EDGE_Child losses control
Hi All, i just realised that i have loss connectivity on my switch which on the two/three gang switches. First switch works fine, its the second and third switch that is non responsive. Upon checking, its been mark as EDGE_CHILD. I have enrol and install driver from mariano, but to no avail.
I read that i need to delete the codes in IDE, however, when i went to IDE site, im being redirected to smartthings, any idea how do i go about? Thank you.
Hi @Khairul_Osman
Edge child created with one specific driver will not work when you change to another driver.
If you have my driver installed, then with the App delete all the Child devices that you have created.
On the device app, select Settings (preferences), menu three dots top right in the app details view and create the child devices again.
The new child devices will appears in the room were the hub is
This is an example of a 3 switch zigbee device
From where exacly do i find this settings? i did click on the three dots on the top right, but could not find such options.
What drivers are you using?
Im using urs. I toggle between Zigbee Thing MC
Then please, post the zigbee thing Mc info
here you go…
@Khairul_Osman
Your device does not in my driver.
I added your device in this driver version
  • Delete your device and all child devices with App
  • Delete old version of Zigbee Multi Switch and Child Mc if is installed in your hub
  • Install in your Hub this new version of the driver Zigbee Multi Switch and Child Mc from my channel
  • Set the device in pairing mode and add new device with app search nearby option.
  • When device appears in app and works, then you can create the child device for switch2 component from settings preferences
 Name         Zigbee Multi Switch and Child Mc
 Version      2023-08-05T16:32:54.605228036
- id: "TS0002/_TZ3000_yhagrqmd"
    deviceLabel: TS0002 Switch
    manufacturer: _TZ3000_yhagrqmd
    model: TS0002
    deviceProfileName: two-switch
You are god send. Manage to do it… Will now test on the 3 and 4 gang switches.
Post the data with zigbee thing Mc
@Khairul_Osman
Sorry, I’ll look at it tomorrow, now I’m busy
Added to this driver version
 Version      2023-08-05T22:23:24.897161115
Hi Mariano, for the 3 and 4 gang there are showing these log when i change driver. I have uninstall and re install the driver to the hub but still having this issue. Appreciate your kind help. Thank you.
You need thus driver date version installed in
Your hub.
It probably will work automagically with the driver β€œDefault clusters”
You may want to give a try using this invitation link:
https://api.smartthings.com/invite/6Vjd4YPVJwjN
Hello Mariano,
Yes ive already installed the updated driver, but am not able to choose β€œZigbee Multi Switch and Child MC” for the 3&4 gang switch.
Sorry, I swapped models TS0003 and TS0004 in fingerprints.
Fixed error in this driver version
 Version      2023-08-06T10:29:51.864191711
- id: "TS0004/_TZ3000_aqgofyol"
    deviceLabel: TS0004 Switch
    manufacturer: _TZ3000_aqgofyol
    model: TS0004
    deviceProfileName: four-switch
  - id: "_TZ3000_thhxrept/TS0003"
    deviceLabel: TS0003 Switch
    manufacturer: _TZ3000_thhxrept
    model: TS0003
    deviceProfileName: three-switch
Install this new driver version
Uninstall devices from App. Driver change does not work fine to configure TUYA multicomponents devices
Add new devices from App with option Search nearby
Thanks Mariano. Appreciate it.
