EcoLink Motion detector
I’m reading about this sensor and comparing it to the Monoprice “white box” motion detector. The monoprice is claimed to be a reboxed EcoLink but no where do I see temperature information on the EcoLink as I do the monoprice. I really want temp sensing to start an attic fan and need motion as well and I’m drawn to the EcoLink as it has native ST support. I could do the Aeon multi but it has functions I do not need so why pay the extra.
Does the EcoLink have temperature or should I just go with the monoprice and use the device type I found in the forum?
why not the SmartThings motion sensor? https://shop.smartthings.com/#!/products/smartsense-motion-sensor
Probably because the ST motion sensor is ~50% more expensive.
Continuing the discussion from EcoLink Motion detector:
Exactly. Sometimes you get what you pay for and I’m ok with spending more but is it necessary? If I was going to spend $50 on a sensor it would be the Aeon Labs Aeotec Z-Wave Multi-Sensor off amazon.
Also that sensor is ZigBee and I don’t need anything else using 2.4Ghz in the house.
Even do the Monoprice one seems to be a rebranded Ecolink the test jumper function on it does not work like the Ecolink so probably there are some non cosmetic differences
I have the same issue – I have both the EcoLink motion sensor and the Monoprice motion sensor.
The EcoLink one doesn’t show the temperature – according to the Amazon description “In addition to sensing motion, light and temperature, the 3-in1 Sensor also monitors its own battery”.
I don’t see the light and temperature data coming through in SmartThings though – has anyone got this to work? I may just return it and get the Monoprice one.
Ok I have both. My ecolink motion sensor doesn’t display temperature but my monoprice one does.
They both report 100% battery.
Anyone else have the right device types for these?
@thrash99er can you please check your device type in your Smartthings IDE for your monoprice and your ecolink. Are using the same device types (my ecolink uses a Z-Wave motion sensor, is the same one used by mono price?) if not I’ll see if I can port the changes from the monoprice device type to the standard so it can support temp also.
I’m using the Z-wave motion sensor for my Ecolink, and the Monoprice Motion Sensor device type for my Monoprice.
I’m using @florianz device type for my monoprice.
I just don’t think that the Ecolink motion sensors have temperature sensors in them.
