Only the master/child multi switch driver devices. Started happening out of the blue last weekend, maybe coincidentally coinciding with the new ST app update. It never happened before that.
Are Tuya devices?
If yes, then uninstall devices and pair again for device configure
They are 3A wall fan and light switches and jinvoo style power boards. I have uninstalled and reinstalled one of them, it continues to act up. I will uninstall all of them.
Oh and Nue wall outlets.
Sorry, it uses the EF00 cluster and it doesnβt work with standard zigbee drivers.
can try Tuya EF00 deiver personal driver
Just to close this out, I uninstalled and reinstalled, now they all seem to be working as expected.
Hi @Raimundo
This device was added last October as two-outlets, since at that time I didnβt know how to unlock TUYA multi-component devices.
@Vinicius_Tiepo I have changed the profile to four-outlet and it should work
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Multi Switch and Child Mc
Version 2023-08-24T11:31:28.590746815
- id: "_TZ3000_3zofvcaa/Outlet"
deviceLabel: TS011F Outlet
manufacturer: _TZ3000_3zofvcaa
model: TS011F
deviceProfileName: four-outlet
Hello @Mariano_Colmenarejo,
I see on the forum that the vibration sensor was added.
I am testing but it is very sensitive and most of the time it is like there is movement.
The info of the device:
https://es.aliexpress.com/item/1005005237218921.html?spm=a2g0o.new_account_index.0.0.55d8425c2n3weK&gatewayAdapt=glo2esp
Device Information
Manufacturer: _TZ3000_bmfw9ykl
Model: TS0210
FingerPrinted_EndPoint.ld: 0x01
App Version: 0x41
ZCL Version: 0x03
Network ID: OX5AB7
Zigbee EUI: A4C13807F1218C38
Device ID: d57e7349-a0fc-40eb-85f4-
a5cΠ΅59Π°Π°78Ρ8
Server Cluster:
Ep: 0x01=<0001,0500,0000)
Client Clusters:
Ep: 0x01=(0019,000A)
Signal Metrics:
LQI: 200 β¦RSSI: -51 dbm
I dont know that its normal or not?
Are you try modify the sensitivity level in settings preferences?
Default value is 2, try with value 1.
You could need to wake up device to set new value
Here is the fingerprint screenshot I was missing. Please add this 4 channel Zigbee Switch. Thanks.
Added to this driver version
To unlock the device and have the 4 switches work independently you have to uninstall the device and pair it again directly with this driver
Version 2023-09-01T20:57:41.189331616
- id: "TS0004/_TZ3000_wkr3jqmr"
deviceLabel: TS0004 Switch
manufacturer: _TZ3000_wkr3jqmr
model: TS0004
deviceProfileName: four-switch
Works great. Thank you Mariano!
Please give me a help. I would really like help on the 4 button zigbee device to work!
Applaud for all the convience you have brought us!
https://www.hej.life/product/detail.html?product_no=105&cate_no=63&display_group=1
4 button with each 3 actions (Press once / press twice / press long)
Sorry, I donβt have any driver for zigbee multiple buttons.
maybe @erickv can add it to his driver
@Mariano_Colmenarejo neewbie to the edge stuff here. How did you get this working? Iβm trying to add SONOFF ZBMINIL2 to mine now but failingβ¦any advice welcome thanks!
Hi @Graemac
Edge driver zigbee Switch Mc has this model fingerprints
- id: "SONOFF/ZBMINIL2"
deviceLabel: SONOFF Switch
manufacturer: SONOFF
model: ZBMINIL2
deviceProfileName: single-switch
If your device has exactly the same fingerprints the it will works with driver zigbee Switch Mc
If your device has different fingerprints, then I need add your device fingerprints to the driver
Opening this up again.
Randomly, last night, these same devices started acting up again. Same devices that were affected last time.
Again, removing them and adding them again has βsortedβ it out, but it is very painful having to fix it all again.
Good morning @Mariano_Colmenarejo, I use your Zigbee Switch Mc driver to control various Vimar switches without any problem, I added a new Vimar Switch a few days ago which, although it works, displays a message and I can understand the reason. I attach screenshots to be clearer. Based on your experience, do you have any idea how to resolve this? Thank you
Hi @mkcimino
The device has not updated the capability switch status.
It may not have been paired successfully, please try pairing again near the Hub
