(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
I had been using the Zigbee Motion Sensor Mc driver with my Tuya PIR motion sensor, but few weeks ago went offline. I finally reset and re-added to my ST as Zigbee Thing but I can’t change to the Zigbee Motion Sensor Mc driver. Can this be fixed?
Added to this driver version
You need uninstall device
Install this driver version in your Hub
Pair device with with this driver version, you do not perform a driver change from zigbee thing
 Name         Zigbee Motion Sensor Mc
 Version      2024-08-05T10:49:15.875208395
- id: "TTUYATEC-kmfarmcu/Motion"
    deviceLabel: RH3040 Motion Sensor
    manufacturer: TUYATEC-kmfarmcu
    model: RH3040
    deviceProfileName: motion-battery
That worked perfectly! Thanks!
I have installed the RBOY Enhanced z-wave driver but it still shows as β€œConnected” but still has no functionality in Smartthings. I’m not sure what else I can do.
I’ve bought the universal enhanced z-wave driver, but the lock still has no functionality in Smartthings.
@Kimmo_Liias
Could you please tell me if this device works with the driver? It may not be important for you, but it is important for me and other users, thanks
Could you please check the device code:
_TZE200_a8sdabt
It should be:
_TZE200_a8sdabtg
Driver is currently not pairing this driver at all.
Sorry for the error. If you had told me I would have corrected it without any problem.
Modified in this driver version
 Name         Zigbee Temp Sensor and Child Thermostat Mc
 Version      2024-08-07T18:57:26.521342253
- id: "_TZE200_a8sdabtg/TS0601"
    deviceLabel: Tuya TS0601
    manufacturer: _TZE200_a8sdabtg
    model: TS0601
    deviceProfileName: temp-humid-battery  # works ??
Thanks for that! 3/4 sensors begin to work. I think there is something other problem with one. However could you please change this to following driver:
Zigbee Temp Sensor with Thermostat Mc
Integrated thermostat function is much more convenient to use. Child thermostat is makes huge mess with automation rules. Really hope you could change that or add to both drivers.
First off, thank you so much for all you’re doing here! This thread and driver pack is wonderful!
Would it be possible to add the following Siren device?
Model
TS0601
Manufacturer Code
_TZE204_t1blo2bj
Thank you so much! We’re trying to set up an alarm to let us know if our autistic son gets into rooms he’s not supposed to be in where he could get into danger (garage, cleaner storage cabinets, etc)…
Hi,
This device user EF00 tuya cluster and does not work with my driver.
It could works with personal tuya EF00 driver
Thanks! I appreciate the response anyway. I’ll look into that one.
Update: that one absolutely did the trick! Thank you so much!
@Mariano_Colmenarejo, could you please add the β€œLocal Time Offset to UTC (-12 to 12)” preference to the β€œZigbee Contact MC” driver?
This is mainly to show the correct β€œlocal” time for the received signal metrics
Att,
@Mariano_Colmenarejo Hey, I really appreciate your work. Would it possible to add the Schneider Electric Wiser Motion and luminance Sensor? By now, it is only added as a Zigbee-Thing. This is the device Information I get when using your Zigbee-Thing driver:
Device Information
Manufacturer: Schneider Electric
Model: CCT595011_AS
FingerPrinted_EndPoint.Id: 0x01
App Version: 0x01
ZCL Version: 0x03
Network ID: 0xB059
Zigbee EUI: E0798DFFFEF5E622
Device ID: 69f63552-37ac-44e1-b690-821b95bbcf90
Server Cluster: 0x01={ 0000,0001,0003,0020,0400,0500,0B05 }
Client Clusters: 0x01={ 0000,0019 }
Signal Metrics: BR
LQI: 255 …
RSSI: -58 dbm
Hi,
 Version      2024-08-19T10:36:58.859122089
- id: "Schneider Electric/CCT595011_AS"
    deviceLabel: Schneider CCT595011_AS Motion Sensor
    manufacturer: Schneider Electric
    model: CCT595011_AS
    deviceProfileName: motion-illuminance
Wow, that was quick! The sensor works, thank you very much!
Hi,
I’ve linked my hub to the Mariano Shared Beta Drivers channel but when I go to the the channel which I am already enrolled in and select show β€˜available drivers’, the page just has spinning icon and SmartThings logo on one side but no drivers show up.
I’ve just brought the Ikea Vallhorn motion sensor but the driver associated with it is the Zigbee Illuminance Sensor and no other driver is available to change it to motion sensor. I cannot install the driver from your channel as cannot access it.
Is there something I am doing wrong or another way to change the driver on the Vallhorn sensor?
Hi @dj_zanda
It must be a problem with the smartthings servers. There are other users and channels with the same problem.
Hopefully they will fix it soon
Hi @Mariano_Colmenarejo can you please add this Motion Sensor to the list?
  • id: β€œSONOFF/SNZB-03P”
    deviceLabel: SONOFF SNZB-03P Sensor
    manufacturer: SONOFF
    model: SNZB-03P
    deviceProfileName: DONT KNOW. It’s a motion sensor with light sensor too…
Thanks you very much man!
Hi,
I need information about the clusters device uses.
Pair it with the zigbee thing Mc driver.
In smartthings advanced users copy the html value of the deviceInfo attribute and paste it into the post
