I donβt know if this device is the lumi.plug fingerprint and I donβt know if it uses standard or custom zigbee clusters.
I could see it if you send me the device information with the zigbee thing Mc driver decoded htlm text from advanced users status of deviceInfo capability
I also have power measurements and they work great as a switch.
I wonder if it is possible to add it also as a zigbee power/meter in order to have power measurements without the controls of the switch (on/off), as i explained i donβt want the controls to avoid accidental switching of sensitive devices (ex. freezer).
Thank you also for the information. Zigbee Thing MC driver also gives me:
In some devices the dimmer is used to control the intensity of the indicator LED.
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Switch Mc
Version 2024-08-22T20:45:43.113517025
- id: "IKEA/TRETAKT"
deviceLabel: IKEA TRETAKT Plug
manufacturer: IKEA of Sweden
model: TRETAKT Smart plug
deviceProfileName: single-switch-plug
After reading your message, I checked and the dimmer function of the the ZigBee Multifunction Light Mc driver does not adjust the brightness of the the indicator LED. That would have been a nice feature.
Hi @Mariano_Colmenarejo, hope i find you well.
Can you move/add this device to the Zigbee Switch MC driver? Itβs pairing with the Zigbee Switch Power MC driver, but this is the model without power metering.
so i will try to remove it and pair it again, and feedback to you if it worked or not.
But, searching in aliexpress and google, it seems that this device has two versions, with and without power monitoring function.
Itβs possible that they share same firmware.
You need uninstall device
Install this driver version in your Hub
Pair device with with this driver version, you do not perform a driver change from zigbee thing
Name Zigbee Contact Mc
Version 2024-09-24T11:12:11.691912934
- id: "_TZ3000_3fqh6agt/Close Sensor"
deviceLabel: GIRIER Contact Sensor
manufacturer: _TZ3000_3fqh6agt
model: TS0203
deviceProfileName: contact-battery-profile
Hi, just wanted to say that I have tried this driver with a Nedis Zigbee outdoor socket. I couldnβt find it in the list of fingerprints but it was available in the list of drivers when I had installed it. I used this driver because I needed the metering divisor set to 1000. The fingerprint details of the device are:
Model TS011F
Manufacturer: _TZ3000_3ias4w4o
It seems to be working well, however I have one questionβ¦ I more or less only want to use this device for metering and donβt want to switch it at all except in some very select circumstance. Is it possible to βlockβ the switch so that it is permanently on (or add such a functionality)? I donβt want to even accidentally switch it in the ST UI as I would then need to be on site to reset the thing that it is measuring
