I am using the default device handler (secure dimmer) as setup by the QR code and it does work, however the app doesn’t correspond correctly with the switch when using the physical buttons (both on/off and dimmer). So the lights could be off but looking at the app, they show on. Same with the dim level.
I am just using this switch only and NOT with an accessory dimmer. Perhaps this is the wrong device handler?
