(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
Please could you activate Show Logs Debug Prints in CLI preference and send me new logs to can see more debug info?
Hi @Mariano_Colmenarejo ,
I use your Edge drivers. I have a _TZ3000_kyb656no water leak sensor. This device mostly offline. Can you do anything for this?
Hi @Skyhan
See this post about this devices
Hey there once again Marioano and others! i have a frient motion sensor pro that works with this driver as well.
However the light (lux) interval cannot be changed in this driver. is that something that can be changed, or is it hardcoded into the device?
here is the fingerprint data of the device.
Currently, the device only updates the lux value every hour, and therefore it’s not suitable for being used to trigger lights to turn on when it’s dark and automations like that.
When this driver was made, the default configuration for illuminance did not exist and it was made in a personalized way with a maximum interval of 1800 seconds and a reportable change of 1 lux.
There are now default settings for illuminace in the hub firmware and they are 3600 sec and 1 lux of reportable change.
If your device is configured correctly it should report any change greater than or equal to 1 lux regardless of the maximum interval.
If not, please try to re-pair it from scratch near the hub to make it set up correctly
thanks, deleting the device and re-adding it with your driver did the trick! It reports quite a lot now though, hope it won’t impact battery life too much.
never mind, it started updating again every hour. weird that it worked at the start, got like a new lux value every second. but yeah, now it updated on the clock every exact 60 minutes again.
CΓ³mo estΓ‘s, despuΓ©s de que aΓ±adiste este driver, mandΓ© una captura de pantalla donde no indicaba baterΓ­a, pero justo unos minutos despuΓ©s de que mande la captura reporto, luego modificaste el driver para probar otro mΓ©todo para leer baterΓ­a y con el nuevo driver nunca reporto el nivel de baterΓ­a, crees que podrΓ­as regresarlo a la primera opciΓ³n de lectura de baterΓ­a?
It seems like weak signals. Sometimes works , sometimes don’t…
Leave your driver as is. No change is required from your driver. I will try to improve the reception.
Thanks for helping
Hola Jose Aureliano
Modificado a porcentaje de bateria en estas 2 versiones de drivers en que se usa el dispositivo
 Name         Zigbee Temp Sensor and Child Thermostat Mc
 Version      2023-08-06T19:21:01.413880196
 Name         Zigbee Temp Sensor with Thermostat Mc
 Version      2023-08-06T19:21:25.926294018
And if you cause light changes, the device does not inform them?
It may have an internal configuration that only reports certain changes in brightness, I don’t know
probably the internal configuration then. even holding a flashlight towards it doesn’t make it report anything :sweat_smile:
I don’t know what experience other users have with this device
If at first insrallation it reports faster it should keep it unless it has some internal function that lowers the reporting frequency in order to protect the battery when it is below a certain level
Worked!!! Gracias!!!
Hi! Can you please add this ZigBee siren?
Hi, @Mariano_Colmenarejo could you please add the device below to the Zigbee Multi Switch and Child Mc?
This device .( TZE200_t1blo2bj ) uses CLUSTER EF00, @Mariano_Colmenarejo drivers don’t support this.
You better try @w35l3y driver. Here:
Hi,
How many components, switches, does this device have?
Hi, @Mariano_Colmenarejo!
I have 5 switches in the same product!
Hi,
Added to this driver version
You need uninstall device from app an reinstall with the new driver version to a correct configuration
 Name         Zigbee Multi Switch and Child Mc
 Version      2023-08-08T14:35:10.141852566
- id: "_TZ3000_o005nuxx/TS011F"
    deviceLabel: TS011F Five Outlet
    manufacturer: _TZ3000_o005nuxx
    model: TS011F
    deviceProfileName: five-outlet
