Sorry, I only have a driver for the smartthings button and this device does not fit in this driver.
There are other drivers for xioami buttons in the community, which might fit
This device is in the process of being accepted for the new version of the stock driver.
If you want to wait for it to be published or do you want me to add it to mine?
βββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ
β Name β Zigbee Motion Sensor Mc β
β Version β 2022-03-15T19:41:40.729077 β
βββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ
Hi Giacomo,
I have updated the github repository of these drivers, but I am not going to update it anymore since it is not necessary, the Zigbee Multi Switch Mc should work fine for all the devices that used the Zigbee Multi Switch Zemismart Mc
β Version β 2022-03-16T19:21:27.455542 β
The curious is. That FP is based on thing edition to ZIGBEE VALVE stock device handler, but in this case Amazon Alexa will NOT get as new device, so⦠does not exist at the platform.
Then i tried changing to average ZIGBEE SWITCH DH and⦠Bingo! Alexa ready!
Do you think adding the fingerprint to your Zigbee Valve MC will allow alexa to find it? if not, whatΒ΄s the best solution? Add to any average switch like that or find the βalexa issueβ on Valve driver?
β Name β Zigbee Valve Mc β
β Version β 2022-03-16T21:54:51.044256 β
I do not know.
If not works could try adding it to the zigbee switch driver
Firstly I would like to send a big thank you to @Mariano_Colmenarejo!
I have a Lidl Silvercrest 3-gang power strip and your edge driver works like a charm. Itβs so great to have people like you here providing all of us with drivers for free.
I have two minor things to ask for, maybe itβs possible to support this:
Firstly, with the old DTH I used formerly I saw the three outlets as separate devices. I found I can change the setting to show all three plugs in the SmartThings app, but sadly only the βmain plugβ is showing up in Alexa devices. I have some Echo routines where it would be great to also again make use of the 2nd and 3rd outlet.
Secondly, would it be possible to let the user customize the name of the three outlets? With the old groovy DTH I could name each βdeviceβ, which would of course be great if that would also work with the new edge driver.
Again, thanks a lot for your work and cheers from Germany,
Christoph
These are two requests that have been made to smartthings by various users.
Hopefully they can give us a solution.
Currently the only thing that can be done is to use 2 virtual switches and with automations to synchronize the state and actions of switch2 and switch3 with the virtual devices.
Also to facilitate the control of the three switches without opening it, you can choose in preferences a multiple mosaic with the 3 switches and the all switches
Thanks a lot for clearing things up for me. So we have to hope the SmartThings team will adress this in the future. In the meantime the work-around with virtual devices will be sufficient for me for scenarios where local execution is not the goal anyway (ie Echo routines).
Best regards!
