have you done anything to disable MQTT?
I think I wanted to isolate and be sure that it was the battery causing the problem so I unenrolled the MQTT and paired it without.
Hi. Does anyone has the driver for aqara H1 3way no netural?
You better include Zigbee Finger Print in order to find the correct driver for you.
Use Mariano’s . Zigbee Thing MC driver and attach a screen shot
I’ll try to unenroll, surprised the battery change can affect it that much? Even though it’s new out of the box . Do you have a 4 button aqara opple wireless switch too?
No I don’t. My only wireless switch was the Aqara Cube.
There is a glitch with MQTT driver or maybe you guys do something special. But MQTT is a LAN(wifi) driver and should never be assigned to Zigbee devices. My question was how do you rule out the mqtt and connect the Zigbee thing?
After pairing to any Zigbee driver it’s easy to switch drivers in the app.
I unenrolled the MQTT driver and tried to put the switch into pairing mode in a variety of reset pairing button pressing combos and it so happened to pair and show up with the right name and driver. It almost takes 10-20 tries to get any aqara device to pair seems like.
@veonua I have paired an Aqara WXKG11LM (wireless mini switch) that is supposed to support, single, double, triple, quadruple and hold press, but actually with the current driver is only supporting single, double and hold, is something that can be done to add triple and quadruple pressing?
Sorry, I don’t know where I read it support triple and quadruple, according to Aqara site only support single, double and hold.
This issue is as old as Aqara. Nobody reads the old posts in the forum or uses the search function.
There are several devices with the same name and look but different firmware
Do you think Is it possible to modify your driver to only show the supported pressing? Right now I can see until 5th press, which is not supported, and that could be a kind of confused.
the code is openly available, you are welcome to make the changes and make a pull request.
I use the Smartthings app only for initial setup, in day-to-day use it is way too slow. I’m using homekit and Google Home.
Hi @veonua ,
Your driver works with lumi.plug.mmeu01, but no Power and Energy metrics are displayed.
even that it seem to be sending in LOG. Attached LOG contain pairing and some on/off from APP
Can you please have a look:
For example : "0x0055, DataType: SinglePrecisionFloat, PresentValue: (1 + 0.770500) * 2^(2)"
, looks for me as power
LOG
? Select a driver. 11
connecting… connected
2023-08-12T10:29:06.366256133+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler device_lifecycle
2023-08-12T10:29:06.396832341+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Zigbee Device: af91a300-a826-4af9-a8cd-d77c25146414
Manufacturer: LUMI Model: lumi.plug.mmeu01
[1]: server: Basic, DeviceTemperatureConfiguration, Identify, Groups, Scenes, OnOff, Alarms, SimpleMetering, ElectricalMeasurement | client: Time, OTAUpgrade [242]: server | client: 0x0021
2023-08-12T10:29:06.397327383+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received lifecycle event: added
2023-08-12T10:29:06.398317466+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler device_lifecycle
2023-08-12T10:29:06.398972008+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received lifecycle event: doConfigure
2023-08-12T10:29:06.400060549+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received unhandled lifecycle event: added
2023-08-12T10:29:06.400968299+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:06.417117549+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Found DeviceLifecycleDispatcher handler in switch
2023-08-12T10:29:06.425236549+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Found CapabilityCommandDispatcher handler in switch
2023-08-12T10:29:06.425762924+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 Ep#1 device_id:0x0051 profile_id:0x0104 model:‘lumi.plug.mmeu01’ manufacturer:‘LUMI’ Client clusters:[Time, OTAUpgrade, ] Server clusters:[Basic, DeviceTemperatureConfiguration, Identify, Groups, Scenes, OnOff, Alarms, SimpleMetering, ElectricalMeasurement, ]
2023-08-12T10:29:06.426606966+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 Ep#242 device_id:0x0061 profile_id:0xA1E0 Client clusters:[0x0021, ] Server clusters:
2023-08-12T10:29:06.427491549+00:00 WARN Xiaomi/Aqara Switch and Button v1.17 No configuration found for: lumi.plug.mmeu01
2023-08-12T10:29:06.428155049+00:00 WARN Xiaomi/Aqara Switch and Button v1.17 No Multistate Input for: lumi.plug.mmeu01
2023-08-12T10:29:06.428801883+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6CE5, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 04CF8CDF3C7E4DC1, src_endpoint: 0x01, cluster: ElectricalMeasurement, dest_addr_mode: 0x03, dest_address: D052A8A4E1940001, dest_endpoint: 0x01 > > >
2023-08-12T10:29:06.430887008+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6CE5, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x050B, DataType: Int16, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 5 > > > >
2023-08-12T10:29:06.438351258+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6CE5, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 04CF8CDF3C7E4DC1, src_endpoint: 0x01, cluster: SimpleMetering, dest_addr_mode: 0x03, dest_address: D052A8A4E1940001, dest_endpoint: 0x01 > > >
2023-08-12T10:29:06.444406008+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6CE5, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0400, DataType: Int24, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 5 > > > >
2023-08-12T10:29:06.450588383+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6CE5, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 04CF8CDF3C7E4DC1, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: D052A8A4E1940001, dest_endpoint: 0x01 > > >
2023-08-12T10:29:06.456832841+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6CE5, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2023-08-12T10:29:06.470671049+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:06.471129966+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> doConfigure callback did not fail, transitioning device to “PROVISIONED”
2023-08-12T10:29:06.478514383+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:06.494477299+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:29:06.495188716+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFE, rssi: -57, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x71 >, < BindRequestResponse || status: 0x00 > > >
2023-08-12T10:29:06.501568674+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:06.545871966+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:29:06.546584508+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFD, rssi: -57, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x43, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: UNREPORTABLE_ATTRIBUTE, direction: 0x00, attr_id: 0x050B > > > >
2023-08-12T10:29:06.553324716+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:06.575909299+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:29:06.579033758+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -56, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x72 >, < BindRequestResponse || status: 0x00 > > >
2023-08-12T10:29:06.588225674+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:06.784999591+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:29:06.787124341+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFF, rssi: -57, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x44, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, direction: 0x00, attr_id: 0x0400 > > > >
2023-08-12T10:29:06.821472841+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:06.926090341+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:29:06.926978341+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -57, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x73 >, < BindRequestResponse || status: 0x00 > > >
2023-08-12T10:29:06.945838008+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:06.947635216+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler device_lifecycle
2023-08-12T10:29:06.949576508+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received lifecycle event: infoChanged
2023-08-12T10:29:06.958197883+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Found DeviceLifecycleDispatcher handler in switch
2023-08-12T10:29:06.959868383+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:06.969197674+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:29:06.974098049+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -56, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x45, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || ZclStatus: SUCCESS > > >
2023-08-12T10:29:06.975031174+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:07.105302883+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:29:07.108565049+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFCC0 >, lqi: 0xFF, rssi: -56, body_length: 0x0046, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x115F, seqno: 0x03, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x00F7, DataType: OctetString, OctetString: “\x64\x10\x00\x03\x28\x1B\x98\x39\x00\x00\x00\x00\x95\x39\xA4\xA9\x55\x42\x96\x39\x00\xA0\x0C\x45\x97\x39\x00\x00\x00\x00\x05\x21\x01\x00\x9A\x20\x00\x08\x21\x16\x01\x07\x27\x00\x00\x00\x00\x00\x00\x00\x00\x09\x21\x00\x0B\x0B\x20\x00\x9B\x10\x01” > > > >
2023-08-12T10:29:07.112513508+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:08.247414174+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:29:08.250880966+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFD, rssi: -56, body_length: 0x000E, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x04, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false >, < AttributeRecord || AttributeId: 0x00F5, DataType: Uint32, Uint32: 0x02FFFF00 > > > >
2023-08-12T10:29:08.266881841+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Found ZigbeeMessageDispatcher handler in switch
2023-08-12T10:29:08.267329882+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-12T10:29:08.268312216+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> emitting event: {“state”:{“value”:“off”},“capability_id”:“switch”,“component_id”:“main”,“attribute_id”:“switch”}
2023-08-12T10:29:08.269424424+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:09.287281049+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:29:09.288205007+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFCC0 >, lqi: 0xFE, rssi: -57, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x115F, seqno: 0x05, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0207, DataType: Boolean, Boolean: true > > > >
2023-08-12T10:29:09.294536715+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:20.057371421+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 driver device thread event handled
2023-08-12T10:29:47.816696123+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler capability
2023-08-12T10:29:47.818249248+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received command: {“capability”:“switch”,“positional_args”:{},“args”:{},“command”:“on”,“component”:“main”}
2023-08-12T10:29:47.819241290+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Found CapabilityCommandDispatcher handler in switch
2023-08-12T10:29:47.834973373+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:47.927083081+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:29:47.927903581+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -56, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x46, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2023-08-12T10:29:47.937342165+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Found ZigbeeMessageDispatcher handler in switch
2023-08-12T10:29:47.939342040+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2023-08-12T10:29:47.940340748+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> emitting event: {“state”:{“value”:“on”},“capability_id”:“switch”,“component_id”:“main”,“attribute_id”:“switch”}
2023-08-12T10:29:47.952636415+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:47.956117373+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:29:47.956583415+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFD, rssi: -56, body_length: 0x000E, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x06, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true >, < AttributeRecord || AttributeId: 0x00F5, DataType: Uint32, Uint32: 0x07000046 > > > >
2023-08-12T10:29:47.968211956+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Found ZigbeeMessageDispatcher handler in switch
2023-08-12T10:29:47.968797039+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-12T10:29:47.969969748+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> emitting event: {“state”:{“value”:“on”},“capability_id”:“switch”,“component_id”:“main”,“attribute_id”:“switch”}
2023-08-12T10:29:47.970950248+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:29:50.096818747+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 driver device thread event handled
2023-08-12T10:29:57.946155495+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:29:57.947100370+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x15, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: AnalogInput >, lqi: 0xFD, rssi: -58, body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x07, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0055, DataType: SinglePrecisionFloat, PresentValue: (1 + 0.770500) * 2^(2) > > > >
2023-08-12T10:29:57.953692787+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:30:20.087705490+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 driver device thread event handled
2023-08-12T10:30:31.842936362+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler capability
2023-08-12T10:30:31.845933071+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received command: {“capability”:“switch”,“positional_args”:{},“args”:{},“command”:“off”,“component”:“main”}
2023-08-12T10:30:31.846960737+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Found CapabilityCommandDispatcher handler in switch
2023-08-12T10:30:31.858143612+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:30:31.944997071+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:30:31.945852696+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFE, rssi: -56, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x49, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: SUCCESS > > >
2023-08-12T10:30:31.960691029+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Found ZigbeeMessageDispatcher handler in switch
2023-08-12T10:30:31.961736279+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2023-08-12T10:30:31.962742404+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> emitting event: {“state”:{“value”:“off”},“capability_id”:“switch”,“component_id”:“main”,“attribute_id”:“switch”}
2023-08-12T10:30:31.964438279+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:30:31.996912654+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:30:31.997611529+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFD, rssi: -56, body_length: 0x000E, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x08, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false >, < AttributeRecord || AttributeId: 0x00F5, DataType: Uint32, Uint32: 0x07000049 > > > >
2023-08-12T10:30:32.007435654+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Found ZigbeeMessageDispatcher handler in switch
2023-08-12T10:30:32.016695237+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-12T10:30:32.017490321+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> emitting event: {“state”:{“value”:“off”},“capability_id”:“switch”,“component_id”:“main”,“attribute_id”:“switch”}
2023-08-12T10:30:32.019494612+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:30:32.021229154+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:30:32.025365779+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x15, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: AnalogInput >, lqi: 0xFD, rssi: -56, body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x09, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0055, DataType: SinglePrecisionFloat, PresentValue: 0 > > > >
2023-08-12T10:30:32.029431529+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:30:48.866119067+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler capability
2023-08-12T10:30:48.887278400+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received command: {“capability”:“switch”,“positional_args”:{},“args”:{},“command”:“on”,“component”:“main”}
2023-08-12T10:30:48.892901692+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Found CapabilityCommandDispatcher handler in switch
2023-08-12T10:30:48.893332525+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:30:48.975312817+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:30:48.976253275+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -57, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4A, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2023-08-12T10:30:48.987136858+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Found ZigbeeMessageDispatcher handler in switch
2023-08-12T10:30:48.989269775+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2023-08-12T10:30:48.990269483+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> emitting event: {“state”:{“value”:“on”},“capability_id”:“switch”,“component_id”:“main”,“attribute_id”:“switch”}
2023-08-12T10:30:49.002452900+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:30:49.006118858+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:30:49.006590733+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -58, body_length: 0x000E, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true >, < AttributeRecord || AttributeId: 0x00F5, DataType: Uint32, Uint32: 0x0700004A > > > >
2023-08-12T10:30:49.017689192+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Found ZigbeeMessageDispatcher handler in switch
2023-08-12T10:30:49.018265108+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-12T10:30:49.019427858+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> emitting event: {“state”:{“value”:“on”},“capability_id”:“switch”,“component_id”:“main”,“attribute_id”:“switch”}
2023-08-12T10:30:49.022126858+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:30:50.073896233+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 driver device thread event handled
2023-08-12T10:30:53.095921941+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:30:53.096841399+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (Mi Power Plug EU (ZNCZ04LM))> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x15, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: AnalogInput >, lqi: 0xFF, rssi: -58, body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0B, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0055, DataType: SinglePrecisionFloat, PresentValue: (1 + 0.636000) * 2^(2) > > > >
2023-08-12T10:30:53.102351899+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 Mi Power Plug EU (ZNCZ04LM) device thread event handled
2023-08-12T10:31:20.072283601+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 driver device thread event handled
2023-08-12T10:31:50.086612024+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 driver device thread event handled
2023-08-12T10:31:54.525186875+00:00 TRACE Xiaomi/Aqara Switch and Button v1.17 Received event with handler zigbee
2023-08-12T10:31:54.526242681+00:00 INFO Xiaomi/Aqara Switch and Button v1.17 <ZigbeeDevice: 7d948403-d543-44b6-bcb8-5693fd0ddd42 [0x3896] (שקע נשלט הדר)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x3896, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFCC0 >, lqi: 0xFF, rssi: -35, body_length: 0x0046, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x115F, seqno: 0x8D, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x00F7, DataType: OctetString, OctetString: “\x64\x10\x01\x03\x28\x1D\x98\x39\x00\x00\x00\x00\x95\x39\xDD\xCF\x43\x40\x96\x39\x00\xC0\x0F\x45\x97\x39\x00\x00\x00\x00\x05\x21\x02\x00\x9A\x20\x00\x08\x21\x16\x01\x07\x27\x00\x00\x00\x00\x00\x00\x00\x00\x09\x21\x01\x0C\x0B\x20\x00\x9B\x10\x00” > > > >
2023-08-12T10:31:54.531691163+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 שקע נשלט הדר device thread event handled
2023-08-12T10:32:20.108567533+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 driver device thread event handled
2023-08-12T10:32:50.106141328+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 driver device thread event handled
2023-08-12T10:33:20.119571832+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.17 driver device thread event handled
It’s strange because this driver is designed for switches and buttons, not for plugs. I attempted to combine the drivers in some experiments, but they shouldn’t be accessible to the public.
Could you please switch to the Plug driver and try it out using the corresponding forum thread?
i need some help, how do i add new drivers so my Aqara D1 2 way gang switch will start working again?
aeonyrs
Since you did not mention the Finger Print, I’m guess the device is:
This should works with @veonua driver:
https://api.smartthings.com/invitation-web/accept?id=5e5b1616-90cf-4383-83ea-a323aac0ed5a
@veonua New user to Smart Things… so please pardon me if I am asking any stupid questions
I am using a couple of Aqara H1 Switches (lumi.switch.n1aeu1, lumi.switch.n2aeu1). The physical state/status of the switch does not seems to reflect to the app. Is the physical state/status not supposed to be updated into the app? If not, is there anything I am doing wrong?
How can I enable the decoupled mode with your drivers as I tried to use the settings > button > Change from switch to Detached but it is not working?
I believe my device is WS-EUK01 (lumi.switch.l1aeu1) and the button status is correctly shown in the history. Can you send me a log from your device?
I can’t send you the logs when I physically click on the switch since it does not seems to send anything via the driver. I tested your driver on lumi.switch.n2aeu1 & other models and it seems like the physical status did not reflect on the app. However, I managed to install another driver for lumi.switch.n2aeu1 and below are the logs when I physically click on the switch.
[Edit] I installed your driver on the same switch and generated the logs below.
2023-08-14T14:44:04.240046519+00:00 DEBUG Zigbee Multi Switch and Child Mc driver device thread event handled
2023-08-14T14:44:10.599129855+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-08-14T14:44:10.600407188+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: 11b8199b-9d43-4504-80a4-23e53f87f5b4 [0xF2D0] (Bathroom)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xF2D0, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCC, rssi: -65, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xB6, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2023-08-14T14:44:10.606065522+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-08-14T14:44:10.618356188+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-14T14:44:10.620249855+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: 11b8199b-9d43-4504-80a4-23e53f87f5b4 [0xF2D0] (Bathroom)> emitting event: {"attribute_id":"signalMetrics","state":{"value":"<em table style='font-size:70%';'font-weight: bold'</em><b>GMT: </b>2023/08/14 Time: 14:44<BR><b>DNI: </b>0xF2D0 <b> LQI: </b>204 <b>RSSI: </b>-65dbm</em><BR>"},"visibility":{"displayed":true},"component_id":"main","capability_id":"legendabsolute60149.signalMetrics"}
2023-08-14T14:44:10.627532522+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: 11b8199b-9d43-4504-80a4-23e53f87f5b4 [0xF2D0] (Bathroom)> emitting event: {"attribute_id":"switch","state":{"value":"on"},"component_id":"main","capability_id":"switch"}
2023-08-14T14:44:10.661889522+00:00 DEBUG Zigbee Multi Switch and Child Mc Bathroom device thread event handled
2023-08-14T14:44:10.671132855+00:00 DEBUG Zigbee Multi Switch and Child Mc Bathroom device thread event handled
2023-08-14T14:44:12.687202189+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: 11b8199b-9d43-4504-80a4-23e53f87f5b4 [0xF2D0] (Bathroom)> emitting event: {"attribute_id":"switchAllOnOff","state":{"value":"S1:On "},"component_id":"main","capability_id":"legendabsolute60149.switchAllOnOff1"}
2023-08-14T14:44:12.699207856+00:00 DEBUG Zigbee Multi Switch and Child Mc Bathroom device thread event handled
2023-08-14T14:44:13.660953523+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-08-14T14:44:13.662220190+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: 11b8199b-9d43-4504-80a4-23e53f87f5b4 [0xF2D0] (Bathroom)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xF2D0, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCE, rssi: -68, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xC2, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2023-08-14T14:44:13.746319857+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-08-14T14:44:13.747749523+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-14T14:44:13.752019523+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: 11b8199b-9d43-4504-80a4-23e53f87f5b4 [0xF2D0] (Bathroom)> emitting event: {"attribute_id":"switch","state":{"value":"off"},"component_id":"main","capability_id":"switch"}
2023-08-14T14:44:13.770198190+00:00 DEBUG Zigbee Multi Switch and Child Mc Bathroom device thread event handled
2023-08-14T14:44:13.771290190+00:00 DEBUG Zigbee Multi Switch and Child Mc Bathroom device thread event handled
2023-08-14T14:44:15.800748524+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: 11b8199b-9d43-4504-80a4-23e53f87f5b4 [0xF2D0] (Bathroom)> emitting event: {"attribute_id":"switchAllOnOff","state":{"value":"All Off"},"component_id":"main","capability_id":"legendabsolute60149.switchAllOnOff1"}
2023-08-14T14:44:15.804188524+00:00 DEBUG Zigbee Multi Switch and Child Mc Bathroom device thread event handled
2023-08-14T14:58:56.338272179+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.18 driver device thread event handled
2023-08-14T14:59:06.900329733+00:00 TRACE Xiaomi/Aqara Switch and Button v1.18 Received event with handler zigbee
2023-08-14T14:59:06.929289872+00:00 INFO Xiaomi/Aqara Switch and Button v1.18 <ZigbeeDevice: 11b8199b-9d43-4504-80a4-23e53f87f5b4 [0xF2D0] (Bathroom)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xF2D0, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCA, rssi: -74, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x52, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2023-08-14T14:59:07.004824621+00:00 TRACE Xiaomi/Aqara Switch and Button v1.18 Found ZigbeeMessageDispatcher handler in switch
2023-08-14T14:59:07.005677380+00:00 INFO Xiaomi/Aqara Switch and Button v1.18 Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-14T14:59:07.161155414+00:00 INFO Xiaomi/Aqara Switch and Button v1.18 endpoint: 1 > component: nil
2023-08-14T14:59:07.169351843+00:00 INFO Xiaomi/Aqara Switch and Button v1.18 <ZigbeeDevice: 11b8199b-9d43-4504-80a4-23e53f87f5b4 [0xF2D0] (Bathroom)> emitting event: {"attribute_id":"switch","component_id":"main","state":{"value":"on"},"capability_id":"switch"}
2023-08-14T14:59:07.180413371+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.18 Bathroom device thread event handled
2023-08-14T14:59:08.855901030+00:00 TRACE Xiaomi/Aqara Switch and Button v1.18 Received event with handler zigbee
2023-08-14T14:59:08.862927208+00:00 INFO Xiaomi/Aqara Switch and Button v1.18 <ZigbeeDevice: 11b8199b-9d43-4504-80a4-23e53f87f5b4 [0xF2D0] (Bathroom)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xF2D0, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCE, rssi: -72, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2023-08-14T14:59:08.867722605+00:00 TRACE Xiaomi/Aqara Switch and Button v1.18 Found ZigbeeMessageDispatcher handler in switch
2023-08-14T14:59:08.868580367+00:00 INFO Xiaomi/Aqara Switch and Button v1.18 Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-14T14:59:08.881901357+00:00 INFO Xiaomi/Aqara Switch and Button v1.18 endpoint: 1 > component: nil
2023-08-14T14:59:08.886885848+00:00 INFO Xiaomi/Aqara Switch and Button v1.18 <ZigbeeDevice: 11b8199b-9d43-4504-80a4-23e53f87f5b4 [0xF2D0] (Bathroom)> emitting event: {"attribute_id":"switch","component_id":"main","state":{"value":"off"},"capability_id":"switch"}
2023-08-14T14:59:08.935627207+00:00 DEBUG Xiaomi/Aqara Switch and Button v1.18 Bathroom device thread event handled
