(EDGE Driver-Mc): Z-Wave Edge Drivers and others with FIBARO devices:
El st color se ejecuta correctamente.
Effectively the command with the level argument is received but the driver does not execute it.
Execute a command On and level 100% which would be the last one used
When you send the command that does not works if nothing is received in the driver, it could be blocked in the API and does not reach the hub
