Am I publishing my channel invitations correctly?
Hi, @harobinson
Just to be clear, the command “edge:channels:invite” doesn’t publish a driver, it “enables” an invitation where users can enroll their hub to your channel.
If you package a new version of the driver, you need to assign that new version to the channel required with the command smartthings edge:channels:assign .
I just made a test and the command “edge:channels:metainfo” showed a previous version because I only packaged the driver but didn’t publish it to the channel, so, that could be happening in your case.
