You need uninstall device
Install this driver version in your Hub
Pair device with with this driver version, you do not perform a driver change from zigbee thing
Name Zigbee Motion Sensor Mc
Version 2024-09-07T08:59:41.638676836
- id: "eWeLink/SNZB-03P"
deviceLabel: Sonoff SNZB-03P Motion Sensor
manufacturer: eWeLink
model: SNZB-03P
deviceProfileName: motion-illuminance
When using the veonua driver, the switch appears in the app as one device. To control two channels, you have to go inside, which is not very convenient. I was hoping that you could just add a fingerprint to your driver and use that.
A work around would be to create 2 virtual buttons using the vEdge Creator driver linked below.
You could use one virtual button to run the same automations as the right Aqara button and the 2nd virtual button to run the same automations as the left Aqara button. Then you won’t have to open the device till.
I just got a zigbee water leaking sensor. And it’s look like the fingerprint not be inculded in your driver zigbee-moisture-sensor-v2. Could you please add the following fingerprint to your driver. Thank you.
Name Zigbee Moisture Sensor Mc
Version 2024-09-22T17:47:17.132150128
- id: "_TZ3000_5ynfoj1f/TS0207"
deviceLabel: Tuya Water Sensor
manufacturer: _TZ3000_5ynfoj1f
model: TS0207
deviceProfileName: moisture-battery
Version 2024-09-23T14:49:07.835999955
- id: "_TZE200_bh3n6gk8/TS0601"
deviceLabel: Tuya Motion Sensor
manufacturer: _TZE200_bh3n6gk8
model: TS0601
deviceProfileName: motion-battery
Hi @Mariano_Colmenarejo,
Driver is working fine reporting movement correctly for the Tuya Motion Sensor, but during the night, since there was no movement for a long time, the sensor went offline in smartthings. As soon as it detected the first movement in the morning, it automatically came back online and reported the event. Is there anything that can be done in the configuration or driver to prevent the device from going offline?
