I have a dryer notification app I slightly modified that works fine. I really want to combine the functionality of “Notify Me With Hue” to this app. I have been messing with it the past few days, but I’m not having much luck. Feel this should be pretty simple and any help would be appreciated.
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Dryer Monitor
* Author: Justin Stowers
* Sends a message and (optionally) turns on or blinks a light to indicate that your clothes are dry.
* Date: 2015-09-29
definition(
name: "Dryer Monitor",
namespace: "JustinDS",
author: "JustinDS",
description: "Sends a message and (optionally) turns on or blinks a light to indicate that your clothes are dry.",
category: "Convenience",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/FunAndSocial/App-HotTubTuner.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/FunAndSocial/App-HotTubTuner%402x.png"
preferences {
section("Tell me when this dryer has stopped..."){
input "sensor1", "capability.accelerationSensor"
section("Via this number (optional, sends push notification if not specified)"){
input("recipients", "contact", title: "Send notifications to") {
input "phone", "phone", title: "Phone Number", required: false
section("And by turning on these lights (optional)") {
input "switches", "capability.switch", required: false, multiple: true, title: "Which lights?"
input "lightMode", "enum", options: ["Flash Lights", "Turn On Lights"], required: false, defaultValue: "Turn On Lights", title: "Action?"
section("Time thresholds (in minutes, optional)"){
input "cycleTime", "decimal", title: "Minimum cycle time", required: false, defaultValue: 10
input "fillTime", "decimal", title: "Time to fill tub", required: false, defaultValue: 5
def installed()
initialize()
def updated()
unsubscribe()
initialize()
def initialize() {
subscribe(sensor1, "acceleration.active", accelerationActiveHandler)
subscribe(sensor1, "acceleration.inactive", accelerationInactiveHandler)
def accelerationActiveHandler(evt) {
log.trace "vibration"
if (!state.isRunning) {
log.info "Arming detector"
state.isRunning = true
state.startedAt = now()
state.stoppedAt = null
def accelerationInactiveHandler(evt) {
log.trace "no vibration, isRunning: $state.isRunning"
if (state.isRunning) {
log.debug "startedAt: ${state.startedAt}, stoppedAt: ${state.stoppedAt}"
if (!state.stoppedAt) {
state.stoppedAt = now()
def delay = Math.floor(fillTime * 60).toInteger()
runIn(delay, checkRunning, [overwrite: false])
def checkRunning() {
log.trace "checkRunning()"
def fillTimeMsec = fillTime ? fillTime * 60000 : 300000
def sensorStates = sensor1.statesSince("acceleration", new Date((now() - fillTimeMsec) as Long))
if (!sensorStates.find{it.value == "active"}) {
def cycleTimeMsec = cycleTime ? cycleTime * 60000 : 600000
def duration = now() - state.startedAt
if (duration - fillTimeMsec > cycleTimeMsec) {
log.debug "Sending notification"
def msg = "$Your Clothes AreDry!"
log.info msg
if (location.contactBookEnabled) {
sendNotificationToContacts(msg, recipients)
else {
if (phone) {
sendSms phone, msg
} else {
sendPush msg
if (switches) {
if (lightMode?.equals("Turn On Lights")) {
switches.on()
} else {
flashLights()
} else {
log.debug "Not sending notification because machine wasn't running long enough $duration versus $cycleTimeMsec msec"
state.isRunning = false
log.info "Disarming detector"
} else {
log.debug "skipping notification because vibration detected again"
else {
log.debug "machine no longer running"
private flashLights() {
def doFlash = true
def onFor = onFor ?: 1000
def offFor = offFor ?: 1000
def numFlashes = numFlashes ?: 3
log.debug "LAST ACTIVATED IS: ${state.lastActivated}"
if (state.lastActivated) {
def elapsed = now() - state.lastActivated
def sequenceTime = (numFlashes + 1) * (onFor + offFor)
doFlash = elapsed > sequenceTime
log.debug "DO FLASH: $doFlash, ELAPSED: $elapsed, LAST ACTIVATED: ${state.lastActivated}"
if (doFlash) {
log.debug "FLASHING $numFlashes times"
state.lastActivated = now()
log.debug "LAST ACTIVATED SET TO: ${state.lastActivated}"
def initialActionOn = switches.collect{it.currentSwitch != "on"}
def delay = 1L
numFlashes.times {
log.trace "Switch on after $delay msec"
switches.eachWithIndex {s, i ->
if (initialActionOn[i]) {
s.on(delay: delay)
else {
s.off(delay:delay)
delay += onFor
log.trace "Switch off after $delay msec"
s.off(delay: delay)
else {
s.on(delay:delay)
delay += offFor
* Notify Me With Hue
* Author: SmartThings
* Date: 2014-01-20
definition(
name: "Notify Me With Hue",
namespace: "smartthings",
author: "SmartThings",
description: "Changes the color and brightness of Philips Hue bulbs when any of a variety of SmartThings is activated. Supports motion, contact, acceleration, moisture and presence sensors as well as switches.",
category: "SmartThings Labs",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Partner/hue.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Partner/hue@2x.png"
preferences {
section("Control these bulbs...") {
input "hues", "capability.colorControl", title: "Which Hue Bulbs?", required:true, multiple:true
section("Choose one or more, when..."){
input "motion", "capability.motionSensor", title: "Motion Here", required: false, multiple: true
input "contact", "capability.contactSensor", title: "Contact Opens", required: false, multiple: true
input "contactClosed", "capability.contactSensor", title: "Contact Closes", required: false, multiple: true
input "acceleration", "capability.accelerationSensor", title: "Acceleration Detected", required: false, multiple: true
input "mySwitch", "capability.switch", title: "Switch Turned On", required: false, multiple: true
input "mySwitchOff", "capability.switch", title: "Switch Turned Off", required: false, multiple: true
input "arrivalPresence", "capability.presenceSensor", title: "Arrival Of", required: false, multiple: true
input "departurePresence", "capability.presenceSensor", title: "Departure Of", required: false, multiple: true
input "smoke", "capability.smokeDetector", title: "Smoke Detected", required: false, multiple: true
input "water", "capability.waterSensor", title: "Water Sensor Wet", required: false, multiple: true
input "button1", "capability.button", title: "Button Press", required:false, multiple:true //remove from production
input "triggerModes", "mode", title: "System Changes Mode", description: "Select mode(s)", required: false, multiple: true
input "timeOfDay", "time", title: "At a Scheduled Time", required: false
section("Choose light effects...")
input "color", "enum", title: "Hue Color?", required: false, multiple:false, options: ["Red","Green","Blue","Yellow","Orange","Purple","Pink"]
input "lightLevel", "enum", title: "Light Level?", required: false, options: [[10:"10%"],[20:"20%"],[30:"30%"],[40:"40%"],[50:"50%"],[60:"60%"],[70:"70%"],[80:"80%"],[90:"90%"],[100:"100%"]]
input "duration", "number", title: "Duration Seconds?", required: false
//input "turnOn", "enum", title: "Turn On when Off?", required: false, options: ["Yes","No"]
section("Minimum time between messages (optional, defaults to every message)") {
input "frequency", "decimal", title: "Minutes", required: false
def installed() {
log.debug "Installed with settings: ${settings}"
subscribeToEvents()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
unschedule()
subscribeToEvents()
def subscribeToEvents() {
subscribe(app, appTouchHandler)
subscribe(contact, "contact.open", eventHandler)
subscribe(contactClosed, "contact.closed", eventHandler)
subscribe(acceleration, "acceleration.active", eventHandler)
subscribe(motion, "motion.active", eventHandler)
subscribe(mySwitch, "switch.on", eventHandler)
subscribe(mySwitchOff, "switch.off", eventHandler)
subscribe(arrivalPresence, "presence.present", eventHandler)
subscribe(departurePresence, "presence.not present", eventHandler)
subscribe(smoke, "smoke.detected", eventHandler)
subscribe(smoke, "smoke.tested", eventHandler)
subscribe(smoke, "carbonMonoxide.detected", eventHandler)
subscribe(water, "water.wet", eventHandler)
subscribe(button1, "button.pushed", eventHandler)
if (triggerModes) {
subscribe(location, modeChangeHandler)
if (timeOfDay) {
schedule(timeOfDay, scheduledTimeHandler)
def eventHandler(evt) {
if (frequency) {
def lastTime = state[evt.deviceId]
if (lastTime == null || now() - lastTime >= frequency * 60000) {
takeAction(evt)
else {
takeAction(evt)
def modeChangeHandler(evt) {
log.trace "modeChangeHandler $evt.name: $evt.value ($triggerModes)"
if (evt.value in triggerModes) {
eventHandler(evt)
def scheduledTimeHandler() {
eventHandler(null)
def appTouchHandler(evt) {
takeAction(evt)
private takeAction(evt) {
if (frequency) {
state[evt.deviceId] = now()
def hueColor = 0
if(color == "Blue")
hueColor = 70//60
else if(color == "Green")
hueColor = 39//30
else if(color == "Yellow")
hueColor = 25//16
else if(color == "Orange")
hueColor = 10
else if(color == "Purple")
hueColor = 75
else if(color == "Pink")
hueColor = 83
state.previous = [:]
hues.each {
state.previous[it.id] = [
"switch": it.currentValue("switch"),
"level" : it.currentValue("level"),
"hue": it.currentValue("hue"),
"saturation": it.currentValue("saturation"),
"color": it.currentValue("color")
log.debug "current values = $state.previous"
def newValue = [hue: hueColor, saturation: 100, level: (lightLevel as Integer) ?: 100]
log.debug "new value = $newValue"
hues*.setColor(newValue)
setTimer()
def setTimer()
if(!duration) //default to 10 seconds
log.debug "pause 10"
pause(10 * 1000)
log.debug "reset hue"
resetHue()
else if(duration < 10)
log.debug "pause $duration"
pause(duration * 1000)
log.debug "resetHue"
resetHue()
else
log.debug "runIn $duration, resetHue"
runIn(duration,"resetHue", [overwrite: false])
def resetHue()
hues.each {
it.setColor(state.previous[it.id])
