Model:
FingerPrinted_EndPoint.Id:
App Version:
ZCL Version:
Network ID:
Zigbee EUI:
Device ID:
Server Cluster:
Client Clusters:
I have a few Xiaomi_ZNCZ02LM plugs that work perfectly, thank you Mariano, as switches for now, but I intend to use them as power meters for 2 fridges and a couple of freezers.
I could use them as is but I’m worried if a kid use the google home app or the smarthings app and turn it of by mistake.
Can you please add the footprint to the power/meter drivers so I can use it as a power meter?
