I have written an edge driver GitHub - mystifier-gh/sonoff-edge
Currently it supports only switch/light and brightness control.
Everyone is welcome to use it and perhaps maintain it as well.
eWelink (sonoff and other brands) smartthings edge driver
eWelink devices broadcast their status on mDNS (which works on LAN) and can be send commands on LAN. This edge driver uses mDNS to update device state and http commands over LAN to set device states.
eWelink encrypts the communication, both mDNS broadcasts and http commands for non-DIY mode devices. The decryption key is devicekey and can be retrived from eWelink server using eWelink credentials. Each device type is identified using uiid and can be used to configure the devices in greater detail. uiid can also be retrived along with devicekey and lots of other device data from eWelink server. devicekey and uiid possibily never change during the lifetime of device.
Steps to install
Install the driver and search for the virtual hub
Subscribe to channel and install the driver ewelink LAN Driver (0a4bfd5c-adb0-404f-8da4-acc5287372ef)
Then open Smartthings app, Add device → Search nearby. You will see a device ewelink virtual hub Click Done.
You will also see the ewelink devices in 30 seconds. But these devices maynot work as they require encryption key.
Update the devices with eWelink data
Download script ewelink.js
Ensure node version is v20 or newer. It may run in earlier versions as well.
node -v
v20.6.1
then run the script
node ewelink.js username password region [port]
where
username is your username at eWelink.
password is your password at eWelink.
region is your server at eWelink. one of us, cn, eu or as
port is the local port to listen to. Optional, default to 8003.
You should see a lot of json
"xxxxxxxxxx": {
"name": "Hallway light",
"deviceid": "xxxxxxxxxx",
"apikey": "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxx",
"extra": {
"uiid": 1,
"description": "20191112004",
"brandId": "5c4c1aee3a7d24c7100be054",
followed by
serving at http://10.0.0.41:8003/
From the above json data, extract the device key and set it in the settings.
Feed from the server:
Open Smartthings app, find the device
ewelink virtual hub, select it and click 3 dots and selectsettings. In Url enter the your server URL from above (eg. http://10.0.0.41:8003/ ) and save. You should now see the devices added.Stop the server and we do not need it anymore. All stuff from now happens on LAN.
Set the device key
Extract the device key from the above output and set it on corresponding device
To add support for a device
The types of device supported by ewelink is identified by uiid. In the above json dump you will see the value for each of the devices at data.thingList.itemData.extra.uiid
For example:
"error": 0,
"msg": "",
"data": {
"thingList": [
"itemType": 1,
"itemData": {
"deviceid": "xxxxxxxxx",
"extra": {
"uiid": 1,
"description": "xxxxxxxx",
Each uiid is explained in UIIDProtocol
Add a smartthings device profile for the uiid and corresponding handlers.
Go ahead and enjoy !!!
