Thank you. It works well.
It works so well, thank you.
Do you have driver for this product?
https://a.aliexpress.com/_oEkp3y4
I juat want to be sure before I order it.
Is a TS0601 model. I think it works with tuya EF00 cluster.
does not work with my driver, but could works with EF00 cluster driver
Hi @Mariano_Colmenarejo, do you know if this switch works with your driver?
Just found this amazing item on AliExpress. Check it out!
US $16.96 | MOES Tuya ZigBee Smart Light Switch US Push Button Wall Switch Work With Alexa Google Home Neutral Wire/No Neutral Wire Required
https://a.aliexpress.com/_mM0QVjC
I just installed the 4 button version and it works well with @Mariano_Colmenarejo 's driver.
Thank you very much!
@Mariano_Colmenarejo, I have an Ikea Tretakt plug which has the following clusters:
Manufacturer: IKEA of Sweden Model: TRETAKT Smart plug FingerPrinted_EndPoint.Id: 0x01 App Version: 0x02 ZCL Version: 0x08 Network ID: 0x0854 Zigbee EUI: 38398FFFFE0BAD25 Device ID: a8782181-ed90-4357-a1e0-84e1d99fa3b9 Server Cluster: Ep: 0x01={ 0000,0003,0004,0005,0006,0008,1000, FC57,FC7C,FC85 } Ep: 0xF2={ 0021 } Client Clusters: Ep: 0x01={ 0019 } Ep: 0xF2={ 0021 } Signal Metrics: LQI: 142 .... RSSI: -75 dbm |
Iβm a bit impressed with the fact that It has the cluster 0008, how can it be possible if itβs a plug?
I think that itβs related to that Ikea is selling Tretakt plug also as pre-paired kit with a plug and remote control (Rodret). Tretakt plug can also be used without the Hub.
TRETAKT plug with remote control, smart - IKEA
However, Tretakt plug works as an On/Off device.
Edit:
You can test sending level to Ikea Tretakt from my.smartthings.com-advanced/devices/your-device-id
If you send setLevel 50% command to Ikea Tretakt, plug turns on.
I see cluster 0008 supported in smart plugs all the time, including, for example, the Zigbee models for Leviton and Neo. Itβs not obvious to me why itβs there since these are binary on/off devices. Could be some kind of compatibility method for group binding. or for manufacturers which use similar firmware for bulbs and plugs. Or which, like Leviton, have some smart plugs which do support dimming and some which donβt and they are using common firmware.
But in any case, itβs quite common.
There are times that cluster 0008 on plugs and switches is linked to the intensity of the indicator LED, not to the level of the loadβs switched output.
You can use zigbee switch stock if you want, which only shows the switch on and off caoability
Thatβs weird!
Sorry if this was asked already, but is there a way to turn on/off a child switch from the ST home screen?
Basically what I am looking for is a way to activate the child switch (1, 2 or 3) from the ST favorites, instead of going into the switch and selecting the one I want.
Hi,
In device settings you can create child devices, that is, switches 2 and 3.
Then you rename them whatever you want and add them to favorites.
You can also rename switch 1 and add it to favorites
thank you Mariano, that worked perfectly
@Mariano_Colmenarejo could you add the following 4 Gang In-Wall Relay to your Zigbee multi switch and child Mc driver? I donβt see an EF00 clusters.
Manufacturer: _TZ3000_mmkbptmx
Model: TS0004
App Version: 0x48
ZCL Version: 0x03
Zigbee EUI: A4C138E791AF7D63
Server Cluster:
0x02={ 0004,0005,0006 }
0x03={ 0004,0005,0006 }
0x01={ 0003,0004,0005,0006,0702,0B04,E000, E001,0000 }
0x04={ 0004,0005,0006 }
Client Clusters:
0x01={ 0019,000A }
0xF2={ 0021 }
Signal Metrics:
LQI: 255
RSSI: -36
Hi Paul,
Added to this driver version
You need install this driver version
uninstall device and reinstall device
You do not perform a driver change
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Multi Switch and Child Mc
Version 2024-06-25T21:02:05.069641144
- id: "TS0004/_TZ3000_mmkbptmx"
deviceLabel: 4 Gang In-Wall Relay
manufacturer: _TZ3000_mmkbptmx
model: TS0004
deviceProfileName: four-switch
Thank you.
It works as expected.
@Mariano_Colmenarejo ,
Can you please add:
Model : TS0002
Manufacturer : TZ3000_mtpeobef
Power Socket + Switch
