(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
THank you @Mariano_Colmenarejo
Using both the mobile app and the web I am trying to switch the driver but error message says not valid fingerprint. I am trying the Z-Wave Smoke Alarm-Mc like you suggested.
In Web I am seeing:
Manufacturer Code: 0260-8003-1000
Model: 8003-1000
Fingerprint: 0260-8003-1000
Security Level: UNSECURE
Sorry, I make a error in productType 0x8002
I Will fix this afternoon
Fixed in this driver version
 Name         Z-Wave Smoke Alarm-Mc
 Version      2023-08-02T14:19:13.652009503
- id: 0260/8003/1000
    deviceLabel: Heiman HS1CG Gas
    manufacturerId: 0x0260
    productType: 0x8003
    productId: 0x1000
    deviceProfileName: gas-battery
21 posts were split to a new topic: [Edge drivers] Driver for TCPi A19 Zigbee smart bulbs
Still says:
Error changing device driver to “Z-Wave Smoke Alarm-Mc”. Ensure that the driver you are trying to change to has a valid fingerprint match with this device.
Wait - it worked. I had to uninstall the Zwave Smoke MC and reinstall.
Thank You!!! I just added it, its doesnt show battery level and Im getting a Waiting Zigbee Message, is this normal?
Hi @lmd569
Battery information may take a while to send the new value on some devices.
When the first zigbee message is received from the device with battery information, the signal metric and battery values will be updated.
If the information is not received in a maximum of 6 hours, try pairing it from scratch with the driver so that it can be configured correctly
Ok, I will thanks again!!
Hi Mariano
Many thanks for all you do and for adding the device to the driver…
Could I please ask you another fa our to get this device added too…its a Zemismart door sensor but a older model…
Many thanks in advance…
Regards
Lanio
Hi Lanio
Added to this driver version
 Name         Zigbee Contact Mc
 Version      2023-08-03T15:30:15.205937086
- id: "_TZ3000_mq9f17dw/Contact Sensor"
    deviceLabel: TS0203 Contact Sensor
    manufacturer: _TZ3000_mq9f17dw
    model: TS0203
    deviceProfileName: contact-battery-profile
Hi Mariano,
I have tried this driver but still does not seem to work.
Below is the image that shows whn the driver is installed.
Thanks & Regards
Lanio
Hi Lanio
Are you referring to the zigbee contact Mc driver?
It should work
Hi @Mariano_Colmenarejo ,
See attached log. Switch תאורת חדר הדר response and update status only if mechanical switch used.
NO response from App. Can you see something ?
And another LOG showing only retries from mobile without mechanical switch, No response:
LOG
23 e9bfd289-1d51-499e-8c64-d564d1868ad2 Zigbee Multi Switch and Child Mc
24 dc04dad1-b981-4578-88c2-922df6ae6a6b Zigbee Range Extender Mc
25 5ab64dc7-5d08-44a4-9806-5a5b823a18d2 Zigbee Sensors Edge Driver [YG] 1.8.16
26 bc53adfe-d18f-4ea4-9610-6aade6696b7a Zigbee Switch Mc
27 7fee6e41-26cc-49ef-b1f4-b30a43e02fe6 Zigbee Switch Power Mc
28 fce41c83-ef6f-4d6c-8e13-8c1b63588641 Zigbee Temp Humidity Sensor Mc
29 d692640b-402a-4d91-9151-d643ad4771f0 Zigbee Thing Mc
30 dfdb7a46-3b9a-49af-b08a-2e4624648a42 Zigbee Water Leak/Smoke Sensor 1.7
31 e7070ea0-2ed9-4802-b7e7-5912a75f20fa Zigbee Window Treatment Mc
32 59a497fe-9448-4ca9-9a3a-5cfcf2232f7e ZXT-120EU Z-Extender AC
? Select a driver. 23
connecting… connected
2023-08-05T17:03:33.683342231+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler capability
2023-08-05T17:03:33.685077022+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: d3922489-ddb3-4588-abd5-f057c23201c9 [0x4AD4] (תאורת חדר הדר)> received command: {“args”:{},“command”:“on”,“capability”:“switch”,“positional_args”:{},“component”:“main”}
2023-08-05T17:03:33.686678397+00:00 TRACE Zigbee Multi Switch and Child Mc Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2023-08-05T17:03:33.696365564+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת חדר הדר device thread event handled
2023-08-05T17:03:34.517940147+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-08-05T17:03:34.520992856+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: d3922489-ddb3-4588-abd5-f057c23201c9 [0x4AD4] (תאורת חדר הדר)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4AD4, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xFF, rssi: -38, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0001, DataType: Uint8, ApplicationVersion: 0x41 >, < AttributeRecord || AttributeId: 0xFFE2, DataType: Uint8, Uint8: 0x20 >, < AttributeRecord || AttributeId: 0xFFE4, DataType: Uint8, Uint8: 0x00 > > > >
2023-08-05T17:03:34.524455731+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת חדר הדר device thread event handled
2023-08-05T17:03:41.286462021+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-08-05T17:03:41.287115979+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: 08df7797-239d-41b8-a329-ef933b19520b [0xEB53] (RGBW הפעלת)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xEB53, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xFF, rssi: -33, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0xE6, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0001, DataType: Uint8, ApplicationVersion: 0x41 >, < AttributeRecord || AttributeId: 0xFFE2, DataType: Uint8, Uint8: 0x20 >, < AttributeRecord || AttributeId: 0xFFE4, DataType: Uint8, Uint8: 0x00 > > > >
2023-08-05T17:03:41.288217354+00:00 DEBUG Zigbee Multi Switch and Child Mc RGBW הפעלת device thread event handled
2023-08-05T17:03:46.557715103+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-08-05T17:03:46.558547436+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: 4bec33c4-dd7a-471c-802a-e46d546364d5 [0xFB6C] (רפיטר חדר הדר)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB6C, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFE, rssi: -38, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1F, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2023-08-05T17:03:46.575290019+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-08-05T17:03:46.575852561+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-05T17:03:46.576828769+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: 4bec33c4-dd7a-471c-802a-e46d546364d5 [0xFB6C] (רפיטר חדר הדר)> emitting event: {“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2023/08/05 Time: 17:03
DNI: 0xFB6C LQI: 254 RSSI: -38dbm
”},“attribute_id”:“signalMetrics”,“component_id”:“main”,“visibility”:{“displayed”:false},“capability_id”:“legendabsolute60149.signalMetrics”}
2023-08-05T17:03:46.581657519+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: 4bec33c4-dd7a-471c-802a-e46d546364d5 [0xFB6C] (רפיטר חדר הדר)> emitting event: {“state”:{“value”:“on”},“attribute_id”:“switch”,“component_id”:“main”,“capability_id”:“switch”}
2023-08-05T17:03:46.601892436+00:00 DEBUG Zigbee Multi Switch and Child Mc רפיטר חדר הדר device thread event handled
2023-08-05T17:03:46.604991436+00:00 DEBUG Zigbee Multi Switch and Child Mc רפיטר חדר הדר device thread event handled
2023-08-05T17:03:48.629850394+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: 4bec33c4-dd7a-471c-802a-e46d546364d5 [0xFB6C] (רפיטר חדר הדר)> emitting event: {“state”:{“value”:"S1:On "},“attribute_id”:“switchAllOnOff”,“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”}
2023-08-05T17:03:48.636826061+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: 4bec33c4-dd7a-471c-802a-e46d546364d5 [0xFB6C] (רפיטר חדר הדר)> emitting event: {“state”:{“value”:"S1:On "},“attribute_id”:“switchAllOnOff”,“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”}
2023-08-05T17:03:48.643093894+00:00 DEBUG Zigbee Multi Switch and Child Mc רפיטר חדר הדר device thread event handled
2023-08-05T17:03:49.616298602+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-08-05T17:03:49.616860727+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: ad6e8a1f-869b-4281-bf00-b97c4b6a6a78 [0x4477] (תאורת כניסה)> received Zigbee message: < ZigbeeMessageRx || type: 0x02, < AddressHeader || src_addr: 0x4477, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: Basic >, lqi: 0xFF, rssi: -49, body_length: 0x000B, < ZDOMessageBody || < ZDOHeader || seqno: 0xD6 >, GenericBody: 00 00 00 00 00 00 00 00 00 00 > >
2023-08-05T17:03:49.622113477+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת כניסה device thread event handled
2023-08-05T17:03:49.629693727+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-08-05T17:03:49.630157769+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: ad6e8a1f-869b-4281-bf00-b97c4b6a6a78 [0x4477] (תאורת כניסה)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4477, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -49, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0D, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2023-08-05T17:03:49.633798269+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-08-05T17:03:49.638481227+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-05T17:03:49.639507435+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: ad6e8a1f-869b-4281-bf00-b97c4b6a6a78 [0x4477] (תאורת כניסה)> emitting event: {“state”:{“value”:“on”},“attribute_id”:“switch”,“component_id”:“switch2”,“capability_id”:“switch”}
2023-08-05T17:03:49.655131560+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת כניסה device thread event handled
2023-08-05T17:03:49.655917019+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-08-05T17:03:49.656711560+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: ad6e8a1f-869b-4281-bf00-b97c4b6a6a78 [0x4477] (תאורת כניסה)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x4477, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -49, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0C, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2023-08-05T17:03:49.662625269+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת כניסה device thread event handled
2023-08-05T17:03:49.675191060+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-08-05T17:03:49.675959019+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-05T17:03:49.678454144+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: ad6e8a1f-869b-4281-bf00-b97c4b6a6a78 [0x4477] (תאורת כניסה)> emitting event: {“state”:{“value”:“off”},“attribute_id”:“switch”,“component_id”:“main”,“capability_id”:“switch”}
2023-08-05T17:03:49.684133685+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת כניסה device thread event handled
2023-08-05T17:03:49.687380810+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת כניסה device thread event handled
2023-08-05T17:03:50.766778102+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-08-05T17:03:50.767695893+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: ad6e8a1f-869b-4281-bf00-b97c4b6a6a78 [0x4477] (תאורת כניסה)> received Zigbee message: < ZigbeeMessageRx || type: 0x02, < AddressHeader || src_addr: 0x4477, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: Basic >, lqi: 0xFF, rssi: -49, body_length: 0x000B, < ZDOMessageBody || < ZDOHeader || seqno: 0xD7 >, GenericBody: 00 00 00 00 00 00 00 00 00 00 > >
2023-08-05T17:03:50.778877185+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת כניסה device thread event handled
2023-08-05T17:03:50.786310560+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-08-05T17:03:50.786759102+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: ad6e8a1f-869b-4281-bf00-b97c4b6a6a78 [0x4477] (תאורת כניסה)> received Zigbee message: < ZigbeeMessageRx || type: 0x02, < AddressHeader || src_addr: 0x4477, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: Basic >, lqi: 0xFF, rssi: -49, body_length: 0x000B, < ZDOMessageBody || < ZDOHeader || seqno: 0xD8 >, GenericBody: 00 00 00 00 00 00 00 00 00 00 > >
2023-08-05T17:03:50.859966560+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת כניסה device thread event handled
2023-08-05T17:03:50.863665060+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-08-05T17:03:50.864145435+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: ad6e8a1f-869b-4281-bf00-b97c4b6a6a78 [0x4477] (תאורת כניסה)> received Zigbee message: < ZigbeeMessageRx || type: 0x02, < AddressHeader || src_addr: 0x4477, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: Basic >, lqi: 0xFF, rssi: -49, body_length: 0x000B, < ZDOMessageBody || < ZDOHeader || seqno: 0xD9 >, GenericBody: 00 00 00 00 00 00 00 00 00 00 > >
2023-08-05T17:03:50.876406227+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת כניסה device thread event handled
2023-08-05T17:03:51.671438851+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: ad6e8a1f-869b-4281-bf00-b97c4b6a6a78 [0x4477] (תאורת כניסה)> emitting event: {“state”:{“value”:"S2:On "},“attribute_id”:“switchAllOnOff”,“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”}
2023-08-05T17:03:51.692819726+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: ad6e8a1f-869b-4281-bf00-b97c4b6a6a78 [0x4477] (תאורת כניסה)> emitting event: {“state”:{“value”:"S2:On "},“attribute_id”:“switchAllOnOff”,“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”}
2023-08-05T17:03:51.693608393+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת כניסה device thread event handled
2023-08-05T17:03:51.711944393+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: ad6e8a1f-869b-4281-bf00-b97c4b6a6a78 [0x4477] (תאורת כניסה)> emitting event: {“state”:{“value”:"S2:On "},“attribute_id”:“switchAllOnOff”,“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”}
2023-08-05T17:03:51.718973393+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: ad6e8a1f-869b-4281-bf00-b97c4b6a6a78 [0x4477] (תאורת כניסה)> emitting event: {“state”:{“value”:“S2:On “},“attribute_id”:“switchAllOnOff”,“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”}
2023-08-05T17:03:51.726220685+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת כניסה device thread event handled
2023-08-05T17:04:02.013774016+00:00 DEBUG Zigbee Multi Switch and Child Mc driver device thread event handled
2023-08-05T17:04:02.476760016+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler capability
2023-08-05T17:04:02.504670474+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: d3922489-ddb3-4588-abd5-f057c23201c9 [0x4AD4] (תאורת חדר הדר)> received command: {“args”:{},“command”:“on”,“capability”:“switch”,“positional_args”:{},“component”:“main”}
2023-08-05T17:04:02.505514849+00:00 TRACE Zigbee Multi Switch and Child Mc Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2023-08-05T17:04:02.506205891+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת חדר הדר device thread event handled
2023-08-05T17:04:14.797972429+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-08-05T17:04:14.802723554+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: fd438055-b988-4df0-b3f5-7dc7203d50c8 [0x2487] (לחצן מרפסת-תאורה)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2487, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xFE, rssi: -38, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x1D, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0001, DataType: Uint8, ApplicationVersion: 0x41 >, < AttributeRecord || AttributeId: 0xFFE2, DataType: Uint8, Uint8: 0x1F >, < AttributeRecord || AttributeId: 0xFFE4, DataType: Uint8, Uint8: 0x00 > > > >
2023-08-05T17:04:14.803601971+00:00 DEBUG Zigbee Multi Switch and Child Mc לחצן מרפסת-תאורה device thread event handled
2023-08-05T17:04:26.971300718+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler capability
2023-08-05T17:04:26.974209926+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: d3922489-ddb3-4588-abd5-f057c23201c9 [0x4AD4] (תאורת חדר הדר)> received command: {“args”:{},“command”:“on”,“capability”:“switch”,“positional_args”:{},“component”:“main”}
2023-08-05T17:04:26.977106635+00:00 TRACE Zigbee Multi Switch and Child Mc Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2023-08-05T17:04:26.978497885+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת חדר הדר device thread event handled
2023-08-05T17:04:32.026131175+00:00 DEBUG Zigbee Multi Switch and Child Mc driver device thread event handled
2023-08-05T17:04:57.616581502+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler capability
2023-08-05T17:04:57.635836752+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: d3922489-ddb3-4588-abd5-f057c23201c9 [0x4AD4] (תאורת חדר הדר)> received command: {“args”:{},“command”:“on”,“capability”:“switch”,“positional_args”:{},“component”:“main”}
2023-08-05T17:04:57.638331794+00:00 TRACE Zigbee Multi Switch and Child Mc Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2023-08-05T17:04:57.639030294+00:00 DEBUG Zigbee Multi Switch and Child Mc תאורת חדר הדר device thread event handled
2023-08-05T17:05:02.026089251+00:00 DEBUG Zigbee Multi Switch and Child Mc driver device thread event handled
2023-08-05T17:05:22.926557496+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-08-05T17:05:22.927128746+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: 4bec33c4-dd7a-471c-802a-e46d546364d5 [0xFB6C] (רפיטר חדר הדר)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFB6C, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0xFF, rssi: -38, body_length: 0x000F, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x21, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0001, DataType: Uint8, ApplicationVersion: 0x43 >, < AttributeRecord || AttributeId: 0xFFE2, DataType: Uint8, Uint8: 0x1F >, < AttributeRecord || AttributeId: 0xFFE4, DataType: Uint8, Uint8: 0x00 > > > >
2023-08-05T17:05:22.928213746+00:00 DEBUG Zigbee Multi Switch and Child Mc רפיטר חדר הדר device thread event handled
2023-08-05T17:05:32.027107078+00:00 INFO Zigbee Multi Switch and Child Mc Doing health check read for [2487]:0006:0000
2023-08-05T17:05:32.028280286+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: fd438055-b988-4df0-b3f5-7dc7203d50c8 [0x2487] (לחצן מרפסת-תאורה)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2487, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2023-08-05T17:05:32.032364911+00:00 DEBUG Zigbee Multi Switch and Child Mc driver device thread event handled
2023-08-05T17:05:32.166264161+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-08-05T17:05:32.167102577+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: fd438055-b988-4df0-b3f5-7dc7203d50c8 [0x2487] (לחצן מרפסת-תאורה)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2487, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -66, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x19, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: false > > > >
2023-08-05T17:05:32.177322036+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-08-05T17:05:32.179838036+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-05T17:05:32.184094327+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: fd438055-b988-4df0-b3f5-7dc7203d50c8 [0x2487] (לחצן מרפסת-תאורה)> emitting event: {“state”:{“value”:”<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2023/08/05 Time: 17:05
DNI: 0x2487 LQI: 255 RSSI: -66dbm
”},“attribute_id”:“signalMetrics”,“component_id”:“main”,“visibility”:{“displayed”:true},“capability_id”:“legendabsolute60149.signalMetrics”}
2023-08-05T17:05:32.188965536+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: fd438055-b988-4df0-b3f5-7dc7203d50c8 [0x2487] (לחצן מרפסת-תאורה)> emitting event: {“state”:{“value”:“off”},“attribute_id”:“switch”,“component_id”:“main”,“capability_id”:“switch”}
2023-08-05T17:05:32.272636911+00:00 DEBUG Zigbee Multi Switch and Child Mc לחצן מרפסת-תאורה device thread event handled
2023-08-05T17:05:32.275796911+00:00 DEBUG Zigbee Multi Switch and Child Mc לחצן מרפסת-תאורה device thread event handled
2023-08-05T17:05:34.286415994+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: fd438055-b988-4df0-b3f5-7dc7203d50c8 [0x2487] (לחצן מרפסת-תאורה)> emitting event: {“state”:{“value”:“All Off”},“attribute_id”:“switchAllOnOff”,“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”}
2023-08-05T17:05:34.298866410+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: fd438055-b988-4df0-b3f5-7dc7203d50c8 [0x2487] (לחצן מרפסת-תאורה)> emitting event: {“state”:{“value”:“All Off”},“attribute_id”:“switchAllOnOff”,“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”}
2023-08-05T17:05:34.358618577+00:00 DEBUG Zigbee Multi Switch and Child Mc לחצן מרפסת-תאורה device thread event handled
Hi Mariano,
Many thanks. Had to disconnect and reconnect and it worked…
Thanks once again…
Regards
Lanio
is this device ID? d3922489-ddb3-4588-abd5-f057c23201c9 [0x4AD4]
In the first log works fine and the secondl log not works
Wath fingerprints is?
Device d3922489-ddb3-4588-abd5-f057c23201c9
1st, log works fine from mechanical switch , don’t work from app. 2nd log retries from mechanical switch
FP:
Mfg Code _TZ3000_fisb3ajo
Model TS0002
Hi Marino.
i have a problem with your Zigbee Siren Mc driver.
i have this Neo siren:
And i get this in the webapp :
Can you help me out ?
Hi @Pattayacity
This device seems to use the EF00 cluster, as I have seen in other posts of yours encon @w35l3y
It won’t work with my standard driver if you use that EFoo cluster.
You can install my Zigbee Thing Mc driver to see if it shows all the clusters of the device
