[Duplicate Post]
Good morning. Can someone provide a code to add a Sonos smart speaker notification to work with the laundry monitor to announce a cycle is finished with the flashing lights? I would love for the lights to flash and for the Sonos speaking to make an announcement stating the dryer is finished.
Can you please provide the complete code for the app? the existing code is listed below.
Thank you in advance.
  • Copyright 2015 SmartThings
  • Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
  • in compliance with the License. You may obtain a copy of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
  • on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
  • for the specific language governing permissions and limitations under the License.
  • Laundry Monitor
  • Author: SmartThings
  • Sends a message and (optionally) turns on or blinks a light to indicate that laundry is done.
  • Date: 2013-02-21
definition(
name: “Laundry Monitor”,
namespace: “smartthings”,
author: “SmartThings”,
description: “Sends a message and (optionally) turns on or blinks a light to indicate that laundry is done.”,
category: “Convenience”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/FunAndSocial/App-HotTubTuner.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/FunAndSocial/App-HotTubTuner%402x.png
preferences {
section(“Tell me when this washer/dryer has stopped…”){
input “sensor1”, “capability.accelerationSensor”
section(“Via this number (optional, sends push notification if not specified)”){
input(“recipients”, “contact”, title: “Send notifications to”) {
input “phone”, “phone”, title: “Phone Number”, required: false
section(“And by turning on these lights (optional)”) {
input “switches”, “capability.switch”, required: false, multiple: true, title: “Which lights?”
input “lightMode”, “enum”, options: [“Flash Lights”, “Turn On Lights”], required: false, defaultValue: “Turn On Lights”, title: “Action?”
section(“Time thresholds (in minutes, optional)”){
input “cycleTime”, “decimal”, title: “Minimum cycle time”, required: false, defaultValue: 10
input “fillTime”, “decimal”, title: “Time to fill tub”, required: false, defaultValue: 5
def installed()
initialize()
def updated()
unsubscribe()
initialize()
def initialize() {
subscribe(sensor1, “acceleration.active”, accelerationActiveHandler)
subscribe(sensor1, “acceleration.inactive”, accelerationInactiveHandler)
def accelerationActiveHandler(evt) {
log.trace “vibration”
if (!state.isRunning) {
log.info “Arming detector”
state.isRunning = true
state.startedAt = now()
state.stoppedAt = null
def accelerationInactiveHandler(evt) {
log.trace “no vibration, isRunning: state.isRunning" if (state.isRunning) { log.debug "startedAt: {state.startedAt}, stoppedAt: ${state.stoppedAt}”
if (!state.stoppedAt) {
state.stoppedAt = now()
def delay = Math.floor(fillTime * 60).toInteger()
runIn(delay, checkRunning, [overwrite: false])
def checkRunning() {
log.trace “checkRunning()”
def fillTimeMsec = fillTime ? fillTime * 60000 : 300000
def sensorStates = sensor1.statesSince(“acceleration”, new Date((now() - fillTimeMsec) as Long))
	if (!sensorStates.find{it.value == "active"}) {
		def cycleTimeMsec = cycleTime ? cycleTime * 60000 : 600000
		def duration = now() - state.startedAt
		if (duration - fillTimeMsec > cycleTimeMsec) {
			log.debug "Sending notification"
			def msg = "${sensor1.displayName} is finished"
			log.info msg
            if (location.contactBookEnabled) {
                sendNotificationToContacts(msg, recipients)
            else {
                if (phone) {
                    sendSms phone, msg
                } else {
                    sendPush msg
			if (switches) {
				if (lightMode?.equals("Turn On Lights")) {
					switches.on()
				} else {
					flashLights()
		} else {
			log.debug "Not sending notification because machine wasn't running long enough $duration versus $cycleTimeMsec msec"
		state.isRunning = false
		log.info "Disarming detector"
	} else {
		log.debug "skipping notification because vibration detected again"
else {
	log.debug "machine no longer running"
private flashLights() {
def doFlash = true
def onFor = onFor ?: 1000
def offFor = offFor ?: 1000
def numFlashes = numFlashes ?: 3
log.debug "LAST ACTIVATED IS: ${state.lastActivated}"
if (state.lastActivated) {
	def elapsed = now() - state.lastActivated
	def sequenceTime = (numFlashes + 1) * (onFor + offFor)
	doFlash = elapsed > sequenceTime
	log.debug "DO FLASH: $doFlash, ELAPSED: $elapsed, LAST ACTIVATED: ${state.lastActivated}"
if (doFlash) {
	log.debug "FLASHING $numFlashes times"
	state.lastActivated = now()
	log.debug "LAST ACTIVATED SET TO: ${state.lastActivated}"
	def initialActionOn = switches.collect{it.currentSwitch != "on"}
	def delay = 1L
	numFlashes.times {
		log.trace "Switch on after  $delay msec"
		switches.eachWithIndex {s, i ->
			if (initialActionOn[i]) {
				s.on(delay: delay)
			else {
				s.off(delay:delay)
		delay += onFor
		log.trace "Switch off after $delay msec"
				s.off(delay: delay)
			else {
				s.on(delay:delay)
		delay += offFor
Crosspost . . .
Good morning Bryan. It’s a sonos
Good morning. Yes, I saw that in your other post.
I was flagging this as a crosspost as you have posted twice regarding the same topic. Presumably an admin will remove this post so that others do not respond to it.
@JDRoberts
Yes. I’m sorry. I did.
Steven Paul Ross
917.669.1658 M
516.595.7630 O
516.268.6313 F
You may want to edit your post and remove the numbers from it. Be careful if replying by email that may include a signature file containing personal Info
