(EDGE Driver-Mc): Z-Wave Edge Drivers and others with FIBARO devices:
Hi @guxdude
You no longer need to do mirror automations, you have to use the Z-Wave Switch and Child Mc driver and optionally create a child device for switch 2.
You should also be able to use the stock Z-Wave Switch, which creates a chid device for switch 2 on installation.
Hi @Mariano_Colmenarejo ,
Would you be able to add the following finger print?
It’s a Inovelli Dimmer Smart Plug NZW39 and I haven’t been able to locate any community drivers that support it.
MSR: 015D-2700-2700
zw:L type:1101 mfr:015D prod:2700 model:2700 ver:1.01 zwv:4.61 lib:03 cc:5E,26,27,70,5B,85,8E,59,55,86,72,5A,73,9F,6C,7A role:05 ff:8601 ui:8600
Thanks in advance for your time.
Hi @Rodd62
Are you tried with official inovelli edge drivers channel?
Thanks! I converted to your new driver (since I didn’t want to delete and reinstall) and seems to be working ok. Your drivers are great! Thank you so much for all your work!
@Mariano_Colmenarejo, hello again. So I used the settings to create child devices for both relays. Switch2 and the associated child device track well with each other and with the physical switch. The Main switch tracks with the physical switch but not the child Switch 1 device. The child device controls the light fine but if I switch the power in the parent device or with the physical switch, the child device does not track.
I have the same device (Inovelli NZW39) and asked on their forum, they said it is not supported by their drivers and suggested to use the ST driver but I have been unable to get anything to work.
Hi @guxdude
Sorry is error in the profile.
switch1 does not exit in the profile, only exist main and switch2 components. Copy and paste error :man_facepalming:
Please delete child device switch1 from app an turn to false the preference of create switch1.
This driver version fix the error
 Name         Z-Wave Switch and Child Mc
 Version      2022-12-12T12:32:52.450610523
I rejoined and did not get a match. All I get are DHTs or nothing.
If it’s not possible, all good, but I figured I’d ask.
Thanks again –
Has switch level, power and energy capabilities or only switch and level?
Switch and level only.
Thanks again
Added to this driver version
Try if it works
 Version      2022-12-12T21:57:00.779033724
- id: 015D/2700/2700
    deviceLabel: Inovelli Dimmer NZW39
    manufacturerId: 0x015D
    productType: 0x2700
    productId: 0x2700
    deviceProfileName: switch-level
It worked perfectly!
Thank you so much!
Hi @Mariano_Colmenarejo .
You could add this Fibaro device:
  • Double Smart Module FGS-224
    It’s like the fibaro double switch 2 but with dry outputs.
    Your drivers works only for the first channel
Here is the fingerprint
Manufacturer:0x010F
Product Type:0x0204
Product ID:0x1000
End Point & Command Class:[0]: SWITCH_BINARY, ASSOCIATION, MULTI_CHANNEL_ASSOCIATION, ASSOCIATION_GRP_INFO, VERSION, MANUFACTURER_SPECIFIC, DEVICE_RESET_LOCALLY, POWERLEVEL, CENTRAL_SCENE, MULTI_CHANNEL, CONFIGURATION, PROTECTION, NOTIFICATION, FIRMWARE_UPDATE_MD, ZWAVEPLUS_INFO, TRANSPORT_SERVICE, SECURITY, SECURITY_2, CRC_16_ENCAP, SUPERVISION, APPLICATION_STATUS
End Point & Command Class:[1]: SWITCH_BINARY, ASSOCIATION, MULTI_CHANNEL_ASSOCIATION, ASSOCIATION_GRP_INFO, VERSION, MANUFACTURER_SPECIFIC, DEVICE_RESET_LOCALLY, POWERLEVEL, CENTRAL_SCENE, MULTI_CHANNEL, CONFIGURATION, PROTECTION, NOTIFICATION, FIRMWARE_UPDATE_MD, ZWAVEPLUS_INFO, TRANSPORT_SERVICE, SECURITY, SECURITY_2, CRC_16_ENCAP, SUPERVISION, APPLICATION_STATUS
Thank you
Hi @svalenciano
That will take me a while, I need to create a profile, subdriver and test It.
I think there is already a driver created by @Daniele_Ratti for this device
I use your driver for other fibaro devices, and it is better and easy to use only one driver for my fibaro devices, but I didn’t know about the existence of this driver from @Daniele_Ratti. It works fine, thank you.
Anyway if you want to add this model to your driver I can help you testing with my devices
Can FGMS-001 be supported? Its Fibaro’s motion sensor but has multiple other features too.
Manual
Hi @baivab
This device should be in the stock Z-Wave Sensor driver and possibly also in my Z-Wave Sensor And Child Thermostat Mc driver
Have you tried to see if it matches?
Thanks worked. Z-Wave Sensor And Child Thermostat Mc
As for Z-Wave Sensor, I could not find it in your channel.
I have 5 Fibaro Flood Sensors. Though just over half of my device types have updated to Edge drivers automatically, these haven’t. Can anyone tell me if the Fibaro Flood Sensor has an Edge driver yet and if so, if this one will update automatically before the support for Groovy ends?
Hi… I think the Fibaro RGBW2 have a new version of the Command class, so cause the driver is not working for the new version RGBW2 … please refer to below… hope that you can update your driver to suit this
